Running issue still
Marcg868
PostPosted: 05:24 - 16 Oct 2010    Post subject: Running issue still Reply with quote
Well i still have problems with my bike running like its on one cylinder, it was only idling with choke. Now the spark plugs have been changed and the carbs cleaned out and fresh petrol put in. It now idles lovely and from there up to 6k rpm it pulls and anything above it seems like its running on one and stutterin. The fuel tank petcock valve doesn't seem to be working also. Any ideas? bike is hyosung gt125r.
JACK, MISS YOU LOADS YOU LEGEND.
hmmmnz
PostPosted: 06:05 - 16 Oct 2010    Post subject: Reply with quote
i gather you have a vacume fuel tap (on - reserve - prime)
and it only runs on prime??
if thats the case then i'd assume the hose that goes from the carbs to the fuel tap has come loose or has a hole/split which in turn is giving you a air leak to the carbs hence making it run funny, and also makes it that it only delivers fuel in the prime position,
have a look at that and report back Very Happy
the humans are dead
I kick arse for the lord
SillyMe1 This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
Marcg868
PostPosted: 08:10 - 16 Oct 2010    Post subject: Reply with quote
Well when i take the tank off it pisses fuel everywhere. Normally it would not leak out of the valve thing the fuel pipes connected to.
Blue_SV650S
PostPosted: 09:13 - 16 Oct 2010    Post subject: Reply with quote
+1 for having a look at the air filter.
Marcg868
PostPosted: 11:11 - 16 Oct 2010    Post subject: Reply with quote
Air filter is one of them paper ones and it has some light oil on it. Its never been changed to be honest. Done 17,800. Looks clean.
Blue_SV650S
PostPosted: 11:53 - 16 Oct 2010    Post subject: Reply with quote
Take it out briefly and see if it makes a difference ...
PostPosted: 12:34 - 16 Oct 2010    Post subject: Reply with quote
I'd try the air filter also.
When was it last serviced either way... mine was a piece of crap until it was actually fully serviced.
Marcg868
PostPosted: 18:49 - 16 Oct 2010    Post subject: Reply with quote
What run it without the air filter for a short distance?
And it was last serviced roughly 3,000 miles ago in march.
PostPosted: 23:03 - 16 Oct 2010    Post subject: Reply with quote
Yea take the filter out and run it as is.
skatefreak
PostPosted: 09:52 - 17 Oct 2010    Post subject: Reply with quote
Just a test run mind you to see if it makes a difference,
dont go galavanting round scotland or anything heh.
-Jvr
Marcg868
PostPosted: 17:01 - 17 Oct 2010    Post subject: Reply with quote
Had a ride today and it's idling lovely and sounds fine. Cleaned the air filter as it's a bmc one similar to a k&n. It now feels like it's bogging down throughtout the rev range,like the engine is being flooded with fuel. Fuel lines are all intact. Just the petcock is always set to prime. Fuel floods out when I take the tank off.
The last post was made 15 years, 339 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.29 - MySQL Queries: 13 - Page Size: 75.72 Kb
