my bikes turned into a slug
abbey8k
PostPosted: 13:37 - 14 Oct 2010    Post subject: my bikes turned into a slug Reply with quote
hi,
i have a kindroad xt125cc cyclone
and recently the oil pump failed causing the gear crack ect to smash into pieces.
rather than buying all the bits and rebuilding the engine i got an almost new engine from a breakers which had only done 140miles had had come off a HONGDOU GY 125cc - 59plate.
the engine and gearbox was opened up and inspected by my father who is a mechanic and was clean and ticked over very good.
the engine was fitted to the bike with no problem and the now bike fires up and runs.
the only problem is thats theres a lack of power.
* anywhere near 5-7 thousand revs the bike stutters and chuggs.
* its hard to drive up any sort of hill in 3rd gear.
* a top speed of 55mph can only be achieved when travelling down hill for a long distance.
any ideas?
bearing in mind the oil and spark plug as already been changed.
thanks abs,
MaybeGuy
PostPosted: 13:40 - 14 Oct 2010    Post subject: Reply with quote
burn that dirty chinky piece of shit and get something that isnt worth less than a picture of my dick
DrDonnyBrago
PostPosted: 13:41 - 14 Oct 2010    Post subject: Re: my bikes turned into a slug Reply with quote
abbey8k wrote:
hi,
any ideas?
thanks abs,
Did you get carbs with the new engine?
pepperami
PostPosted: 13:54 - 14 Oct 2010    Post subject: Reply with quote
To much air? not enough fuel? possibly you may need to re-jet your carb?
cdi box? is it compatible with your "new" engine?
what about the plug? is it due to be changed/old
Plug cap? HT lead?
these are all things I would look into if I was in your situation.
just my ideas Thumbs Up
abbey8k
PostPosted: 13:59 - 14 Oct 2010    Post subject: Reply with quote
wish i could afford to
abbey8k
PostPosted: 14:00 - 14 Oct 2010    Post subject: Re: my bikes turned into a slug Reply with quote
DonnyBrago wrote:
abbey8k wrote:
hi,
any ideas?
thanks abs,
no i'm using the existing carb
MaybeGuy
PostPosted: 14:03 - 14 Oct 2010    Post subject: Reply with quote
how about a suzuki marauder 125
abbey8k
PostPosted: 14:07 - 14 Oct 2010    Post subject: Reply with quote
Plug cap? HT lead?
not too sure where to look for the air intake. the throttle pin as been adjusted inside of the carb several times in different positions, all giving the same result. + when searching for the cdi unit online the cdi unit is designed to run most chink bikes including the kindroad and hongdou + the plug looks fine
abbey8k
PostPosted: 14:10 - 14 Oct 2010    Post subject: Reply with quote
i'm pritty sure thats what the bike is modelled on but with a honda cg engine
DrDonnyBrago
PostPosted: 14:24 - 14 Oct 2010    Post subject: Reply with quote
He just wants to sell you some heap he got cheap.
It will still be infinitely better than a chinese bike though Wink .
abbey8k
PostPosted: 14:28 - 14 Oct 2010    Post subject: Reply with quote
i'm pritty sure thats what the bike is modelled on but with a honda cg engine[/quote]
It will still be infinitely better than a chinese bike though Wink .[/quote]
sorry mattsprattuk i miss read it
how much would you be talking?
abs
MaybeGuy
PostPosted: 15:13 - 14 Oct 2010    Post subject: Reply with quote
650
have a look and see what they go for on ebay. Its cheap
skatefreak
PostPosted: 18:43 - 14 Oct 2010    Post subject: Reply with quote
let me get this straight,
your using the new engine with the old carb?
I would have thought that you would want to try a carb set for that engine to be fair...
Certainly sounds like a tuning issue to me and if the carb isnt suitable it'll never go right...
Just a thought though...
-Jvr
abbey8k
PostPosted: 12:32 - 15 Oct 2010    Post subject: Reply with quote
mattsprattuk wrote:
650
i havent the funds at the moment but thanks for the offer.
abs
abbey8k
PostPosted: 12:38 - 15 Oct 2010    Post subject: Reply with quote
-Jvr
all the Chinese bike engines are copy's of honda's cg 125 the only differnce between my old one and this one was the condition so there shouldn't a compatibility issue but thanks i will defiantly look into it
thanks Jvr
abs
PostPosted: 12:41 - 15 Oct 2010    Post subject: Reply with quote
thanks Jvr
Every engine is different...you might have the same carb...but it could require proper setting up to this engine.
Not all engines are cg clones..they all have different materials and build quality...they might not even be OHV engines..
The last post was made 15 years, 326 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 92.75 Kb
