Clutch slip?
SpannerMonkey
PostPosted: 20:24 - 16 Oct 2010    Post subject: Clutch slip? Reply with quote
Okay, so when I test rode the GN250 I'm buying, if I'mfull throttling it picking up some speed, And I change gear quickly and drop the clutch back in quickly, it sorta slips for about a second before gripping. the bitepoint of the clutch seems very high on the lever too.
Would you say adjusting the clutch so that the bite is nearer to the middle would allow more pressure from the springs to grip it all together? or is this a sign of worn friction plates?
Ariel Badger
PostPosted: 20:28 - 16 Oct 2010    Post subject: Reply with quote
If there is free-play of about 5 mm in the lever it is adjusted right. It could be oil related, the cable may be binding a requiring oil or the clutch could be worn.
SpannerMonkey
PostPosted: 20:34 - 16 Oct 2010    Post subject: Reply with quote
no free play in the lever from what I remember
Digit
PostPosted: 20:37 - 16 Oct 2010    Post subject: Reply with quote
That will definitely cause the problem, as will a corroded cable.
Roy.
Happy daze!
SillyMe
Yeah common problem, I have had this a few times when the friction plates wear out, they are fairly cheap and easy to fit how, ever it may just need an oil change 1.3 LT, Semi Synthetic SAE 10-40
Manual here you can download it as it will show you the clutch configuration and sequence of order in which to fit the friction plates. If metal plated in between have no indentations on them change them too.
https://www.scribd.com/doc/5321965/GN250-Manual
Yeah make sure cable is fairly free and easy to full via the lever, and make sure there's a little play in the clutch lever before it compresses.
Once made equal to man, woman becomes his superior.
The man who says "I may be wrong, but -" does not believe there can be any such possibility
Owned and rode: Honda 100H, Honda MBX 125, Kawasaki AR 125, Suzuki RG 125 Pepsi, Honda NSR125 RK, Honda NRS 125 race bike, Suzuki GSXR 400 Bandit, Aprilia RS 125 O2, Honda CG125, Kawasaki KMX 125, Aprilia RS 125 O6, Suzuki XT225 and now Honda XR 400. ( A few scooters and other dead beats in between)
The last post was made 15 years, 327 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 44.74 Kb
