Removing bearings
Walloper
PostPosted: 17:58 - 08 Oct 2010    Post subject: Re: Removing bearings Reply with quote
warped one wrote:
I have a leading link style rear suspension on my GT and was wondering how to remove the bearings from the main block that everything attaches too.
Pictures or we won't help you.
Tim..
PostPosted: 21:46 - 08 Oct 2010    Post subject: Reply with quote
Use a press with the aid of spacers, that you've made specially for the job, to get them out.
Or
Use a big hammer and a socket thats about the right size.
Either way, remember to press the bearing out from the outer ring and not the inner one.
www.marshallracing.co.uk
PostPosted: 00:07 - 09 Oct 2010    Post subject: Reply with quote
You mean in the shock linkage?
As said. Prise out the rubber seals with a small screwdriver then either press them out with a hydraulic press or hammer them out with a drift.
You MIGHT be able to put the whole linkage in the oven set to "really fucking hot" and wait for them to fall out. Heating would certainly make them easier to remove in any case.
0ddball
PostPosted: 00:22 - 09 Oct 2010    Post subject: Reply with quote
I've found they usually drift out of the linkage pretty easy even when cold as long as water hasn't got i there.
Kai.Wilson
PostPosted: 08:59 - 09 Oct 2010    Post subject: Reply with quote
And when it comes to putting some in out bearings in the frezzer for 2 hours and use a heat gun where the sit Smile
Kai
The last post was made 16 years, 23 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 48.8 Kb
