Flat spot in revs... Still!
JackT
PostPosted: 13:46 - 10 Oct 2010    Post subject: Flat spot in revs... Still! Reply with quote
First things first, the bike takes a while to start up, which i think might be related, posibly not. Once its got going she idles fine. Then the real problem kicks in. When i pull the trottle back she gets to around 5000rpm then wont rev any higher with a spluttery sound like shes running low on petrol.
1st gear pretty much doesnt exist when im setting off, and even in 5th i cant rev about 5000. (which usually results in about 30mph)
I've exhausted my knowledge in trying to sort this problem out and this is what i've done so far;
Cleaned carb inc main and pilot jet, made sure float isnt sticking and fuel line is clear,
Replaced air filter and airbox inc box - bard manifold,
Clean tank best i can, cleaned fuel filter in the tank, cleaned the tap out,
Replaced spark plug,
Replaced a broken exhaust gasket,
Replaced CDI unit (the actual unit not the coil).
Can anyone please give me some suggestions of possible problems and solutions as i really need her running for college.
Thanks
Jack
PostPosted: 14:34 - 10 Oct 2010    Post subject: Reply with quote
Firstly....
what bike?
JackT
PostPosted: 14:35 - 10 Oct 2010    Post subject: Reply with quote
oh my bad, its a kinroad cyclone, coulda sworn i put tht lol. Musta deleted it haha
PostPosted: 14:40 - 10 Oct 2010    Post subject: Reply with quote
Ok, what colour is the spark plug.
You say it splutters, do you have a spare key.. put it in the petrol cap and open it when it starts to struggle whilst moving. See if that cures it.
My old GS500 had/still has a petrol problem, it feels like its cutting out...it turned out to be the fuel tap! try using the alternative option on the tap?
Also... anything not connected at the carb end? Maybe an air pipe has come loose?
JackT
PostPosted: 14:43 - 10 Oct 2010    Post subject: Reply with quote
The plug i took out was black, and i tried the key in the cap, wasnt a vacuum problem. Not sure how to cute the black plug problem because i altered the air mix on the carb and that didnt help.
PostPosted: 14:49 - 10 Oct 2010    Post subject: Reply with quote
sounds like its running WAYYY too rich, another symptom on the GS!!
Choke stuck on? Air filter clean? I think its either that or you need to adjust the carb to slow the amount of fuel being passed through.
JackT
PostPosted: 14:52 - 10 Oct 2010    Post subject: Reply with quote
When i cleaned the carb the choke plate seemed fine, movement wa free and no tight spots. And its a brand new air filter. What else would make her run rich?
PostPosted: 14:56 - 10 Oct 2010    Post subject: Reply with quote
Well, aside from a bigger carb jet or choke being forced on (cable could be stuck) I wouldn't know, im sure you can adjust float height in a carb, but im unsure as to whether it will sort the over-fuelling.
tahrey
PostPosted: 19:12 - 11 Oct 2010    Post subject: Reply with quote
Sounds just like what my CG does with the choke left on (and if there's a great remove between it and the kinroad...). It just won't go any higher because the choke is doing exactly what it says on the tin - restricting the air intake.
Unless it's something wierd like valves not opening enough or an obstruction/kink in the airway, it's probably carb adjustments time.
(Does fiddling the choke one way / the other make ANY noticable difference to how it runs, btw? IE if you get it nice and cold, is it harder to start with it off? Runs even worse with it full-on?)
JackT
PostPosted: 22:22 - 11 Oct 2010    Post subject: Reply with quote
choke seems to make no difference at all. Im not sure what ese i can adjust on the carb, done needle hight, idle, air mix. Is there any other adjustments you can suggest to do with air/fuel mix?
Carvel
PostPosted: 22:28 - 11 Oct 2010    Post subject: Reply with quote
Which points to it being stuck on, no?
JackT
PostPosted: 22:34 - 11 Oct 2010    Post subject: Reply with quote
So how would i sort tht, cos the choke plate moves freely when the carbs off the bike
Carvel
PostPosted: 22:39 - 11 Oct 2010    Post subject: Reply with quote
Check the cables moving freely.
JackT
PostPosted: 22:44 - 11 Oct 2010    Post subject: Reply with quote
cables recently new, pulls choke lever fine
hmmmnz
PostPosted: 00:55 - 12 Oct 2010    Post subject: Reply with quote
pull out the air filter and have a test with no air filter in the bike,
if it runs better then she's rich,
if thats the case we'll go from there
the humans are dead
I kick arse for the lord
PostPosted: 09:40 - 12 Oct 2010    Post subject: Reply with quote
I would assume that a black spark plug is either running stupidly rich or burning oil.
I "personally" think its the choke. just disconnect the cable from the carb end.
JackT
PostPosted: 12:08 - 24 Oct 2010    Post subject: Reply with quote
Just an update, pulled the filter out and disconnected the choke cable (with a combination of the 2) but she just sounded like she was gonne suck my leg in but the rev issue didnt change at all.
Odie
PostPosted: 12:48 - 24 Oct 2010    Post subject: Reply with quote
Ok simple question's:
Have you had done / had some-one else do any work on the bike prior to this problem happening.
When did it start happening and had anything happened to the bike (dropped it, cut out for no reason, a mate borrowed it, had some work done etc)?
The reason i ask these questions is 9 times out of 10 its some-thing has happened prior to the current problem that is the cause!
It dont matter that you think its inconsequential, it could of caused it because as i said it normally is!
JackT
PostPosted: 12:55 - 24 Oct 2010    Post subject: Reply with quote
No one else has worked on it, ive been doing it as a project so my hands only.
It just started one day a fair few months ago. (taken a while to do the stuff i know) i thought it was just low on fuel when it first happened lol. But never dropped or used by any one else (apart from previous user but it ran fine when i first got it)
As far as i can think back there wasnt anywork done on her in the period when i got her and the problem started, no crashed or drops or anything.
Odie
PostPosted: 16:27 - 24 Oct 2010    Post subject: Reply with quote
Long shot, its a problem on Honda CX500's, i know its not the same bike but the symptoms are very similar.
If the alternator on the CX500 is on its way out the bike will not rev past 5,000rpm, this is due to the ignitor sensors being part of the alternator and not letting the ignition advance under load.
Change the alternator and it solves the problem because the ignition sensors are changed at the same time as they are part of the alternator.
Another idea, my wife has a Gilera Cougar, some-one changed the rear under guard due to it breaking and didnt refit it correctly, this blocked the intake for the airbox, reducing the amount of air entering the engine, initially we went through everything because the bike would not pull above half throttle, checked cdi, carb, ignition, everything, even removed the air filter and cover, still no change, eventually found out about the flat covering the airbox inlet, put hand on the swinging arm, followed the inner guard up and found a rubber flap, pulled it out and haypresto, the bike was back to its usual self.
As i said these are idea's, it aint going to do any harm to check these out, hope you have a manual.
odie
JackT
PostPosted: 16:33 - 24 Oct 2010    Post subject: Reply with quote
I checked the clearance or the air intake when i first replaced the airbox. But yeah i'll check on the alternator idea. And as for manual's the genious who built this bike didnt make a manual to go with it.
stirlinggaz
PostPosted: 17:19 - 24 Oct 2010    Post subject: Reply with quote
chuck the carb in the bin & fit a mikuni,lol
& theres now a haynes (generic) manual available for these bikes. Whistle
cheers,
GAZ
JackT
PostPosted: 17:22 - 24 Oct 2010    Post subject: Reply with quote
mikuni are made for large engines. Mines only 125 unforunately
stirlinggaz
PostPosted: 17:32 - 24 Oct 2010    Post subject: Reply with quote
mikuni also make carbs for 50-125cc bikes & above. (including pit bikes)
the usual upgrade is the 29mm.
cheers,
GAZ
The last post was made 15 years, 291 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.23 Sec - Server Load: 2.82 - MySQL Queries: 13 - Page Size: 119.94 Kb
