Waterproofing... the bike!
Acemastr
PostPosted: 08:37 - 05 Oct 2010    Post subject: Waterproofing... the bike! Reply with quote
Got to work today to find my headlight not working, appears to be the connector behind the dash (again), easily a 2 hour job to remove the entire front end, put it back in, and put it all back on.
My question is, are there any decent sprays out there to waterproof electrical contacts? maybe give it a WD40 and scrub the contacts before, may even dremel off the rusty bits, and spray on some waterproof spray once the 2 connectors are joined?
Cheers guys & girls
2016 Toyota Tacoma Limited
iooi
PostPosted: 09:00 - 05 Oct 2010    Post subject: Reply with quote
Clean the contacts up and then refit with a nice dollop of Vaseline to keep the water out.
There are sprays, but they cost more £££
Dazbo666
PostPosted: 09:13 - 05 Oct 2010    Post subject: Reply with quote
Not 100% how effective it is with electricals, but my suggestion would be PTFE spray etc... ??
I use Muc Off Maintenance Spray at the moment, and it seems to be pretty effective
Also had GT85 in the past with similar effects
ACF 50 is said to be one of the best, but not cheap
Word of the day : DILLIGAF
PostPosted: 09:21 - 05 Oct 2010    Post subject: Reply with quote
Take your pick of dielectric grease, ACF50 and vaseline. (in order of preference)
Rowey
PostPosted: 09:37 - 05 Oct 2010    Post subject: Reply with quote
Hot glue gun might work. Seals it up and glues it in place. If you need to remove it, warming it will make it easier to get off.
Silicone grease is good. Used it on outside satellite coax connectors.
ZX6R C6F.
Acemastr
PostPosted: 21:05 - 05 Oct 2010    Post subject: Reply with quote
Well, ironic really. Riding along, all throttle dies, lights all on, rev counter dying down as though the killswitch has been flicked.
Play about with the fuse box and it starts with a massive backfire. I now need to clean my fuse box thoroughly and waterproof it.
Can i literally spray a shedload of WD40 into it, leave it for an hour, Degreaser all over it, slap the fuses back in and ACF50 the lot? is this going to clean it? is this going to stop contact within the fusebox?
Many thanks
Glenben92
PostPosted: 22:08 - 05 Oct 2010    Post subject: Reply with quote
https://cgi.ebay.co.uk/NEW-Holts-Damp-Start-Ignition-Sealer---Autoplast--300ml_W0QQitemZ350199223212QQcmdZViewItem?rvr_id=149816187724&rvr_id=149816187724&cguid=e86c1eff1290a0e2027454f4ff67ec05
That stuff is absolute gold. designed for ignition circuits, it sprays on and forms a thin plastic film over the cables and connections. completely protects electrics. my bikes loom is covered and... it works very well.
and its cheap Smile
57 Huoniao HN125-8 - Smile, 97 Kawasaki GPZ500S - Very Happy
99 Yamaha FZS 600 - Wink
Mod 2 Passed - 01/10/2010
PostPosted: 23:57 - 05 Oct 2010    Post subject: Reply with quote
Worth noting that sprays/grease etc will only protect good connections.
Next time you take the tank/fairings/seat/whatevers off, don't just spray your chosen potion. Seperate the connectors and clean them, then apply potion (ACF50 is mine)
I used a jewelers screwdriver to scratch-clean the pins in the connector blocks. (battery disconnected and was careful not to touch 2 pins at once when doing the ECU block)
Did the same with the fuseblock.
Pat
Stelmer
PostPosted: 00:18 - 06 Oct 2010    Post subject: Reply with quote
I had to do all the connectors on the GSX when I got it. Only thing is that most of them fell apart upon being touched.....
I used Vaseline when I replaced them. 2 years later, everything electrical works still.....
PostPosted: 01:19 - 06 Oct 2010    Post subject: Reply with quote
Just to say. All of the things mentioned are electrical insulators. So if you get them between the contact surfaces, they can actually stop them making contact (in reality, it is usually scraped off the bit that actually makes contact as you assemble the connection).
What you should do is clean and assemble the connection THEN put the Grease/vaseline over the top of them.
Glenben92
PostPosted: 09:36 - 06 Oct 2010    Post subject: Reply with quote
Pat
Yeah very true. I assumed this was obvious but some might not think of it. If there's already any moisture inside a wire/connection then you're just gonna be sealing it in!
Acemastr
PostPosted: 10:12 - 06 Oct 2010    Post subject: Reply with quote
Think I'll dremel the contacts with a wire attachment, WD40 the entire fuse box/contacts, degreaser to remove the crap and WD40, then use whatever ignition sealer i choose (still hunting, ACF50 is extortionately priced, £14 for a normal sized can! can't imagine it being THAT good to charge £14...)
Acemastr
PostPosted: 10:25 - 06 Oct 2010    Post subject: Reply with quote
DrDonnyBrago
PostPosted: 10:36 - 06 Oct 2010    Post subject: Reply with quote
ACF50 is for the whole bike though. Spray it on everything metal except your discs and controls and it will help prevent the corrosion you get on our shitty roads..
PostPosted: 11:54 - 06 Oct 2010    Post subject: Reply with quote
The ACF does go a long way, one can lasts a long time. If you're doing terminals, spray a little into the lid then apply it with a small brush or a cloth.
Likewise on metal. Spray a little then wipe it about with a cloth, it doesn't need to be clagged on, if there is enough to make the metal appear slightly oily, that's enough. You can just keep the cloth and wipe stuff down with it, occasionally refreshing it with a bit of the spray.
Acemastr
PostPosted: 12:19 - 06 Oct 2010    Post subject: Reply with quote
Oh i see, i was going to go mental and squirt the hell out of everything, but if ACF is an insulator and i'm brushing it onto contacts etc... they surely aren't going to work? the fuse box is a mess with contacts etc, brushing ACF into there is going to be a nightmare and will cover the contacts.
Cheers for the help as well guys.
DrDonnyBrago
PostPosted: 12:36 - 06 Oct 2010    Post subject: Reply with quote
The ACF would get scratched out of the way when you plug everything back together. I have sprayed it into a particularly annoying connection before, all worked fine when I plugged it all back in.
PostPosted: 17:03 - 06 Oct 2010    Post subject: Reply with quote
If they are making contact now. They'll be doing so when covered with the stuff.
There is a goodly amount of it on the wiring on my bike.
Acemastr
PostPosted: 22:29 - 06 Oct 2010    Post subject: Reply with quote
Inept wrote:
If i'm only doing 150 miles a week or so, and wash my bike at least everyweek ... does that mean there is less of a need for going overboard with wd40 and acf .... Rolling Eyes Thumbs Up Karma Confused Smile
Is it left out overnight? mine is, I have a cover i've begun using again now which should help a bit
PostPosted: 22:45 - 06 Oct 2010    Post subject: Reply with quote
My understanding of ACF50 is you apply and leave. You can use water to wash off road dirt, just no shampoo etc.
Before i used ACF and got a shed, i kept my bike looking good by cleaning it after every wet ride(bike stored under a cover) This involved 2 watering cans of cold water to wash off the salt. Wiped off with rags. Used WD40 on a rag and wiped my bike down (excluding the obvious parts). Sprayed WD under the tank and behind my clocks.
Connector blocks were daubed in vaseline.
Rain or shine my bike looked good and it's easier to keep it looking good by cleaning a little and often.
Faults and leaks are easier to spot and fix.
[edit] and no, it's not showroom condition clean. I like to ride bikes as well as clean them
Acemastr
PostPosted: 12:58 - 07 Oct 2010    Post subject: Reply with quote
Reading up about ACF, one application done properly should last you the entire winter.
The last post was made 15 years, 310 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.63 - MySQL Queries: 13 - Page Size: 131.23 Kb
