Hi! Looking for a Roag Legal, 120/100-18 Nobbly rear tyre?
SillyMe
PostPosted: 17:10 - 19 Oct 2010    Post subject: Hi! Looking for a Roag Legal, 120/100-18 Nobbly rear tyre? Reply with quote
Honda XR400.
Everywhere I look they don't stipulate weather or not they are road legal or not.
Once made equal to man, woman becomes his superior.
The man who says "I may be wrong, but -" does not believe there can be any such possibility
Owned and rode: Honda 100H, Honda MBX 125, Kawasaki AR 125, Suzuki RG 125 Pepsi, Honda NSR125 RK, Honda NRS 125 race bike, Suzuki GSXR 400 Bandit, Aprilia RS 125 O2, Honda CG125, Kawasaki KMX 125, Aprilia RS 125 O6, Suzuki XT225 and now Honda XR 400. ( A few scooters and other dead beats in between)
PostPosted: 17:18 - 19 Oct 2010    Post subject: Re: Hi! Looking for a Roag Legal, 120/100-18 Nobbly rear tyr Reply with quote
What do you want to use it for?
'Knobbly' covers a wide range of tyres.
Why do you want it to be road legal, too?
(Ie for MOT, because you're a stickler to road legality, event conditions, etc?)
Oh and I wouldn't get too het-up on having exactly the right size.
Ie, I've had 140 to 100 width dirt tyres on the same rim and been fine.
SillyMe
PostPosted: 18:24 - 19 Oct 2010    Post subject: Reply with quote
I Like the nobbly's and they have to be road legal because I use my bike on the road.
I am looking for a road legal 120/100-18 or better still 130 or 140/100-18. The wider the better.
Cheers!
PostPosted: 18:34 - 19 Oct 2010    Post subject: Re: Hi! Looking for a Roag Legal, 120/100-18 Nobbly rear tyr Reply with quote
You need to answer this question before you can get a useful answer.
Is it just for road use? Or do you want to be using it off-road and if so, what kind of off-road use?
Why do you want a wider tyre?
Do you want a wide knobbly tyre just for looks Confused.
SillyMe
PostPosted: 18:44 - 19 Oct 2010    Post subject: Reply with quote
Yes wider tyre just for road use, I currently have a 110/100-18.
Check this road legal nobbly I have now, I just want a wider one.
https://img709.imageshack.us/img709/8660/dsc00146ko.jpg
PostPosted: 19:02 - 19 Oct 2010    Post subject: Reply with quote
The problem here is that, frankly, it's a rather silly choice I'm afraid.
You're choosing a tyre that doesn't work well on the road and works less well in most winter conditions.
When it's just for road use, the wider tyre will probably make it handle even worse on the road - off road things work rather differently.
The tyre will wear out quicker to some degree - though not wear out of legal tread, just become even worse as far as grip and feel goes.
However, still, I suggest you try a Pireili mt21.
They have the 'knobbly' look you are after, but are just about acceptable road tyres. I've done plenty of road work on them, but only generally because either I was riding too or from off-road, or for a short trip because it wasn't worth swapping tyres/wheels and I wanted to pop to the shops.
If the bike is designed for a 110, it may be quite a distortion to get a 140 on; as I say, for road use this is more of an issue.
Personally, I'd suggest not being a tart and get some proper road tyres in the proper sizes for road use Wink.
SillyMe
PostPosted: 19:10 - 19 Oct 2010    Post subject: Reply with quote
Cheers for that, I will have a look at those Pireili mt21.
garyd
PostPosted: 22:35 - 19 Oct 2010    Post subject: Reply with quote
Get a Mitas CO2 rear in 120x100x18 or front C15 100x90x21 road legal and by far the best wearing tyre for all conditions /road use
CRF230 all you need
SillyMe
PostPosted: 08:30 - 20 Oct 2010    Post subject: Reply with quote
Thanks for that, I have tried to google them without any success. Where would I get them from to have a look. any links.
Cheers!
Dibble
PostPosted: 18:59 - 20 Oct 2010    Post subject: Reply with quote
Are you sure you have enough room at the front of the swingarm? a 110/100-18 is 110mm high(nominal) a 140/100-18 is 30mm taller and might rip off the plastic shockguard thing bear in mind the tyre increases in diameter at speed.
G is right a wider tyre will not produce any more grip on the road (maybe less as it is a larger diameter the chord will be less )
Off road it depends what your riding on.
SillyMe
PostPosted: 19:02 - 20 Oct 2010    Post subject: Reply with quote
Good point above, I would get away with a 120/100-18, I saw one the other day. It looked much wider than mine. So I guess the 130's and 140's may be too wide.
Imonster
PostPosted: 19:46 - 20 Oct 2010    Post subject: Reply with quote
Cheers!
I normally get my Mitas tyres through Leisuretrail. Google should see you right.
Those who make peaceful revolution impossible will make violent revolution inevitable.
The last post was made 16 years, 10 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 77.87 Kb
