| dan3411 |
 dan3411 Renault 5 Driver
| SillyMe |
 SillyMe Trackday Trickster
 Posted: 19:18 - 18 Oct 2010 Post subject: |
Yeah sounds about right for 1.5K.
Iv'e got a 400, done nearly 1000 miles and had to adjust the chain twice.
Use good penetrating chain loob.
| Quote: | When chain tension is properly set, it should be able to move up and down between approximately .75 and 1 inch at its loosest point.
So find the tight spo tin the chain by rolling the bike then role it again till it gets slack then set.
https://motorcycles.about.com/od/motorcyclemaintenanc1/ss/Chain_Maint_7.htm ____________________ Once made equal to man, woman becomes his superior.
The man who says "I may be wrong, but -" does not believe there can be any such possibility
Owned and rode: Honda 100H, Honda MBX 125, Kawasaki AR 125, Suzuki RG 125 Pepsi, Honda NSR125 RK, Honda NRS 125 race bike, Suzuki GSXR 400 Bandit, Aprilia RS 125 O2, Honda CG125, Kawasaki KMX 125, Aprilia RS 125 O6, Suzuki XT225 and now Honda XR 400. ( A few scooters and other dead beats in between) |
| iooi |
 iooi Super Spammer
 Posted: 19:43 - 18 Oct 2010 Post subject: |
Its not a case of what it looks like.....
If you spin the wheel (engine off) does the chain have a constant sag, or does it jump around (tight spots)
Brand new chain on my "V" and its done over 1K and still does not need adjusting. ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| dan3411 |
| Howling TerrorOutOfOffice |
 Howling TerrorOutOfOffice Super Spammer
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 20:09 - 18 Oct 2010 Post subject: |
I always worked on the principle that the brakes, tyres & chain were a weekly 'check' item..... irrespective of mileage, and 500 miles a week would be on the high-side, so no that isn't unusual... maybe unnecessary in these days of heavy duty sealed ring chains, but still a worthy precaution.
Worth noting that there are more moving parts in the average drive chain than in the rest of the bike put together, so I reckon it deserves a little attention, even if its only a wiggle to check the tension & a dousing of lube.
From symptoms though, it shouldn't slacken off that much, that quick. But I believe that the Bandit is a bit of an awkward one to tension properly becouse of the pivot possition, it needs to be checked with the suspension unloaded... sure some-one will correct me... and its made difficult by having only a side-stand.
(using a paddock-stand, on rear wheel spindle would support the swing-arm so leave the weight still on the back suspension)
Possible that its a crap chain stuck on by some-one that disn't see the point in an expensive one for a few sunny sunday miles, or it could just be on its last legs, or it could be you haven't 'quite' got the knack of tensioning it properly, or combination of all three.
Haynes Manual: check the exact procedure.
Appropriate stand: to make it easy
New C&S kit for when it does 'go'
Decent Chain Lube
DO carry on checking weekly, but hopefully you shouldn't have to ACTUALLY adjust it every time, just give it a squirt of lube, especially in the winter crud. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| doggone |
 doggone World Chat Champion
| Bikeless |
 Bikeless World Chat Champion
| doggone |
 Posted: 20:22 - 18 Oct 2010 Post subject: |
Since getting my verniers i've become abit anal about chain slack.
The 250 thumper is a 3 weekly adjustment ritual...Damm that thing loves new chains, probably due to wringing its neck and pillion duties. ____________________ Diabolical homemade music Bandcamp and Soundcloud
The Harry Turner Project |
| N cee thirty |
 N cee thirty Banned
 Posted: 20:43 - 18 Oct 2010 Post subject: |
adjusted my chain twice in 3k miles and its like brand new
if its not dragging on the floor its fine
this is a cg though  ____________________ '00 Aprilia RS50 > '92 Honda CG > '99 Yamaha Fazer > '91 Yamaha RXS > '79 Suzuki X5 > 01' Honda Cg > 07' Honda Cg > 82' Kawasaki Z200 > suzuki gsxr 400 gk73a > honda vfr 400 NC30 Mod 2 Passed 09/06/2011
Jewlio Iglesias wrote: I actually did vote BNP once |
| SillyMe |
 Posted: 20:49 - 18 Oct 2010 Post subject: |
| CHR15 wrote: | | Quote: | Yeah sounds about right for 1.5K. |
are you just deliberately here to cause shit and give bad advice??
i did nearly 1400 miles round France mostly 2 up with a few wheelie sessions and didn't adjust my chain once.
my current chain is on about 3.5k and i think ive adjusted it about 3 times. |
As other posts have speculated you have no idea how old the chain is, or what the quality the chain is. Read here for lots of different views before you accuse people of talking shit. People here have differing views too, so never judge others by your own standards and please refrain from flippant frivolous remarks of an offensive nature.
https://www.gixxer.com/forums/showthread.php?t=131962 ____________________ Once made equal to man, woman becomes his superior.
| neatbik |
 neatbik World Chat Champion
| Zimbo |
 Zimbo World Chat Champion
| 0l0dom0l0 |
 0l0dom0l0 World Chat Champion
| BanditsHigh |
 BanditsHigh Worse than a woman
| dan3411 |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 23:07 - 18 Oct 2010 Post subject: |
| BanditsHigh wrote: | | Teflon-Mike wrote: | ... it needs to be checked with the suspension unloaded... sure some-one will correct me... and its made difficult by having only a side-stand.
(using a paddock-stand, on rear wheel spindle would support the swing-arm so leave the weight still on the back suspension) |
How to confuse the hell out of someone ... first you state it's to be checked without any load on the suspension then you say to use a paddock stand to load the suspension while checking |
Read that again. I said a paddock stand WOULDN'T unload the suspension. Nothing more.
| BanditsHigh wrote: | A chain should always be checked with the weight of the bike loading the suspension, i.e. either on the side stand or on a paddock stand ... if you adjust a chain while the bike is on the centre stand it will be adjusted too tightly and will place undue stress on not only the chain but the sprocket bearing and output shaft bearing as well |
Not always. On bikes with centre stands, the suspension is normally at full droop, rear wheel off the ground when on the stand, and that is how it would be sat to do any maintenence, and allow the wheel to be turned to check sproket & wheel alignment etc, hence how 'conventionally' its presumed the bike will be when you check the chain tension.
But it depends on the swing-arm pivot to sprocket centre geometry, whether the chain goes loose or tight, as it goes through its travel. Most bikes have the sproket just ahead and above the spindle, so max tension will be on the chain when the wheel axle, swing arm spindle and sproket shaft centre are all in line. That MAY be when the bike is unloaded and supported on its wheels, but more often not.
However, full droop is a natural datum, and the amount of slack needed from there to max tension is a known quantity and can easily be measured to quote in the hand-book, where setting at an unloaded ride height, is not, as it can be varied by any maner of things from the amount of fuel in the tank, to a rack on the back, preload on teh springs etc etc.
Either way, the full weight of teh bike ISN'T on the suspension when a bikes on its side stand, and I wouldn't recomend ANY-ONE start lifting & spinning or trying to remove wheels with a bike propped ONLY on its side stand...
However, I know the Bandits didn't have a centre stand as standard (at least early ones) and I also had a feeling that due to the sproket / swing-arm spindle possitioning, that it is one of the anomolies where there IS a specific procedure for tensioning the chain, & suggested he find it & follow it, using a 'stand' that best suited that....... ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| stinkwheel |
 Posted: 23:11 - 18 Oct 2010 Post subject: |
I don't like the sound of that and nor do you or you wouldn't have posted about it.
In fact, it sounds almost identical to the experience we had with my girlfriends CB500. It also came from an owner who was doing hundreds of miles a year.
We kept having to adjust the chain every 3-400 miles and were just winding it further and further back. I eventually got too concerned about this and ordered a new chain and sprocket kit for it.
Got the old one off and it looked like it was a "standard" grade, non o-ring, no-name chain (I'm happy enough with a non o-ring but it has to be heavy duty on a 500). Exactly the sort you find going cheap on tabletop stalls at autojumbles which, knowing the previous owner as I do, is exactly the sort of thing he'd pick up.
Put the Honda one on and it's needed to be adjusted ONCE in the last 2,000+ miles and even then, not by much.
Get it changed if for no other reason than piece of mind. At the very best, a broken chain will leave you stranded in the middle of nowhere. At the worst, it'll smash up your engine, cut a few toes off or cause a crash. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Vincent |
 Vincent Banned
| neil. |
 neil. World Chat Champion
| chris-red |
| Walloper |
 Walloper Super Spammer
 Posted: 09:57 - 19 Oct 2010 Post subject: |
I love these threads with hardly any variable conditions involved.
Get a manual with the correct OEM Bike/Chain.
Adjust the chain as per those instructions.
Excessive wear you describe will most probably be due to cheap components, over tensioning or racing everywhere.
Worn chains will probably be accompanied by worn sprocket teeth. (If fitted as a matched set.)
New chain on old sprocket will aggrivate any wear on the old parts and cause unwanted point contact on new chain parts (Rollers/Side plates).
Another reason for chain 'stretch' is the rear axle bolt is not clamping the wheel tight. So the chain doesn't stretch as far as one's imagination  ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| nowhere.elysium |
 nowhere.elysium The Pork Lord
 Posted: 10:22 - 19 Oct 2010 Post subject: |
we're pretty comfortable in the assertion that you make contentious comments, with a variable grounding in the truth. Failing that, you've got a talent for not completely reading the post, which tends to make for an interesting (thought utterly useless) contribution.
Also, gixxer.com is hardly known as a forum for those of the highest technical acumen*, so citing it to back up your argument is guaranteed to make you look a fool.
*Anyone remember sti2gsxr? ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
The last post was made 16 years, 10 days ago. Instead of replying here, would creating a new thread be more useful? |
