what suzuki is this
 Topic moved: from Show & Tell to General Bike Chat by Bendy (7 Oct 2010 - 18:04)
paulwhalley
PostPosted: 21:18 - 06 Oct 2010    Post subject: what suzuki is this Reply with quote
just got it all i no its a suzuki with jawa on the engine
hmmmnz
PostPosted: 21:36 - 06 Oct 2010    Post subject: Reply with quote
well its not Very Happy
its a cz175 motor from the early 60's
https://p1.bikepics.com/pics/2009%5C05%5C03%5Cbikepics-1656023-full.jpg
and the frame looks like.... a ts250 from around 74
https://www.bikez.com/pictures/suzuki/1974/9580_0_1_4_ts%20250_Image%20credits%20-%20Matthew%20J.%20Morling.jpg
the humans are dead
I kick arse for the lord
69.9mph
PostPosted: 22:55 - 06 Oct 2010    Post subject: Reply with quote
Hard to tell from the pics but it looks to be quite a small bike so could be a TS125. What are the wheel sizes?
I had a TS250 like that one back in the day but a '76 model - fun bike.
MaybeGuy
PostPosted: 23:02 - 06 Oct 2010    Post subject: Reply with quote
i doubt thats a suzuki frame. more likely just a random tank as it looks well out of place.
hmmmnz
PostPosted: 07:30 - 07 Oct 2010    Post subject: Reply with quote
the frame is definitly a suzuki frame, weither the tank from another model has been shoehorned on is another matter,
what are the numbers on the headstock??
the humans are dead
PostPosted: 12:17 - 07 Oct 2010    Post subject: Reply with quote
Looks a bit like an SP370 chassis.
HOWEVER. As I said in the other thread, the chain from a CZ engine is on the right, the sprocket on a Suzuki chassis will be on the left. Might just be a case of having flipped the back wheel.
Teflon-Mike
tl;dr
PostPosted: 17:58 - 07 Oct 2010    Post subject: Reply with quote
https://www.suzukicycles.org/photos/SP/SP370/1978_SP370_red_side_500.jpg
Frame loop is much taller and narrower on the SP to accomodate the big 4-stroke single. Shocks are more inclined. Tank & Mudguards all a lot different, as well as the forks and hubs.
Didn't 'quite' look like the TS250, so wondered whether it may be TS125/185.
https://www.motorcyclespecs.co.za/Gallery%20%20A/Suzuki%20TS%20185%2071.jpg
https://www.suzukicycles.org/photos/suzuki-history/1971/1971_TS125_450.jpg
Those are earlier mid-70's TS's, later ones had more inclined shocks and angular MX body-work.
Looking at them, they have twin diagonal frame rails coming down from the cylinder head area towards the swing-arm pivot, where the 'mystery-bike' and the TS250 seem to have a single back-bone coming down the middle.
Looks like a TS250 chassis then.
And I WONDER whether the engine might actually be 125?
Back in the early '80's old 250's were almost worthless, and one with a dead engine absolutely so. A CZ125 was pretty un-valuable also, and could be written off as beyond ecconomic repair come MOT time for something as daft as a duff regulator.... Slotting a working CZ125 motor into an old 250 Chassis, would have made a cheap learner legal.... Or it could have just been a low rent field bike excersize.
BUT looks like an early TS250 frame & cycle-parts, rather than a 125 or 185, and from the frame shape, probably pre-77.
As a classic, its not one I'd pick as a project, finding an engine for it is going to be a tuffee.... and theres a lot of work going to be needed on the cycle-parts. As a rider, bikes like this go for around a grand fifteen hundred, if done well, A show-bike done to part number spotters envy, will fetch a bit more, but few are ecconomically restored to eaither standard.... even when they bike comes with the engine its supposed to have!
What you thinking of doing with it?
paulwhalley
PostPosted: 18:20 - 07 Oct 2010    Post subject: Reply with quote
well im not to sure yet if i can find out what model it is then i might restore it! if not then i will tidy it up abit then ride it on the fields.
i have been told the engine is a 350cc its got 3 gears and the gear selector is the kick start as well as for frame numbers i will have to get back to you on that one as the bike is in some ones garage picking it up on Saturday so will have a look
some one said it could be a b120???
hmmmnz
PostPosted: 19:45 - 07 Oct 2010    Post subject: Reply with quote
a b120 uses a monocoque frame (eg 2 parts of sheet metal welded together) https://www.suzukicycles.org/photos/B/B120/1967_B120P_red_side_560.jpg
its not a 350, all jawa and cz 350's are twins,
i still have my money on it being a cz175 engine and ts250 frame,
get some more pictures and the frame and engine numbers
and we'll be able to tell more
the humans are dead
paulwhalley
PostPosted: 21:37 - 07 Oct 2010    Post subject: Reply with quote
o ryt well i will get some more info up over weekend
PostPosted: 22:44 - 07 Oct 2010    Post subject: Reply with quote
Ok. After a bit of poking around and general Czech bike nerding here's what I think.
I think I can see a second exhaust on the other side of the bike.
I also notice that the opening for the carb shroud is unusually large and finishes at an angle as if it was designed to connect to something else in a continuation of that shape, not just attach to a simple airbox. the cooling vanes are shallow and indistinct.
That could well make the engine a Jawa Model 353 dating from the mid 1960s. 250cc twinport single.
Fairly collectable if it is. If it turns over and has compression, it might be worth keeping an eye out for a rolling chassis. If it's seized solid, you might be able to flog parts off it to collectors. Especially if you polished them up and know exactly what model they are off (Czech alloy doesn't rot like Japanese stuff, it'll be solid enough). The carb shroud in particular is something which often gets lost over the years.
Have a look at the engine number, the first three numbers are usually the model number on both Jawas and CZs.
I think the frame is barely worth bothering with.
paulwhalley
PostPosted: 07:13 - 08 Oct 2010    Post subject: Reply with quote
"I think I can see a second exhaust on the other side of the bike."
yes you can and if the engine is worth something i know where another one is but its missing the cover over the carb
the one i have dose kick over and has compression
PostPosted: 08:39 - 08 Oct 2010    Post subject: Reply with quote
"Worth something" and "collectable" are not necessarily the same thing, although they can be. More research needed. People collect the numbers off the side of trains.
A lot depends on finding someone who wants to collect the thing badly enough.
A fairly tidy one went on ebay, complete and running, for about £400 recently.
It IS worth checking the engine number though. Jawa and CZ were world leaders in trials/scrambles in the period that engine dates from. They made some highly competative machines and their works and homologation special models mostly used standard parts so externally look just like any other engine.
The fact that someone has fitted it to a dirtbike chassis could (and I stress, it's highly unlikely) mean it's a competition engine which would definately be in the "worth something" category.
paulwhalley
PostPosted: 19:19 - 09 Oct 2010    Post subject: Reply with quote
new pics! found some numbers on the frame which next to them say weight ect but numbers hard to make out
The last post was made 15 years, 103 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.44 - MySQL Queries: 16 - Page Size: 86.53 Kb
