Fuel problem??
Louise
PostPosted: 18:13 - 03 Oct 2010    Post subject: Fuel problem?? Reply with quote
Going to work this afternoon, running fine, hit the motorway and the bike just sounded like a sack of shyte.
Splutterin, sounded terrible, would give me power, then wouldnt, chugging, jolting forward.
Its in fact sounding like a V-twin right now.
Slow ride coming home, its just at the 3k rev mark, 1st 2nd gear its very very sluggish,almost sounding like it wants to backfire - untill i manage to pick up speed, say around 40mph and the bike sounds fine? Pulling away is a nightmare!!
ive just put redex in with some more fuel...
Am thinking fuel starvation?? will redex clear it up eventually?
i need my bike all this week for work, but I dont want to cause more damage, if any Confused
Clanger
Stirrer
PostPosted: 18:26 - 03 Oct 2010    Post subject: Reply with quote
Wet plugs??
Carb heater?
Possibly...you have been riding about on the motorways in this horrible weather...it might be worth pulling your plug leads off and checking they are dry for a start... Thinking
Louise
PostPosted: 18:31 - 03 Oct 2010    Post subject: Reply with quote
Ive not riden in the rain, the bike was outside last night tho.. So unsure how the plugs could get wet, I will check tommorow just to make sure.
Walloper
PostPosted: 18:42 - 03 Oct 2010    Post subject: Reply with quote
Coil/s.
Water gets in and fcuks them for no reason.
Fuel solenoid valve. Opens when you turn on the key.
Is it fuel injected?
Could be shit in the system but that normally kills it completely.
Intermittent splutter/stutter sounds more like electrical....
Connection/s.
Dealer check?
Acemastr
PostPosted: 18:52 - 03 Oct 2010    Post subject: Reply with quote
sounds like it needs a good redline to clear some crap in the fuel system. Possibly a partially blocked breather pipe?
2016 Toyota Tacoma Limited
Ariel Badger
PostPosted: 19:05 - 03 Oct 2010    Post subject: Reply with quote
I will bet that there is water in the carb float bowls take them off and drain them.
Louise
PostPosted: 16:38 - 04 Oct 2010    Post subject: Reply with quote
Right, taken tank off, airfilter out. Got the these.
Slight mix of white stuff/ fuel (on the right of pic)
the "2nd pic is a side veiw of the throttle bodies.
Its fuel injected.
Im having troble removing the whole air box Evil or Very Mad Am trying to check the spark plugs!
https://i144.photobucket.com/albums/r167/LouiseB24/DSC_0736.jpg
https://i144.photobucket.com/albums/r167/LouiseB24/DSC_0735.jpg
Walloper
PostPosted: 18:38 - 04 Oct 2010    Post subject: Reply with quote
Don't drain the carbs what ever you do.
I don't know that water in fuel woulf give that symptom. It would normally kill the bike dead. (It doesn't emulsify with fuel but water can be full of crud and it's the crud that could cause stop start spluttery running.)
My famous symptom like that was the ignition system.
There is so much power in modern electronic ignition that is can blast through an amazing amount of conditions that old fashioned ignition would flat fail.
If the bike has had a soaking or been put away wet/after washing. The moisture can collect as condensation. Over time this can cause corrosion and high tension electrical energy tracing to ground.
That can cause lack of power and erratic running.
Drain the fuel tank into a spotless clean container.
If there is any sign of detritus or water in the fuel then it may well be a fuel contamination problem.
Redex will not fix it. The problem will be something blocking the injectors or a fuel pressure regulator.
But do not panic.
If there is muck in the fuel drain off the tank and remove as much of the fuel system as you can.
Try to get the hoses and bits clean using one of those (Useless) PC air blower can things out of Staples.
Clash it al back together and refill with clean fuel.
Try to start as normal. It will take a few seconds to get fuel back through the system.
Worst thing is if there is a blockage in the injectors. This is more complex. I have no intimate knowledge of this Kwakakwaka 632 but my triumph needed two bloody injectors when it got contaminated.
Walloper
PostPosted: 20:25 - 04 Oct 2010    Post subject: Re: Fuel problem?? Reply with quote
'Not a big fan of Redex and other fuel addatives personaly, tho they've should have improved since I first tried them. When's the last time the plugs were changed? Can't hurt to use a bit of Contact Spray around the electrics. I use that GT64 stuff, or was that GT46 Question Confused Confused
Your age or your waist...? Laughing
Louise
PostPosted: 07:28 - 05 Oct 2010    Post subject: Reply with quote
The bike is turning over but not firing up now Evil or Very Mad So ive ordered sparks. Will drain the tank as well once they turn up.
Its all fresh fuel tho, im always adding a fiver every other day for work Confused
Walloper
PostPosted: 09:35 - 05 Oct 2010    Post subject: Reply with quote
i dont think she will, considering its fi
No shit.
Well no worries now you're on (Jumped on) the job.... Razz
Louise
PostPosted: 22:14 - 06 Oct 2010    Post subject: Reply with quote
have you had a look to check its actually sparking
To be honest, I wouldnt know how too Embarassed
Only bike I changed sparks on was my bandit - which was easy to do ect.
This is my first sports, and found it quiet a task to take bits off and find the spark plugs!!
Sparks have arrived, just waiting on the tool to remove them as I dont have one.
I wont drain the tank, as I said above, fresh fuel is in there every other day.
but yeah, tell me - how to check a spark Laughing
I pulled the HT lead from plugs. but thats it Confused
Louise
PostPosted: 18:55 - 08 Oct 2010    Post subject: Reply with quote
Right, Ive changed the spark plugs.
Rode it up the road, was fine for 2 miles. Then it started all over again.
Not as bad this time tho, More so if i was doing 35 in 4th gear - it would play up, i was just testing all the gears. Then a few more miles up the road, pulling away in 1st wasnt great, and would grunt/chugg.
Heres a link to the vid, its not great - the first 'rev' you can here its not right. the Revs after are normal.
Im lost now, maybe not firing on all cylinders Confused
https://www.youtube.com/watch?v=whxmVEBo5E4
yanto
PostPosted: 20:20 - 08 Oct 2010    Post subject: Reply with quote
hi bikes looks clean you havent jet washed it have you
every thing sems to point to water in the system and its easy to get water in the ram air of a 636 i have sen it a few times before
also that air box has a lot of dirt in it
could of got into the injection system
Louise
PostPosted: 20:49 - 08 Oct 2010    Post subject: Reply with quote
I had about 20 mins before darkness set in so i just changed the plugs. Not jet washed the bike. I shall try the tissue tomo, but isnt that the same with Wd40 sprayed onto the downpipes? Ill grab photos of old sparks tommorow.
yanto
PostPosted: 20:57 - 08 Oct 2010    Post subject: Reply with quote
Louise wrote:
but isnt that the same with Wd40 sprayed onto the downpipes? .
whooo dont do that wd40 is flammable
i worked in a garage in stafford and a guy was told to spray some on his plug leads to help with the damp
he done it with the bike running and it burst into flames
little not wd40 dries out and can cause more problems
i use duck oil or other penetrating fluids
Louise
PostPosted: 18:49 - 12 Oct 2010    Post subject: Reply with quote
Right, 3rd time taken to bits Brick Wall
All the plugs spark fine.
Ive put wet tissue on all the four pipes when warming up, all hiss/water drys right away.
The problem did get better - would only 'splutter/die' a few times - mainly in lower gear/slow speeds/pulling off.
I took it apart again, cleaned the HT leads inside - there was a fair bit of crud. I swaped over Ht 1 and 4 - then went for a run.
Runs alot better, and only twice it 'wanted' to splutter but didnt.
Im guessing I need to change the HT coil pack??
But the whole bike just stinks of fuel Confused
Pics of old plugs as asked
https://i144.photobucket.com/albums/r167/LouiseB24/DSC_0749.jpg
https://i144.photobucket.com/albums/r167/LouiseB24/DSC_0747.jpg
https://i144.photobucket.com/albums/r167/LouiseB24/DSC_0746.jpg
When i took the new plugs out to check, 1 and 4 were fine. However 2 and 3 were slightly covered in oil.
Clanger
Stirrer
PostPosted: 19:05 - 12 Oct 2010    Post subject: Reply with quote
Did you dry the leads too - inside where they meet the sparks?
TBH, Louise if my sparks looked like that, I'd lob them, and replace with new ones. Thumbs Up
Hopefully by bumping this thread back up, the others will come back with more advice...
Walloper
PostPosted: 19:07 - 12 Oct 2010    Post subject: Reply with quote
Firstly. Those pictures of the sparking plags are dreadfull.
You are far to close to the plugs to permit a sharp image.
Move the camera back to about 16".
Second. The plugs look usable but if you say the symptom improves as you clean the electrics then look at replacing the HT leads. And if doing that may as well do all four plugs too.
Does this engine have individual coil units? If so you may need dealer help to identify the one/s that are bad. If plugs HT leads don't help.
Or some Dude on here may have a easy way to check.
Ignition systems are normally cheaper to fix than fuel systems.
Louise
PostPosted: 19:24 - 12 Oct 2010    Post subject: Reply with quote
Sorry my cam is a lil poor on close ups.
They are the old plugs, I have replaced with 4 new ones now Thumbs Up
Walloper
PostPosted: 20:19 - 12 Oct 2010    Post subject: Reply with quote
Apology accepted. Smile
Sorry for speileng Plugs as Plags. Plags are useless in a modern motorcycle engine.
The last post was made 15 years, 334 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 119.39 Kb
