Anyone ever cut an exhaust shorter?
MinhDinh
PostPosted: 15:28 - 19 Oct 2010    Post subject: Anyone ever cut an exhaust shorter? Reply with quote
A friend's neighbour has a Firebalde and he told me to cut my exhaust down like his so it sounds better. I was just wondering if it affects power and I need to re jet.
I know nothing of mechanics BTW, but my boss has a garage with all the tools to weld and stuff if I choose to do so.
I have a BlueFlame Evo 3
https://www.triumph-online.co.uk/ekmps/shops/squaredealsmot/images/plain-titanium-evo3-dual-trioval(1).jpg
I wouldn't mind a louder sound Smile
Hit the G spot. Wink
mad4it028
PostPosted: 15:33 - 19 Oct 2010    Post subject: Reply with quote
ive cut a few down on my zx6r i found i gained alittle on bottem end but to the expence of the top end
i also found that after the itnital couple of weeks the noise really got on my wick
Walloper
PostPosted: 15:50 - 19 Oct 2010    Post subject: Re: Anyone ever cut an exhaust shorter? Reply with quote
And all the usual hassle of noise and complaints to/by police
No power advantage worth the chop.
PostPosted: 15:59 - 19 Oct 2010    Post subject: Re: Anyone ever cut an exhaust shorter? Reply with quote
Don't need to weld anything. A drill, a hacksaw and a few rivets is all you need.
Often you lose some engine braking too.
pepperami
PostPosted: 16:06 - 19 Oct 2010    Post subject: Reply with quote
I made a "custom" (shorter) for my CG when I first got my welder.
I cut a section out and then welded the two ends back together again.
It worked on the bike but was louder and the bike popped and banged on over-run.
It was only and old gash pipe that I had lying around and I only did it to see if I could Smile
mad4it028
PostPosted: 16:12 - 19 Oct 2010    Post subject: Re: Anyone ever cut an exhaust shorter? Reply with quote
some pipes do need welding as the baffel is welded both ends but ive only found this with the oval rivet less types micron oval was the last i did that needed welding
MinhDinh
PostPosted: 16:16 - 19 Oct 2010    Post subject: Reply with quote
Okay so you can lose top end :o
Not sure if I ever will hit 160 (indicated) that often, but some reason I still want my bloody top end! LOL. I haven't even come close to 160 yet!
I suppose the neighbours will hate the noise, but I work 9-6 so usually only leave and get home at sensible times.
As for the police, quite a few follow me, and I have been stopped twice since I got the bike which is probably late Sept. I guess I don't want to give something that they can do me.
MinhDinh
PostPosted: 19:06 - 19 Oct 2010    Post subject: Re: Anyone ever cut an exhaust shorter? Reply with quote
Vincent wrote:
MinhDinh wrote:
I'd cut it off at the link pipe and weld on a Yoshi end can or similar Wink
Only kidding, "each to their own" and all that Razz
Already there when I got it :p
But it's not too bad in real life!
https://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs610.snc4/58993_433982089418_615694418_4873840_5100847_n.jpg
https://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs599.snc4/57961_433982024418_615694418_4873837_4661445_n.jpg
Walloper
PostPosted: 07:56 - 20 Oct 2010    Post subject: Reply with quote
Try not to leave slack in the security chain or leave the lock exposed to hammer blows.
andy py80
PostPosted: 09:27 - 20 Oct 2010    Post subject: Reply with quote
Hi its a realy nice exhaust but u will loose power by cutting it. : )
Andy py80
pepperami
PostPosted: 11:05 - 20 Oct 2010    Post subject: Reply with quote
MinhDinh wrote:
As for the police, quite a few follow me, and I have been stopped , I guess I don't want to give something that they can do me.
That`s exactly why I put the standard can back on my ZX6r Crying or Very sad
DrDonnyBrago
PostPosted: 11:28 - 20 Oct 2010    Post subject: Reply with quote
Was tempted to do the same to mine, decided against it as it is loud enough as it is.
MinhDinh
PostPosted: 12:11 - 20 Oct 2010    Post subject: Reply with quote
Why not Wall?
I thought it it was loose they couldn't just bang it down because the chain would move and take the force off?
Decided not to get it cut, but the guy who told me to do it said he knows a mechanic who can do it for 30 quid.
I didn't realise you lose power
johnsmith222
PostPosted: 12:33 - 20 Oct 2010    Post subject: Reply with quote
MinhDinh wrote:
Why not Wall?
Imagine trying to hit something that is lying on a hard surface (the ground). It's two solid objects with a weak point (the lock in between the ground and the hammer).
If it's up in the air then it is much harder to attack because the hammer will likely slip off it and it'll be moving all over the place. Also, it's much harder to cut a chain when it's off the ground because of bad access etc.
I'll go out and take a photo of what you should do with your almax chain cover so that you can secure your bike better.
EDIT:
Cut down the sheath down one side so that you are exposing half of the chain links. Cabletie it to one of the links so it doesn't ravel up like this:
https://i14.photobucket.com/albums/a324/david_m213/DSC00503.jpg?t=1287574805
The reason for keeping one side covered is that the side that's covered gets pulled through your wheel etc, giving it a bit of protection from scratching etc.
https://i14.photobucket.com/albums/a324/david_m213/DSC00504.jpg?t=1287574900
You can then shorten the chain to keep it off the ground like in this picture. This will make it much harder to attack the padlock and chain, and in theory, the less likely it will be broken. (eg, instead of having 20 links to attack, hoping for a weak one, they now only have a choice of 8.
MinhDinh
PostPosted: 14:16 - 20 Oct 2010    Post subject: Reply with quote
Ah I see what you did there.
Very good idea, you are right that it's damn hard to break through a chain and lock that can not be hammered on the ground.
Will have a look in a sec.
Minty
PostPosted: 17:18 - 20 Oct 2010    Post subject: Reply with quote
I stubbied the Scorpion can on my Blade and found no issues whatsoever and the sound is great.
The good thing with mine is that it still remains quiet sub 5k revs and comes alive above 5k.
Handy when the rozzers are around.
Took me about an hour to do.
My fingers smell of your mum.
The last post was made 16 years, 10 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 98.48 Kb
