chain lube
ollieholt
PostPosted: 13:18 - 09 Oct 2010    Post subject: chain lube Reply with quote
hi all, ive got a scottoiler and its ran out. can i put anything else in it or just the scottoiler stuff thats 9 quid a bottle posted?
im off on a 100 mile round trip and ive no spray lube but ive other things here. ive got mech oil, essentially duck oil, will i be ok to put that in it? it just flings off the chain and doesnt last long but if its in the oiler at least i will have piece of mind that it is being lubricated.
any other suggestions?
Laughing < This? Well this is just a day brightner.
garth
PostPosted: 13:24 - 09 Oct 2010    Post subject: Reply with quote
Meh, I chuck any oil in mine!
Aka Matt
PostPosted: 13:27 - 09 Oct 2010    Post subject: Reply with quote
For a 100 mile trip just scrub some engine oil on the chain with a toothbrush (use hers if available) before you go.
I wouldn't have thought using a different oil (so long as its not too heavy) would cause any problems?
Current bike(s): 2016 Tuono 1100 Factory, 1998 Hornet 600
Previous: 1998 YZF600R Thundercat, 2001 Bandit 600, 2002 GSX-R 600 K2, 2011 Tuono R, 2013 Z1000SX
ollieholt
fair do's i think ill just chuck some mech oil in and turn it right down, its a bit less viscous then scottoil
hellkat
PostPosted: 13:54 - 09 Oct 2010    Post subject: Reply with quote
I do just over a hundred miles in a week travelling to work and back, and if I lubed my chain once a week, my bike would think itself very fortunate indeed.
In fact at the moment all I have is this green can of spray-on chain wax ...? I leave it behind my front wall by the rubbish bin so its somewhere I can easily see and remember to do it ... I do try and remember to do it at the very least after its rained, so the fact that its raining more frequently recently ... means my bike prolly thinks its had a birthday or something.
DynaMight
PostPosted: 14:47 - 09 Oct 2010    Post subject: Reply with quote
Any oil will do the job, the only issue you may encounter will be the viscosity (thinner/thicker) so it may drip quicker or not drip at all.
I dont know how the Scottoiler oil compares to say normal 10w40 engine oil etc
May require trail and error to get it right.
Blackwolf
Burgerfist
PostPosted: 15:22 - 09 Oct 2010    Post subject: Reply with quote
Its been mentioned on here chainsaw oil works quite well?
garyd
PostPosted: 17:11 - 09 Oct 2010    Post subject: Reply with quote
EP90 gear oil
CRF230 all you need
ThoughtContro...
PostPosted: 18:07 - 09 Oct 2010    Post subject: Reply with quote
I seem to recall reading that ATF was a reasonable replacement for scottoil
Other than that engine oil and toothbrush. Wipe excess off or have it fling everywhere.
Prize cunt
doggone
PostPosted: 20:49 - 09 Oct 2010    Post subject: Reply with quote
In theory O ring chains don't even need to be lubed except that it stops corrosion starting which would soon mess them up.
No need to worry about it for a few days.
mr-inteligent
PostPosted: 00:09 - 10 Oct 2010    Post subject: Reply with quote
I know 80W/90 works very well... it seems to be the best consistency for staying on the chain not the back wheel.
normally sold as gear oil
ollieholt
PostPosted: 01:08 - 10 Oct 2010    Post subject: Reply with quote
tried duck oil..... yeh it just all pissed out in about 3 seconds, went and bought some proper scott oil for 8 quid at local dealer, will last about 6 months its a big bottle. ive heard 80/90's works a treat before and i was considering it but it wasnt much more for the proper stuff it was designed to handle so went in that direction, cheers for the advice though. Thumbs Up
Glenben92
PostPosted: 01:39 - 10 Oct 2010    Post subject: Reply with quote
Always use 80/90 Gear Oil, Just rub abit in and drizzle on the sprocket and chain as it spins on the stand. Works a treat Smile It's a really fucking SHIT chain as well, and it STILL doesn't stretch or deform or fuck teeth or anything Smile
57 Huoniao HN125-8 - Smile, 97 Kawasaki GPZ500S - Very Happy
99 Yamaha FZS 600 - Wink
Mod 2 Passed - 01/10/2010
Walloper
PostPosted: 10:13 - 10 Oct 2010    Post subject: Reply with quote
I was fortunate to meet Mr. Scott Oiler who invented the Scotoiler.
I asked him what magical ingredients go into the oil.
He told me an oil company looks after the blend for summer/winter and that the additives prevent corrosion and oxidation and stuff.
Of course he's not going to tell me the recipe. Smile
Engine oil would be near enough for a 100 mile trip and reduce the feed to lowest.
PostPosted: 23:41 - 10 Oct 2010    Post subject: Reply with quote
I've put EP90 in a scotoiler before. No problems. You need to turn it up higher though. I've also put used engine oil through them.
At the end of the day, it's a plastic container with a tube attached and a small needle valve in the bottom. When the engine is on, the valve is sucked open and the oil can run out through it. The flow adjuster alters how far the valve opens
You could put pretty much any liquid in it and providing it doesn't either attack the plastic or make the valve stick open/shut, it'll deliver it to the chain.
SamJL
PostPosted: 01:01 - 11 Oct 2010    Post subject: Reply with quote
I know a lot of people do this, so I tried it!
Worst idea ever! It started to rain, the oil got washed off the chain, and on to my back tyre, made for an interesting ride home!
At least with proper chain lube this doesn't happen!
2009 CBR1000RR
2004 KTM 200SX
2004 KTM 65SX Very Happy
The last post was made 15 years, 362 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 87.77 Kb
