Spray job
timboellis
PostPosted: 19:46 - 12 Oct 2010    Post subject: Spray job Reply with quote
I just spray painted my paniers however not looking shiny i done it in a warm room heated up the paint etc.
but it looks okay , but is there a way i can make it shiney ?
Philious
PostPosted: 19:53 - 12 Oct 2010    Post subject: Re: Spray job Reply with quote
Add several coats of clear laquer Wink
Previously; Honda XR125 - Yamaha DT125r - Aprilia Rs125 - Suzuki GS500e, Currently; Kawasaki ZX6R + ZX10R
Theory : Passed 28/7/09 Module 1: Passed 21/09/09 Module 2: Passed 23/09/09
timboellis
PostPosted: 19:55 - 12 Oct 2010    Post subject: Spray job Reply with quote
THanks for that will pop to the shop the morrow and get some and if it looks good i may even go as fart as painting the whole bike.
SlimRick
PostPosted: 19:58 - 12 Oct 2010    Post subject: Reply with quote
Rubbing compound, t-cut and polish. Thumbs Up
timboellis
PostPosted: 20:02 - 12 Oct 2010    Post subject: Spray job Reply with quote
I have t-cut already not sure if that would work, will try it in a little bit the morrow
SlimRick
PostPosted: 20:06 - 12 Oct 2010    Post subject: Reply with quote
If you've only just sprayed them, you need to leave them a few days for the paint to harden before using t-cut or rubbing compound.
Frost
PostPosted: 20:36 - 12 Oct 2010    Post subject: Reply with quote
T cut or laquer, you must choose only 1 as once you put tcut on or start to handle them the laquer won't go on properly.
Clanger
Stirrer
PostPosted: 20:53 - 12 Oct 2010    Post subject: Reply with quote
When my mate was doing his own spray job, we would both sit for hours rubbing it all down afterwards with fine grade paper, then some sort of polish or wax, then he would re-spray and repeat.
In the end he built up the tank with about 7 fine sprays and the depth of shine was superb. Thumbs Up
lihp
PostPosted: 00:59 - 13 Oct 2010    Post subject: Reply with quote
This is the best way, flatten in down with 2000grit or so, and then respray, do same till you have clear coat over, then flatten that, and respray a few coats, and flatten, polish and wax.
ZRX61
Victor Meldrew
PostPosted: 15:42 - 13 Oct 2010    Post subject: Reply with quote
If you're going to clearcoat them, flatting or rubbing down the colour coat is a complete waste of time.. Rolling Eyes
Frost
PostPosted: 15:50 - 13 Oct 2010    Post subject: Reply with quote
It's worse than that. If you flatten the colour coat then spray on the clear coat it will just run off like water, or peel off like bannana skin when dry. The colour needs to have some roughness to it to allow the clear coat to stick, otherwise it's like spray painting glass.
2000 grit is fine, metal polish is finer, T-Cut is finer still.
When i spray stuff now i use so little colour it's shocking. Use primer and sand primer to get rid of imperfections, once it's perfect a quick coat of colour, let that dry without touching it, then a few coats of clear. There's no need for any more colour than required to cover the area if you're going to be putting a few coats of clear over the top.
ZRX61
Victor Meldrew
PostPosted: 16:09 - 13 Oct 2010    Post subject: Reply with quote
Tip for the best result from T-Crap:
If you have a can of it in the garage, pick it up, carry it to the dustbin & drop in it.
It really is the worse stuff you could put on paint
The last post was made 15 years, 330 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.26 - MySQL Queries: 13 - Page Size: 70.06 Kb
