Chain Stretching Problems
dan3411
PostPosted: 19:07 - 18 Oct 2010    Post subject: Chain Stretching Problems Reply with quote
Just bought a Bandit ,well had it about 3 weeks and i have had to adjust the chain on it almost weekly is this normal? Well obviously it is not... but between it's last 2 MOTs it has only done like 1K miles and in these pasts 3 weeks i have clocks up about 1.5K.
I'll get some pics up of the chain, it looks ok-ish.
I adjust it to about 1.5 inches of play upwards at the tightest point... not that i could really find it but now it has about 2.5ish inches of play and it makes riding at low speeds a real pain and i have to nurse downshifts a bit more to save the transmission.
Are these characteristics of a crappy chain?
Suzuki Bandit 600N
SillyMe
PostPosted: 19:18 - 18 Oct 2010    Post subject: Reply with quote
Yeah sounds about right for 1.5K.
Iv'e got a 400, done nearly 1000 miles and had to adjust the chain twice.
Use good penetrating chain loob.
When chain tension is properly set, it should be able to move up and down between approximately .75 and 1 inch at its loosest point.
So find the tight spo tin the chain by rolling the bike then role it again till it gets slack then set.
https://motorcycles.about.com/od/motorcyclemaintenanc1/ss/Chain_Maint_7.htm
Once made equal to man, woman becomes his superior.
The man who says "I may be wrong, but -" does not believe there can be any such possibility
Owned and rode: Honda 100H, Honda MBX 125, Kawasaki AR 125, Suzuki RG 125 Pepsi, Honda NSR125 RK, Honda NRS 125 race bike, Suzuki GSXR 400 Bandit, Aprilia RS 125 O2, Honda CG125, Kawasaki KMX 125, Aprilia RS 125 O6, Suzuki XT225 and now Honda XR 400. ( A few scooters and other dead beats in between)
iooi
PostPosted: 19:43 - 18 Oct 2010    Post subject: Reply with quote
Its not a case of what it looks like.....
If you spin the wheel (engine off) does the chain have a constant sag, or does it jump around (tight spots)
Brand new chain on my "V" and its done over 1K and still does not need adjusting.
dan3411
PostPosted: 19:44 - 18 Oct 2010    Post subject: Reply with quote
So what is the correct free play, haynes says 25mm to 35 mm and i ok to go down to 20mm freeplay? I don't 2 up if that makes any difference?
Suzuki Bandit 600N
PostPosted: 20:08 - 18 Oct 2010    Post subject: Reply with quote
How tight are your tolerances Chris?
5mm on my 525 HV
Teflon-Mike
tl;dr
PostPosted: 20:09 - 18 Oct 2010    Post subject: Reply with quote
I always worked on the principle that the brakes, tyres & chain were a weekly 'check' item..... irrespective of mileage, and 500 miles a week would be on the high-side, so no that isn't unusual... maybe unnecessary in these days of heavy duty sealed ring chains, but still a worthy precaution.
Worth noting that there are more moving parts in the average drive chain than in the rest of the bike put together, so I reckon it deserves a little attention, even if its only a wiggle to check the tension & a dousing of lube.
From symptoms though, it shouldn't slacken off that much, that quick. But I believe that the Bandit is a bit of an awkward one to tension properly becouse of the pivot possition, it needs to be checked with the suspension unloaded... sure some-one will correct me... and its made difficult by having only a side-stand.
(using a paddock-stand, on rear wheel spindle would support the swing-arm so leave the weight still on the back suspension)
Possible that its a crap chain stuck on by some-one that disn't see the point in an expensive one for a few sunny sunday miles, or it could just be on its last legs, or it could be you haven't 'quite' got the knack of tensioning it properly, or combination of all three.
Haynes Manual: check the exact procedure.
Appropriate stand: to make it easy
New C&S kit for when it does 'go'
Decent Chain Lube
DO carry on checking weekly, but hopefully you shouldn't have to ACTUALLY adjust it every time, just give it a squirt of lube, especially in the winter crud.
doggone
PostPosted: 20:10 - 18 Oct 2010    Post subject: Reply with quote
I wonder if the previous owner has put a cheap crappy one on because he knew it was going.
Bikeless
PostPosted: 20:16 - 18 Oct 2010    Post subject: Reply with quote
Constantly adjusted my chain on my old 400,i reckon it was a DID copy as it was crap,bought it legit from M+P aswell,whereas the blade only needed doing once every 2000 miles or so,IIRC,with loads more power.
doggone
PostPosted: 20:18 - 18 Oct 2010    Post subject: Reply with quote
Sensible thing is get new quality chain and sprockets and have no wurries for a couple of years.
If the thing gives out at high speed you could do a lot of damage to the surrounding bits - and possibly your leg too.
PostPosted: 20:22 - 18 Oct 2010    Post subject: Reply with quote
Since getting my verniers i've become abit anal about chain slack. Embarassed
The 250 thumper is a 3 weekly adjustment ritual...Damm that thing loves new chains, probably due to wringing its neck and pillion duties.
SillyMe
PostPosted: 20:49 - 18 Oct 2010    Post subject: Reply with quote
are you just deliberately here to cause shit and give bad advice??
i did nearly 1400 miles round France mostly 2 up with a few wheelie sessions and didn't adjust my chain once.
my current chain is on about 3.5k and i think ive adjusted it about 3 times.
As other posts have speculated you have no idea how old the chain is, or what the quality the chain is. Read here for lots of different views before you accuse people of talking shit. People here have differing views too, so never judge others by your own standards and please refrain from flippant frivolous remarks of an offensive nature.
https://www.gixxer.com/forums/showthread.php?t=131962
neatbik
PostPosted: 20:57 - 18 Oct 2010    Post subject: Reply with quote
It does sound to me like either the chain is knackered, or just a bad quality one.
Years ago i put a cheap one on my RS125 and that needed almost constant adjustment.
Either way it sounds like you would benefit from a new one.
DID x or o ring is the way to go.
Another thing, what condition are your sprockets in?
Zimbo
PostPosted: 21:09 - 18 Oct 2010    Post subject: Reply with quote
Chains tend to need adjusting more often as they get worn,
To check the degree of wear on your chain, pinch the chain between your thumb and finger right at the back of the rear sprocket and try to pull the chain back directly away from the sprocket. Chains without wear won't move away from the sprocket at all as the pins and bushes are tight, a worn chain will move away fro the sprocket enough to expose most of a tooth due to wear on the pins.
0l0dom0l0
PostPosted: 21:40 - 18 Oct 2010    Post subject: Reply with quote
The Iris chain i had on my gpr 50 was awful! It needed adjusting every few hundrew miles, and that was a 50cc!! I can't imagine what they would be like on anything that actually had some power!
although as you say, its a did chain which are generally very good quality. not really sure what to suggest, just make sure it adjusted regularly.
your changin gear really aggressivly or anything are you?
BanditsHigh
Worse than a woman
PostPosted: 22:08 - 18 Oct 2010    Post subject: Reply with quote
Teflon-Mike wrote:
... it needs to be checked with the suspension unloaded... sure some-one will correct me... and its made difficult by having only a side-stand.
How to confuse the hell out of someone ... first you state it's to be checked without any load on the suspension then you say to use a paddock stand to load the suspension while checking Confused
A chain should always be checked with the weight of the bike loading the suspension, i.e. either on the side stand or on a paddock stand ... if you adjust a chain while the bike is on the centre stand it will be adjusted too tightly and will place undue stress on not only the chain but the sprocket bearing and output shaft bearing as well Thumbs Up
dan3411
PostPosted: 22:39 - 18 Oct 2010    Post subject: Reply with quote
Part of me hopes it is human error, however i am using a paddock stand.. and following the steps in the manual.
Will be getting these end of the month;
https://bikespeeduk.com/epages/steer2916.sf/en_GB/?ObjectPath=/Shops/steer2916/Products/3532VX
Only trouble is I have never changed a chain myself, the procedure it's looks very simple but like mosts things we shall see.
Suzuki Bandit 600N
Teflon-Mike
tl;dr
PostPosted: 23:07 - 18 Oct 2010    Post subject: Reply with quote
Read that again. I said a paddock stand WOULDN'T unload the suspension. Nothing more.
Not always. On bikes with centre stands, the suspension is normally at full droop, rear wheel off the ground when on the stand, and that is how it would be sat to do any maintenence, and allow the wheel to be turned to check sproket & wheel alignment etc, hence how 'conventionally' its presumed the bike will be when you check the chain tension.
But it depends on the swing-arm pivot to sprocket centre geometry, whether the chain goes loose or tight, as it goes through its travel. Most bikes have the sproket just ahead and above the spindle, so max tension will be on the chain when the wheel axle, swing arm spindle and sproket shaft centre are all in line. That MAY be when the bike is unloaded and supported on its wheels, but more often not.
However, full droop is a natural datum, and the amount of slack needed from there to max tension is a known quantity and can easily be measured to quote in the hand-book, where setting at an unloaded ride height, is not, as it can be varied by any maner of things from the amount of fuel in the tank, to a rack on the back, preload on teh springs etc etc.
Either way, the full weight of teh bike ISN'T on the suspension when a bikes on its side stand, and I wouldn't recomend ANY-ONE start lifting & spinning or trying to remove wheels with a bike propped ONLY on its side stand...
However, I know the Bandits didn't have a centre stand as standard (at least early ones) and I also had a feeling that due to the sproket / swing-arm spindle possitioning, that it is one of the anomolies where there IS a specific procedure for tensioning the chain, & suggested he find it & follow it, using a 'stand' that best suited that.......
PostPosted: 23:11 - 18 Oct 2010    Post subject: Reply with quote
I don't like the sound of that and nor do you or you wouldn't have posted about it.
In fact, it sounds almost identical to the experience we had with my girlfriends CB500. It also came from an owner who was doing hundreds of miles a year.
We kept having to adjust the chain every 3-400 miles and were just winding it further and further back. I eventually got too concerned about this and ordered a new chain and sprocket kit for it.
Got the old one off and it looked like it was a "standard" grade, non o-ring, no-name chain (I'm happy enough with a non o-ring but it has to be heavy duty on a 500). Exactly the sort you find going cheap on tabletop stalls at autojumbles which, knowing the previous owner as I do, is exactly the sort of thing he'd pick up.
Put the Honda one on and it's needed to be adjusted ONCE in the last 2,000+ miles and even then, not by much.
Get it changed if for no other reason than piece of mind. At the very best, a broken chain will leave you stranded in the middle of nowhere. At the worst, it'll smash up your engine, cut a few toes off or cause a crash.
neil.
PostPosted: 06:47 - 19 Oct 2010    Post subject: Reply with quote
+1 Do this to be sure if the chain is worn out.
To add my Penny Coin Penny Coin , I don't think I've adjusted my DID O-ring chain in over 4'000 miles (it'll be nearly 10'000 miles old now and I've adjusted it once or twice throughout its life) but I use a Loobman chain oiler filled with engine oil which I give a squeeze of each day and clean it with paraffin once a week (which works out to be every 300 miles).
PostPosted: 09:36 - 19 Oct 2010    Post subject: Reply with quote
Yep I'd say so, I do my TDM once every 2 months (2k miles). I'd suggest it is on it's way out. I'd get a new one.
I don't care what anyone says having to adjust a chain every 500 miles is not normal.
Walloper
PostPosted: 09:57 - 19 Oct 2010    Post subject: Reply with quote
I love these threads with hardly any variable conditions involved.
Get a manual with the correct OEM Bike/Chain.
Adjust the chain as per those instructions.
Excessive wear you describe will most probably be due to cheap components, over tensioning or racing everywhere.
Worn chains will probably be accompanied by worn sprocket teeth. (If fitted as a matched set.)
New chain on old sprocket will aggrivate any wear on the old parts and cause unwanted point contact on new chain parts (Rollers/Side plates).
Another reason for chain 'stretch' is the rear axle bolt is not clamping the wheel tight. So the chain doesn't stretch as far as one's imagination Embarassed
nowhere.elysium
The Pork Lord
PostPosted: 10:22 - 19 Oct 2010    Post subject: Reply with quote
we're pretty comfortable in the assertion that you make contentious comments, with a variable grounding in the truth. Failing that, you've got a talent for not completely reading the post, which tends to make for an interesting (thought utterly useless) contribution.
Also, gixxer.com is hardly known as a forum for those of the highest technical acumen*, so citing it to back up your argument is guaranteed to make you look a fool.
*Anyone remember sti2gsxr?
The last post was made 16 years, 10 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 139.15 Kb
