Stage 6 Pro Replica Exhaust on Piaggio Nrg 50 AC
andycole94
PostPosted: 12:20 - 18 Oct 2010    Post subject: Stage 6 Pro Replica Exhaust on Piaggio Nrg 50 AC Reply with quote
Hi to all as im new to the forum Smile ,
Iv fitted a Stage 6 exhaust and ive up jetted the carb to a 72, and now i have a serious bogging issue, it boggs right up untill i hit 5000rpm and hits 20mph. Once it is running flat out for about 40 seconds it hits 5000rpm and goes for it, and within about another 30 seconds i hit about 50-55mph at 8000rpm? Im not happy about the slow acceleration and how it handles even small hills to an almost stop, unless im over the 5000rpm, how could i get better acceleration? If it helps, my contra spring and rollers are all standard.
Cheers for reading and any replies.
SillyMe
PostPosted: 17:06 - 18 Oct 2010    Post subject: Reply with quote
Probably because the mixture is rich, Have you carb tuned, your getting a lot of power over so many thousand revs because two strokes fail to loose any mixture through the exhaust port when reving at a certain speed. AKA power band.
Suprised your exhaust hasn't melted yet.
Once made equal to man, woman becomes his superior.
The man who says "I may be wrong, but -" does not believe there can be any such possibility
Owned and rode: Honda 100H, Honda MBX 125, Kawasaki AR 125, Suzuki RG 125 Pepsi, Honda NSR125 RK, Honda NRS 125 race bike, Suzuki GSXR 400 Bandit, Aprilia RS 125 O2, Honda CG125, Kawasaki KMX 125, Aprilia RS 125 O6, Suzuki XT225 and now Honda XR 400. ( A few scooters and other dead beats in between)
andycole94
PostPosted: 21:45 - 18 Oct 2010    Post subject: Reply with quote
Sorry I don't quite understand what you mean? In laymen terms please.
SillyMe
PostPosted: 07:29 - 19 Oct 2010    Post subject: Reply with quote
Basically, it sounds as though it's because of the adjustments you have made with the exhaust and carb up-jetting.
Low back pressure/power in low revs could be the new pipe fitted, a fuel mixture issue set at the carb or/and it could just be as a result of the changes you have made to the bike.
Low power in low revs also indicates new piston rings needed but unlike judging by he speed you attain in higher revs.
In laymen’s terms you shouldn’t have spent all that money turning a scooter into a rocket, you should have passed your test and bought a bigger bike.
andycole94
PostPosted: 18:35 - 19 Oct 2010    Post subject: Reply with quote
Ok, thanks for your views on 50cc engines Confused , I only ride one as im 16 and live in the U.K. so I can't legally ride anything bigger, e.g. 125cc, but do you have any advice on how to stop the bogging and slow acceleration?
Livefast123
PostPosted: 19:03 - 19 Oct 2010    Post subject: Reply with quote
Firstly you can't just add go faster bits to your ped without knowing what your doing and having some knowledge of 2 strokes. Sounds like your mixture is well out and your engine is having a real hard time
Firstly take your spark plug out and check what colour the end is.
Black - Rich
Coffee - Perfect
Whiteish - Lean
Sounds like your mixture is extremly rich so i'd expect a black plug. You will need to sort your jetting out first, you might want to try a ped site as you will have owners with NRG's etc who have done this mod and could help you more.
You will then probably find that you need heavier rollers etc
BTW riding your ped with those mods is illegal at 16 Rolling Eyes Keep it standard, enjoy for a year then get a bigger bike
Current ride - Yamaha MT-07
Digitalize
PostPosted: 19:14 - 19 Oct 2010    Post subject: Reply with quote
Having it de-restricted is technically illegal Laughing
Do anything you want to it is my view, just stick to 50cc
1998 CB600F Hornet
Kev1
PostPosted: 11:13 - 21 Nov 2010    Post subject: stage 6 exhaust Reply with quote
Hi, the Stage 6 Pro Replica exhaust pipe will never work with standard rollers, it makes virtually no power at all at 5000rpms (much less than the standard pipe at this rpm) but much more at higher revs
see... https://blog.pedparts.co.uk/2010/11/stage-6-pro-replica-exhaust-triumphs.html
All you have to do is decrease the weight of the rollers by approx 1.5 - 2grs to get the revs up and it will fly !
coggie
PostPosted: 23:44 - 24 Nov 2010    Post subject: Reply with quote
agreed, done loads mods to me derbi it flys but its still 50 cc bets most 70 ped just about keeps up with some 70 geared bikes
2005 Derbi Gpr Replica, Airsal 70cc kit, K&N, Doppler Racing Crank, Metrakit Pro Carbon Exhaust, Metrakit Carbon Reeds - Currently Being Build (Project)
(SOLD) 2005 Derbi Senda SM Limited Edition 656/999 (SOLD)
The last post was made 15 years, 71 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.12 - MySQL Queries: 13 - Page Size: 61.79 Kb
