Logged on stats from active directory
t121anf
PostPosted: 15:53 - 11 Oct 2010    Post subject: Logged on stats from active directory Reply with quote
i need to find something out and i'm a little stuck as to where to start.
the end product will be a plasma screen that displays something like the following info
PCs on Level 1 : 10 of 30 in use
PCs on Level 2 : 2 of 66 in use
and so on.
So our place has an Active Directory, which in turn as computers organised into "Levels"
All i want to know is how many PCs are in each levels (suppose this could be hard coded by me counting them but thats not ideal when the manager just removes stuff or adds stuff) and if they are logged on.
I've tried googling and get various suggestions but it seems to go too far, all i need is x of y.
Can anyone here help?
chrisw
PostPosted: 18:30 - 11 Oct 2010    Post subject: Reply with quote
Do you want switched on or logged in?
If it's just switched on then it would be quite simple to have a VBS pull out the names from AD then run through and ping them or perform a simple WMI query if ICMP is blocked.
If you want logged on then that would require a little more work be easily do-able.
panrider_uk
PostPosted: 18:40 - 11 Oct 2010    Post subject: Reply with quote
If switched on numbers required then a simple script that just polls them all with a ping would suffice.
As part of our login script I log all logins/logouts to a file for each pc (filename is the same as the pc name) with date, username, ip address and various other bits of useful info. I also write to a file where the filename is the username stating date and time. This lets us get useful info quite easily about who's logging into which machine and when. You'd just need a simple script to scan these files to collect the real-time info.
Mark
t121anf
PostPosted: 21:20 - 11 Oct 2010    Post subject: Reply with quote
logged in, it's to help students find unused pc's.
ideally looking for a solution that requires nothing putting onto the pcs as i have no control over them
panrider_uk
PostPosted: 21:43 - 11 Oct 2010    Post subject: Reply with quote
With a small amount of work This could easily be modified to read AD instead of a text file of computers and output the results you want.
Mark
The last post was made 15 years, 328 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.38 - MySQL Queries: 15 - Page Size: 43.6 Kb
