| spetom |
 spetom Trackday Trickster
| MinhDinh |
 MinhDinh World Chat Champion
 Posted: 22:41 - 15 Oct 2010 Post subject: |
I have just bought acf 50 for the first time. It smoked away in the morning but I assume it still protects the bike since everyone else only uses it once. ____________________ Hit the G spot.  |
| swiftb |
 swiftb World Chat Champion
| Rob W |
 Rob W World Chat Champion
| L4Isoside |
 L4Isoside World Chat Champion
 Posted: 22:54 - 15 Oct 2010 Post subject: |
It's something I'm now looking at (should have last year but oh well)
I'd like to know of an effective way of getting rust off down pipes am similar areas?
I'm going to be cleaning the bike a lot more often (maybe every time I use it, because I wont be using it that much this year/winter) or at minimum a hose down.
Was also looking at that "all year biker" company but they are not near me
Going to get me some ACF as well. |
| dragstaar |
 dragstaar World Chat Champion
| dragstaar |
| Howling TerrorOutOfOffice |
| tommybhoy |
 tommybhoy Spanner Monkey
| F3NiNjA |
 F3NiNjA L Plate Warrior
| Kal |
 Kal World Chat Champion
| L4Isoside |
| Im-a-Ridah |
 Im-a-Ridah World Chat Champion
| Gone |
 Gone Nearly there...
| Paxovasa |
 Paxovasa World Chat Champion
 Posted: 09:45 - 16 Oct 2010 Post subject: |
I leave mine dirty
I don't know if it works, as I can't see what it is like underneath. But I would like to think it is in pristine condition  ____________________ Suzuki GSF600 K3 (in the fastest colour, black). |
| Gone |
| spetom |
| BorderHooner |
 BorderHooner Could Be A Chat Bot
 Posted: 10:49 - 16 Oct 2010 Post subject: |
Dude - if you want to ride your bike all winter - you need to cover the bike (except brake discs and callipers, seat, pegs, grips, tyres - obviously) in ACF-50 or similar product.
Wash the bike often with warm water and mild soap so you don't wash the oils/silicones/whatever off the bike. Clean the callipers often so they don't crud up - I would do this once a month - especially if salt grit has been spread on the road. It takes 2 minutes to release a calliper - 30 seconds to removed the pads - 2 bolts normally, spray with a can of calliper cleaner and get a tooth brush in there.
If you ride in the salt - wash the bike before you put it away every single time and rinse the callipers off thoroughly turning the wheels and applying and releasing the brake - otherwise you'll have shit brakes in the spring and they'll need stripping and rebuilding.
You need some of these https://www.bellbrush.com/white-nonabrasive-scouring-pads-p-1669.html you can buy them in tescos/asda etc etc - these pads are for taking oxidation off parts such as spokes, nuts, bolt heads, engine casing etc.
You will need tooth brushes and/or non scratch pipe cleaners for hard to reach areas - these are great https://www.tooled-up.com/Product.asp?PID=141373&Referrer=froogle - just watch you don't scratch the bike parts as the bristles are on a metal wire.
If you keep the bike clean, and protected it won't oxidise - if you ride it all week and leave crud on it it will furr up. ____________________ Benelli. Happy as a pig in cacky. |
| spetom |
 Posted: 11:29 - 16 Oct 2010 Post subject: |
I've got a waterjet.
I think that would be the most efficient way to clean and with no solvents.
Is it as simple as just rubbing ACF 50 everywhere? That's what I've been doing to date.
However I have heard of people putting other protective substances on their engines and exhausts which last all winter, maybe 2 applications. Just forget the names.
On another note there is also ACF 50 Corosion Block Grease, never used it:
https://cgi.ebay.co.uk/ACF-50-CORROSION-BLOCK-GREASE-454g-TUB-AND-57g-TUBE-/120630709467?pt=UK_Motorcycle_Parts&hash=item1c16268cdb
What is it's purpose? Does it replace copper crease? So axles, chains, sprockets etc.? |
| BorderHooner |
| Clanger |
 Clanger Stirrer
 Posted: 16:21 - 16 Oct 2010 Post subject: Re: How do you protect/clean your bike against rust? |
| spetom wrote: | ACF 50 on the engine block and exhaust, when the engine starts up it smokes bad |
Yes, this is normal. Then after your ride out, wash the bike down, rinse and re-apply the ACF 50/WD40. It's worked for me for oodles of years...I wouldn't change it.
I would however hope to have the bike inside a shed or garage during the winter months too. Especially if a Suzuki!!
If its outside, try and throw the cover over when it's dried off, less condensation that way.
| spetom wrote: | I've got a waterjet. |
Eek! Be very careful...especially around your wheels, you could dry out your wheel bearings!!! I would get them checked out, if you've been spraying your bike for some time now!!! ____________________ Be who you are and say what you feel, because those who mind don't matter, and those who matter won't mind - Dr. Seuss |
| BorderHooner |
| spetom |
| steppen22 |
 steppen22 World Chat Champion
The last post was made 15 years, 328 days ago. Instead of replying here, would creating a new thread be more useful? |
