| JackT |
 JackT Two Stroke Sniffer
 Posted: 13:46 - 10 Oct 2010 Post subject: Flat spot in revs... Still! |
First things first, the bike takes a while to start up, which i think might be related, posibly not. Once its got going she idles fine. Then the real problem kicks in. When i pull the trottle back she gets to around 5000rpm then wont rev any higher with a spluttery sound like shes running low on petrol.
1st gear pretty much doesnt exist when im setting off, and even in 5th i cant rev about 5000. (which usually results in about 30mph)
I've exhausted my knowledge in trying to sort this problem out and this is what i've done so far;
Cleaned carb inc main and pilot jet, made sure float isnt sticking and fuel line is clear,
Replaced air filter and airbox inc box - bard manifold,
Clean tank best i can, cleaned fuel filter in the tank, cleaned the tap out,
Replaced spark plug,
Replaced a broken exhaust gasket,
Replaced CDI unit (the actual unit not the coil).
Can anyone please give me some suggestions of possible problems and solutions as i really need her running for college.
Thanks
Jack |
| P.addy |
 P.addy Red Rocket
| JackT |
| P.addy |
 P.addy Red Rocket
| JackT |
| P.addy |
 P.addy Red Rocket
| JackT |
| P.addy |
 P.addy Red Rocket
| tahrey |
 tahrey World Chat Champion
| JackT |
| Carvel |
 Carvel World Chat Champion
| JackT |
| Carvel |
| JackT |
| hmmmnz |
 hmmmnz Super Spammer
| P.addy |
 P.addy Red Rocket
| JackT |
| Odie |
 Odie World Chat Champion
| JackT |
| Odie |
 Posted: 16:27 - 24 Oct 2010 Post subject: |
Long shot, its a problem on Honda CX500's, i know its not the same bike but the symptoms are very similar.
If the alternator on the CX500 is on its way out the bike will not rev past 5,000rpm, this is due to the ignitor sensors being part of the alternator and not letting the ignition advance under load.
Change the alternator and it solves the problem because the ignition sensors are changed at the same time as they are part of the alternator.
Another idea, my wife has a Gilera Cougar, some-one changed the rear under guard due to it breaking and didnt refit it correctly, this blocked the intake for the airbox, reducing the amount of air entering the engine, initially we went through everything because the bike would not pull above half throttle, checked cdi, carb, ignition, everything, even removed the air filter and cover, still no change, eventually found out about the flat covering the airbox inlet, put hand on the swinging arm, followed the inner guard up and found a rubber flap, pulled it out and haypresto, the bike was back to its usual self.
As i said these are idea's, it aint going to do any harm to check these out, hope you have a manual.
odie ____________________ You are so ugly when you were born the doctor said "I?m gonna drop it, if it falls is a rat, if it flies is a bat." |
| JackT |
| stirlinggaz |
 stirlinggaz World Chat Champion
 Posted: 17:19 - 24 Oct 2010 Post subject: |
chuck the carb in the bin & fit a mikuni,lol
& theres now a haynes (generic) manual available for these bikes.
cheers,
GAZ |
| JackT |
| stirlinggaz |
The last post was made 15 years, 292 days ago. Instead of replying here, would creating a new thread be more useful? |
