| dragstaar |
 dragstaar World Chat Champion
| vmax12 |
 vmax12 Renault 5 Driver
| Mr Hammers |
 Mr Hammers World Chat Champion
 Posted: 12:44 - 07 Oct 2010 Post subject: |
Are you sure it's the forks that are creaking? Could it not be the fairing is rubbing somewhere when the forks are compressed? ____________________ A Guide To Powerbands |
| DrDonnyBrago |
 DrDonnyBrago World Chat Champion
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 16:44 - 07 Oct 2010 Post subject: |
Most likely the brakes creaking.
Could be a hose chaffing in the fairing or through an eye though.
Have a look see of the brake hose(s) & Speedo cable are all in thier guides, and check gromets.
If you have braided hose, its narrower than stock rubber hose, and some guides have grommets that grip the std hose. Put on a braided, the gromet dont grip & the hose chaffs, & being braided steel, wears through the rubber.... grommet pops, and they you get grating noise as braided steel rubs on guide!
More likely accumulated brake dist on caliper float-pins, though, and or in & around the pads.
Wip out the pads, clean, coppa-slip, put'em back.
If that dont cure it, wip the calipers off, pill the calipers off the float-pins, clean, coppa-slip, re-assemble, see if that works.
Another one is the mudguard.... check the mounting bolts... if loose, can twist or shift under braking & give rubbing / grating noises, esp if the brake hose or speedo cable have guides clipped to it to help make it move when the forks compress.
Basically, poke-prod, scratch head, bounce, twist, tug, looking for something a bit wiered or unusual, and a little preventative maintenence, should sort it out. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| mysterious_rider |
 mysterious_rider World Chat Champion
| dragstaar |
| shotgun |
 shotgun Two Stroke Sniffer
 Posted: 18:11 - 07 Oct 2010 Post subject: |
Have you tried spraying some brake cleaner into the floating rivets? When they get gobbed up it causes the discs to squeal & grind sometimes. Make sure you wipe the discs well afterwards.  |
| Pete. |
 Pete. Super Spammer
 Posted: 21:25 - 07 Oct 2010 Post subject: |
Check the headstock bearings and also check the welds around thw headstock for signs of cracking. ____________________ a.k.a 'Geri'
| Ed Case |
 Ed Case World Chat Champion
The last post was made 15 years, 330 days ago. Instead of replying here, would creating a new thread be more useful? |
