| Acemastr |
 Acemastr World Chat Champion
| iooi |
 iooi Super Spammer
 Posted: 09:00 - 05 Oct 2010 Post subject: |
Clean the contacts up and then refit with a nice dollop of Vaseline to keep the water out.
There are sprays, but they cost more £££ ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| Dazbo666 |
 Dazbo666 World Chat Champion
 Posted: 09:13 - 05 Oct 2010 Post subject: |
Not 100% how effective it is with electricals, but my suggestion would be PTFE spray etc... ??
I use Muc Off Maintenance Spray at the moment, and it seems to be pretty effective
Also had GT85 in the past with similar effects
ACF 50 is said to be one of the best, but not cheap ____________________ 1st bike (Sept'06 - May'10) : 1991 GPZ500S / Current bike (since Nov 2009) : 2003 Suzuki Bandit 600N
Word of the day : DILLIGAF |
| Rowey |
 Rowey World Chat Champion
| Acemastr |
| Glenben92 |
 Glenben92 Nearly there...
| Howling TerrorOutOfOffice |
 Posted: 23:57 - 05 Oct 2010 Post subject: |
Worth noting that sprays/grease etc will only protect good connections.
Next time you take the tank/fairings/seat/whatevers off, don't just spray your chosen potion. Seperate the connectors and clean them, then apply potion (ACF50 is mine)
I used a jewelers screwdriver to scratch-clean the pins in the connector blocks. (battery disconnected and was careful not to touch 2 pins at once when doing the ECU block)
Did the same with the fuseblock.
Pat ____________________ Diabolical homemade music Bandcamp and Soundcloud
The Harry Turner Project |
| Stelmer |
 Stelmer World Chat Champion
| FURBAR |
 FURBAR Banned
 Posted: 01:03 - 06 Oct 2010 Post subject: |
So a bit of vaseline on electircal circuit blocks helps ... ?? .. as i will do that as of when if it's a good idea ..  ____________________ Fuk um !! |
 Posted: 01:19 - 06 Oct 2010 Post subject: |
Just to say. All of the things mentioned are electrical insulators. So if you get them between the contact surfaces, they can actually stop them making contact (in reality, it is usually scraped off the bit that actually makes contact as you assemble the connection).
What you should do is clean and assemble the connection THEN put the Grease/vaseline over the top of them. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Glenben92 |
 Posted: 09:36 - 06 Oct 2010 Post subject: |
| Acemastr |
| Acemastr |
| DrDonnyBrago |
 Posted: 11:54 - 06 Oct 2010 Post subject: |
The ACF does go a long way, one can lasts a long time. If you're doing terminals, spray a little into the lid then apply it with a small brush or a cloth.
Likewise on metal. Spray a little then wipe it about with a cloth, it doesn't need to be clagged on, if there is enough to make the metal appear slightly oily, that's enough. You can just keep the cloth and wipe stuff down with it, occasionally refreshing it with a bit of the spray. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Acemastr |
| DrDonnyBrago |
| FURBAR |
 FURBAR Banned
 Posted: 21:22 - 06 Oct 2010 Post subject: |
If i'm only doing 150 miles a week or so, and wash my bike at least everyweek ... does that mean there is less of a need for going overboard with wd40 and acf ....  ____________________ Fuk um !! |
| Acemastr |
 Posted: 22:29 - 06 Oct 2010 Post subject: |
Is it left out overnight? mine is, I have a cover i've begun using again now which should help a bit ____________________ 2017 KTM 350 XC-F - 2014 Yamaha R6 - 2005 Yamaha YZ125
2016 Toyota Tacoma Limited |
 Posted: 22:45 - 06 Oct 2010 Post subject: |
My understanding of ACF50 is you apply and leave. You can use water to wash off road dirt, just no shampoo etc.
Before i used ACF and got a shed, i kept my bike looking good by cleaning it after every wet ride(bike stored under a cover) This involved 2 watering cans of cold water to wash off the salt. Wiped off with rags. Used WD40 on a rag and wiped my bike down (excluding the obvious parts). Sprayed WD under the tank and behind my clocks.
Connector blocks were daubed in vaseline.
Rain or shine my bike looked good and it's easier to keep it looking good by cleaning a little and often.
Faults and leaks are easier to spot and fix.
[edit] and no, it's not showroom condition clean. I like to ride bikes as well as clean them ____________________ Diabolical homemade music Bandcamp and Soundcloud
| FURBAR |
 FURBAR Banned
 Posted: 12:47 - 07 Oct 2010 Post subject: |
I only put my bike / dry under a cover if i know i'm not going to use it for at least the next day or more .. i have sheets and blankets i use on thier own and with the cover ...
If no cover, the bike is under a LARGE garden umbrella .... and a small one over the front wheel and handlebars ..
Because of this, i'm thinking of using ACF50 less, and or on parts i see looking like they need it ...
I have a outdoor fixed hose on a wheel next to said bike, so spraying down whenever can be done in less than five mins ...
So still unsure if these plans are good or should be changed altured ..  ____________________ Fuk um !! |
| Acemastr |
| FURBAR |
 FURBAR Banned
 Posted: 13:06 - 07 Oct 2010 Post subject: |
Yes, done correctly it's supposed to .. i would be fine with that for a winter hack, but i'm not riding my bike round manky all winter ...  ____________________ Fuk um !! |
The last post was made 15 years, 312 days ago. Instead of replying here, would creating a new thread be more useful? |
