idles higher when warm
skikman
PostPosted: 17:04 - 04 Oct 2010    Post subject: idles higher when warm Reply with quote
hi.my lifan 125 custom idles higher after running for a few miles.it ticks over fine after a bit of choke first thing but if i go say to the next town [8 mile away] it will be ticking over faster.what do you think is up?
JackDaniels
PostPosted: 17:10 - 04 Oct 2010    Post subject: Reply with quote
my 50cc dose this also i have no idea why, mine never used to
THEORY TEST - PASSED! - 02-08-11 CBT Passed - 09-08-10 MOD 1 - 09-08-2011 - MOD 2 - 28-09-2011
2006 Yamaha JOGRR>2010 Yamaha Ybr>1995 Honda CB400 Superfour >2005 Honda hornet>1999 Suzuki Bandit 1200 > 2002 BMW R1150GS > 2013 Tiger Sport 1050 > 2007 GSXR 1000 > 2005 GS500E
SW Motech Shop UK
PostPosted: 17:57 - 04 Oct 2010    Post subject: Reply with quote
could be a number of things such as air leak on the intake or incorrect mixture. what sort of rpm difference are we talking about? What 125 is it?
https://www.motorcycle-road-and-race.co.uk and https://www.sw-motech-shop.co.uk/ and https://www.motorcycle-luggage.co.uk/
skikman
PostPosted: 18:14 - 04 Oct 2010    Post subject: Reply with quote
its the one in the pic.lifan 125 custom[copy of honda cm 125] not a big lot of revs but enough that you have to turn it down at carb.
yen_powell
PostPosted: 18:18 - 04 Oct 2010    Post subject: Reply with quote
Sounds normal to me. You should set the tickover speed when the engine is properly warmed up anyway, the next town sounds ideal.
XT1200Z and a DR350 in bits
L4Isoside
PostPosted: 18:37 - 04 Oct 2010    Post subject: Reply with quote
Its because its warm...
I assume its not fuel injected, my old ybr used to idle real low when it was hot (e.g. after long ride in summer etc) because it could handle it, yet in the cold it would idle higher because it needed to else it would cut out.
If its carbed then it would just idle at what you've set it at. Set it when warm in the summer, but in winter id set it just a tad higher to help for the cold mornings etc.
stuartadair
PostPosted: 19:33 - 04 Oct 2010    Post subject: Reply with quote
Hiya, I've got a Baimo Renegade with the same engine as yours. Its a Chinese variant of the CG125 (FM156 I think is the official name) Although I've messed about with it considerably, including upgrading to 150cc, it idles at about 1200rpm. It needs full choke to start and to idle for about the first 2/3 miles, after which it will idle but a little too slowly, perhaps 1000 rpm. This time of year it does need about 6/8 miles to really warm up and idle smoothly.
GSTEEL32
PostPosted: 19:44 - 04 Oct 2010    Post subject: Reply with quote
Possibly an airleak caused by either dog$hit gaskets, or incorrectly torqued cylinder bolts.....
skikman
PostPosted: 20:01 - 04 Oct 2010    Post subject: Reply with quote
not quite the same.mine is a 244fmi twin cylinder so twice as hard to set up.i was thinking carbs because it dosent idle smooth[up and down]but i dont want to mess with the mixture screw as you have to drill a hole to get at it
flumpy7
PostPosted: 20:36 - 04 Oct 2010    Post subject: Reply with quote
Hi i find small bikes often have some degree of fluctuation of idle speed like this....try not to worry about it its just part of the character of your bike. Sure you could get all frustrated and spend hours trying to sort it but whats the point? Just adjust it when you need to. If a 125 gets you from A to B its doing pretty much all that should be required of it!
2012 Sinnis apache
Glenben92
PostPosted: 22:35 - 04 Oct 2010    Post subject: Reply with quote
It's COMPLETELY normal :S thats like saying "after i let go of my clutch in gear, the bike moves forward, whats wrong?"
57 Huoniao HN125-8 - Smile, 97 Kawasaki GPZ500S - Very Happy
99 Yamaha FZS 600 - Wink
Mod 2 Passed - 01/10/2010
Alex A
PostPosted: 23:05 - 04 Oct 2010    Post subject: Reply with quote
It's normal on carbed bikes IME.
Set the idle speed when it's warm to 1.2-1.5k RPM (or whatever is appropriate). Then use your choke to fire it up and keep it revving before it warms up.
skikman
PostPosted: 23:20 - 04 Oct 2010    Post subject: Reply with quote
ok thanks everyone
Mr Hammers
PostPosted: 16:10 - 06 Oct 2010    Post subject: Reply with quote
Glenben92 wrote:
..after i let go of my clutch in gear, the bike moves forward, whats wrong?"
Sounds like you've got what's called a 'geared' bike. To stop this you need to remove the clutch, then the gearbox, and just to be sure, the engine. You should find that the problem with moving forward disappears completely. Thumbs Up
A Guide To Powerbands
Glenben92
PostPosted: 20:56 - 06 Oct 2010    Post subject: Reply with quote
Oh it's geared is it!? shit that sounds like its broken. Might just throw it away then, can't be doing with any of this "moving" business, it's just a hassle really Wink
"sarcasm is the lowest form of wit"... is it fuck it's bloody brilliant Smile
There is a gap of 2 years, 118 days between these two posts...
TrickyTrix
PostPosted: 02:22 - 01 Feb 2013    Post subject: High idle speed when warm Reply with quote
I have a bandit 600 1999 that idles high when hot, it's definitely not normal, 3000 ish when hot, 1200 when cold, checked carbs and airbox to some extent but not professional, went round checked all bolts, seem ok... Any ideas?
The last post was made 13 years, 288 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 89.28 Kb
