bought myself an arc welder
-Ali-
PostPosted: 19:15 - 17 Oct 2010    Post subject: bought myself an arc welder Reply with quote
the only problem is it needs a 30amp spar to run off, anyone know of any household sockets or am i going to have something installed?
seantobin43
PostPosted: 19:16 - 17 Oct 2010    Post subject: Reply with quote
where did you get it
SEAN TOBIN Very Happy
-Ali-
PostPosted: 19:21 - 17 Oct 2010    Post subject: Reply with quote
rob yarrr wrote:
haha from aldi ?
i got one aswell and stuck a normal house plug on it,will get round to using eventually,wish my mum would stfu about it blowing the whole electric system in the house
Aldi indeed, thought for £30 it would be worth a punt.
Serendipity
PostPosted: 19:27 - 17 Oct 2010    Post subject: Reply with quote
Same here and the same question has occurred to me.
Taking a feed from the circuit that supplies an electric oven would be meaty enough, but welding in the kitchen may not go down well with any significant others you may share the house with. Wink
I'm hoping the massive armoured cable running to my garage is on a 30amp spur. There's an electrician at the end of the cul-de-sac so I may get his opinion before I set fire to the junction box.
2007 CBF1000 & 2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation
colin1
Captain Safety
PostPosted: 21:11 - 17 Oct 2010    Post subject: Reply with quote
Smile I was thinking about buying one of these, glad I didnt now Smile
EDIT:
Having said that, I've got an electric cooker socket in the kitchen, and a bit of googling says they tend to be rated at 30amps.
Dazbo666
PostPosted: 21:19 - 17 Oct 2010    Post subject: Reply with quote
There's a similar setup available from Screwfix at the moment (but ~£100), which is actually suppied with a 13 amp plug.
Having said that, I'm sure we have the 30amp connection that would normally feed an electric cooker (which we've never used)
... in fact I'm quite tempted to get a MIG rather than an arc welder - but possibly hire one first to try them out
Word of the day : DILLIGAF
Cigaro
PostPosted: 21:52 - 17 Oct 2010    Post subject: Reply with quote
What size welder is it?
Most hobby welders will pull 15A max, the smaller ones can happily run off a 13A plug. Worst that will happen is that you will blow the fuse in the plug.
Must be a big welder to need 30 amps.
pepperami
PostPosted: 22:34 - 17 Oct 2010    Post subject: Reply with quote
CHR15 wrote:
mig's easier if your a novice.
once you've got one, you wont know how you managed without it.
You`re right, it is easier if you`re a novice.. and I am!
And I dont know how I managed without it, it has already saved my center stand on the CG and patched up a hole in a mates exhaust.
He was so happy, he bought me half a bottle of Scotch Smile
I`ve tried/done arc welding and it can be a real bugger to get the hang of Crying or Very sad
you can buy gasless mig welders and that`s what i`ve got.
I`ve found that it`s just that little bit easier to weld thinner metal with the mig.
mind you, my welding still looks like bird droppings or that someone with a heavy cold has sneezed on it Laughing
Dazbo666
PostPosted: 22:56 - 17 Oct 2010    Post subject: Reply with quote
May main plans for justifying getting a MIG welder is that I'm in the process of replacing the swiss cheese allen bolts on the Bandit, and already rounded a number of them (so it'll be much easier to replace them when I can weld a hex nut to the tops of them).
I also have plans to deal with another known problem on the Bandit, by replacing the corroded part of the exhaust collector box...
it's 3 or 4 days and ~£70 plus postage to get Banditmania or LMSpares to do it
or ~£160-£200 for a new set of downpipes
or ~£100 plus accessories, and a BIIIG sense of achievement to do it myself Thumbs Up Wink
Dazbo666
PostPosted: 23:08 - 17 Oct 2010    Post subject: Reply with quote
CHR15 wrote:
...you would be replacing that with stainless, which if your doing it properly, would want stainless wire......
Ooh, common sense of course, but I hadn't thought of that actually - thanks for the info Wink
...and as for "assessment pieces", are you doing a welding course??
NIIICE eye candy though Thumbs Up
Ariel Badger
PostPosted: 23:52 - 17 Oct 2010    Post subject: Reply with quote
also, have some whore.
6mm arc, assessment piece
https://i939.photobucket.com/albums/ad233/chris-bracey/random/IMG_3472Medium.jpg
1mm gas assessment piece
https://i939.photobucket.com/albums/ad233/chris-bracey/random/IMG_3473Medium.jpg
Nice root run on the fillet but where are the two cap runs?
The last post was made 15 years, 309 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 82.31 Kb
