Honda NSR 125 Starter motor- HELP!
clewlow690
PostPosted: 23:02 - 06 Oct 2010    Post subject: Honda NSR 125 Starter motor- HELP! Reply with quote
My starter motor has packed in! The battery is holding a 14v charge and theres a clicking noise coming from a gold box thats in a black rubber casing under my tank behind the air box when I press the ignition swich. Also when I press the ignition switch the headlights dim down and return to normal when the switch is released. The starter motor gets warm when the switch is pressed but theres no action from it. I havent checked the solenoid because I dont know where to find it. Please can anybody help me? Help would be much appreciated. Cheers
skatefreak
PostPosted: 12:19 - 07 Oct 2010    Post subject: Reply with quote
Sounds very much like it could be the brushes have warn down/commutatar bars are shorting.
Is the starter even trying/turning a little?
Check out alains NSR tips doc floating around (https://www.geneva-racing.ch/~alains/NSRtips.doc).
Also try picking up the NSR service manual.
The starter is pretty straight forward and easy to service Smile
Best regards
-Jvr
clewlow690
PostPosted: 12:42 - 07 Oct 2010    Post subject: Reply with quote
Nothing at all from the motor itself mate. Just the clicking noise from a gold box between the battery and air box which im presuming is the solenoid? Cheers for the help. Much appreciated
skatefreak
PostPosted: 13:05 - 07 Oct 2010    Post subject: Reply with quote
Okay,
Well the click itself varifies that the starter relay switch is working so we can rule that out for now, you can try applying the battery current directly but chances are the starter needs a little attention.
Its pretty easy to go over,
check out the manual, page 197 +
https://www.nsr125.co.uk/Downloads/Honda_NSR125_Manual.zip
-Jvr
clewlow690
PostPosted: 13:46 - 07 Oct 2010    Post subject: Reply with quote
Thanks for that pal. Will giv it a go at the weekend. Cheers
alains
PostPosted: 19:12 - 09 Oct 2010    Post subject: Reply with quote
look chapter about starter repair
but if you hear a click and no effect, on starter , the battery may be has unsufficient voltage
remember this :
bat fully charger 13.2VDC >>> under 12.8 battery for the dump
charge on the bike at 5500 and more 14.2VDC >>> less than that , ckeck regulation at 14.2 or dump the battery
clewlow690
PostPosted: 19:36 - 10 Oct 2010    Post subject: Reply with quote
Cheers for the reply. I forgot to mention that before it packed in the starter motor was making a loud screeching noise when it was starting the bike. Dont know if this helps to identify the problem any easier?
alains
PostPosted: 00:08 - 11 Oct 2010    Post subject: Reply with quote
no , 99% it's brushes worn & springs tired
The last post was made 15 years, 344 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.44 - MySQL Queries: 13 - Page Size: 55.42 Kb
