Paying kwik fit type places for oil and filter change
mrtEE
PostPosted: 19:04 - 16 Oct 2010    Post subject: Paying kwik fit type places for oil and filter change Reply with quote
Its fairly cheap to get a kwik fit type place to do an oil and filter change on my Xsara VTS, but how likely is that they will actually do it?
Its about £25 with national tyres and autocare which is probably cheaper than buying the oil and filter and doing it myself.
Just worried that they will fail to do the work or knacker it up somehow as most of these places have a bad rep?
WildGoose
White Van Man
PostPosted: 19:37 - 16 Oct 2010    Post subject: Reply with quote
It is cheaper than buying the oil and filter yourself in a lot of cases unfortunately.
For example Honda will do an oil and filter change with castrol for less than I can buy the castrol oil for on its own.
Should be pretty obvious if they have done it, the oil will be transparent on the dipstick straight after a change.
Whether or not they use the oil they say they will is what would worry me.
If you don't buy branded oil, there is no way a garage can beat the cost of doing it yourself.
They may just wipe the filter casing clean rather than change it. Most numpties wouldn't know what an oil filter looks like anyway. If the filter is internal, as it is on quite a few modern cars now, like the Mondeo, then they can get away without changing it quite easily.
mrtEE
PostPosted: 20:12 - 16 Oct 2010    Post subject: Reply with quote
I guess I could ask to watch them do the change, that way I could check they are using decent oil? and etch something into the oil filter.
I tihnk the oil filter is accessible via the engine bay on the VTS so I should be able to check that easily.
ian789
PostPosted: 20:16 - 16 Oct 2010    Post subject: Reply with quote
Surely you'll want the sense of achievement and piece of mind doing it yourself?
JonB
Afraid of Mileage
PostPosted: 20:19 - 16 Oct 2010    Post subject: Reply with quote
Hardly a fucking achievement, for the sake of getting dirty and 25 minutes you might as well part with £25. Like Goose said it's often cheaper than buying the oil yourself.
10 pence Short
PostPosted: 20:21 - 16 Oct 2010    Post subject: Reply with quote
Best idea is to book an appointment and say that you'll be waiting while they do it, only a 15 minute job and you can watch.
I haven't had a cont all day, drinkstable.
ian789
PostPosted: 20:25 - 16 Oct 2010    Post subject: Reply with quote
Calm down mate, it's just I don't trust places like this.
If you do go be ready for them to tell you your tyres are bald and your brakes are fooked.
mrtEE
PostPosted: 20:32 - 16 Oct 2010    Post subject: Reply with quote
Your probably right but tyres and pads can clearly be seen as in good nick so doesnt bother me!
SoND
PostPosted: 21:02 - 16 Oct 2010    Post subject: Reply with quote
Get it done, look at the oil filter after, assess your next move accordingly.
WildGoose
White Van Man
PostPosted: 21:55 - 16 Oct 2010    Post subject: Reply with quote
If you genuinely don't trust these type of places (as I don't). Then why not do it yourself?
Oil filter should be a couple of quid max using google, and can probably find a suitable decent quality 5L of oil for £10.
el_oso
PostPosted: 22:42 - 16 Oct 2010    Post subject: Reply with quote
wikinsons sell about 5L 10W/40 for a tenner
or if you have a costco card they do castrol oil dual 4/5L packs for about £22
Duke 390
Car: Jeep Wrangler 4.0L
Jrod
Page 3 Girl
PostPosted: 22:50 - 16 Oct 2010    Post subject: Reply with quote
I'd never let anyone change my oil.
No one except myself drives, let alone works on my car! I don't even like letting the MOT tester take it round the block for the brake test. Sad
SlimRick
PostPosted: 22:54 - 16 Oct 2010    Post subject: Reply with quote
Never had a tester take my car on a drive - thought they had to use a brake test roller.
Al
PostPosted: 23:04 - 16 Oct 2010    Post subject: Reply with quote
I'd definitely check that they actually do the job.
I had my tracking supposedly adjusted at one of the big tyre and exhaust places and they hadn't even touched it.
My friend works for a service center type place but it wasn't open on Sunday so I took it to Kwik-shaft as it was the only day I was free.
My friend said that I could bring it to him for the re-check if I wanted as it was closer.
The adjusters were seized solid, it took us about half an hour with a blow touch, wd40 and a hammer to free them off. Quick shaft had completely scammed me (well rather the spotty kid who worked there had).
Yamaha FZR400RR 3tj
My Instagram Thingy
Flip
PostPosted: 23:11 - 16 Oct 2010    Post subject: Reply with quote
He does what now? Shocked
WildGoose
White Van Man
PostPosted: 23:36 - 16 Oct 2010    Post subject: Reply with quote
Find a new MOT tester.
A real one would be an idea.
ian789
PostPosted: 23:42 - 16 Oct 2010    Post subject: Reply with quote
https://i5.photobucket.com/albums/y191/waveguide/KwikFit_Fitters.jpg
Jrod
Page 3 Girl
PostPosted: 00:15 - 17 Oct 2010    Post subject: Reply with quote
It has to be tested with a tapley meter as its fitted with a plate diff.
andyscooter
PostPosted: 08:29 - 17 Oct 2010    Post subject: Reply with quote
the trained monkeys at kwikfit changed a set of pads on my dads car once
they put the caliper back together with some sort of air tool and managed to round off the hex patten in all the allen key bolts in every caliper
dodgydog
PostPosted: 08:54 - 17 Oct 2010    Post subject: Reply with quote
Out in the van a year or so ago, a car passed us and we saw the rear wheel wobbling. We followed and eventually managed to stop it.
Young lady driving, she had her brakes done at Kwik Fit the previous day. Every wheel was loose, alloys too.
The left rear just had one wheel nut left on, right front had two nuts, the others had three.
All the alloys were knackered.
Dog
I know that you believe that you understood what you think I said, but I am not sure you realise that what you heard is not exactly what I meant
Phoenix
Twisted Firestarter
PostPosted: 10:25 - 17 Oct 2010    Post subject: Reply with quote
So? They're not going to hold you car to ransom and refuse to let you leave until you pay them to fix it all. If you've got so much sense then you just get them to do the oil change and leave.
I use Kwik Fit/Tyre sales for oil changes because they use Mobil 1 semi and fit a filter for £25, I can't buy the stuff for that, my BMW uses 6litres of oil too. It's easy to watch them do it, it's hardly an engine rebuild, bolt out, filter off, filter on, bolt on.
Incidentally last one I did they did tell me my tyres were all bald...they were right too Wink
PostPosted: 19:12 - 17 Oct 2010    Post subject: Reply with quote
Not if you have permanent 4wd. If you do then the roller brake test will damage the central diff. They should use a Tapley meter and take it for a test drive to do a brake test.
Jrod
Page 3 Girl
PostPosted: 19:56 - 17 Oct 2010    Post subject: Reply with quote
Same applys for any car fitted with a LSD although, unless you tell them it will probably be done on the rollers.
The last post was made 16 years, 11 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.29 - MySQL Queries: 15 - Page Size: 118.76 Kb
