Speed wobbles on a maxim - Sorted
2wheelsteve
PostPosted: 22:04 - 19 Sep 2010    Post subject: Speed wobbles on a maxim - Sorted Reply with quote
Ive just got a 1982 yam maxim that is starting speed wobbles on curves at speed, any maxim owners out there had similar, gonna have to check forks, swingarm tracking, tyre pressures, tyre condition, any more proper ideas would be appreciated
Ride Safe
Ichy
PostPosted: 22:07 - 19 Sep 2010    Post subject: Reply with quote
Not 100% sure it is the same bike but I had a XJ750 that used to wobble in a straight line at 120ish. I stuck a home made brace on the front, removed the headlight fairing and had the wheels balanced. Not sure which was the saviour but it fixed it.
2wheelsteve
PostPosted: 22:16 - 19 Sep 2010    Post subject: Reply with quote
I will get the wheels balanced and see how that goes and slow down at bends for now Smile Thumbs Up
Ride Safe
evoboy
PostPosted: 23:53 - 19 Sep 2010    Post subject: Reply with quote
I get this on my xj600 at around 100mph when taking bends.
Just kinda ride through it.
APT Motorcycles
Welshd1k
PostPosted: 01:30 - 20 Sep 2010    Post subject: Reply with quote
my hornet did this at 90 ish when i had a 16" rim with SHITE tyre. now with a 17" and a decent rubber its fine. i think its down to rubber / balancing and forks twisting
2wheelsteve
PostPosted: 07:55 - 20 Sep 2010    Post subject: Reply with quote
I do suspect the forks to be honest, get them off give them a roll and do the seals again I think, also look at the rear sus, cheers
Ride Safe
Pernig
PostPosted: 11:10 - 20 Sep 2010    Post subject: Reply with quote
The head bearings that come on it weren't that good to start with, and they are no better after 28 years. If you're really bothered about it it might be worth changing them for a tapered set. However mine is still passing MOTs with 44k on the clock.
Also if your tyre pressures are incorrect or if your tyres are excessively worn, this can cause a bit of a wobble. At one stage I tried some cheap Cheng Shin tyres and the bike handled awfully toward the end of their life. As soon as I changed them it was like riding a new bike.
Also you could check that the front wheel is in balance. This could make a little bit of difference. You could check the back one while you're at it but I find this doesn't affect the handling, just makes for slightly uneven tyre wear.
H100 Breaking for spares
2wheelsteve
PostPosted: 18:30 - 20 Sep 2010    Post subject: Reply with quote
Its not like tank slappers Ive had in the past, it feels like the arse end starts waggling, weard and scary but I stay with it easing off slightly and slowly, I know its the front but it feels like the rear, I'll sort it because its not the kind of thing you leave is it Smile Thumbs Up I reckon tracking or previous front end damage, ride safe guys
Ride Safe
2wheelsteve
PostPosted: 22:10 - 13 Oct 2010    Post subject: Reply with quote
Sorted, today I noticed scuffing on the rear tyre wall, the tyre is a very tight fit but today it was raining as usual so the bike wasnt pushed but yep scuffs appeared so yep its rear wheel bearings, ordered and will be sorted when they arrive, brilliant Very Happy Very Happy Very Happy Very Happy Thumbs Up
Ride Safe
2wheelsteve
PostPosted: 23:57 - 20 Oct 2010    Post subject: Reply with quote
Well if you ride through this you'd be in big shit bucking bronco style, I found the culprit..........
https://www.youtube.com/watch?v=bZfzbI7X-1A Thumbs Up Smile
Ride Safe
PostPosted: 01:50 - 21 Oct 2010    Post subject: Reply with quote
If the wheel bearings are shot, the sprocket carrier bearing wont be far behind them. Remember to replace that too.
Ichy
PostPosted: 09:06 - 21 Oct 2010    Post subject: Reply with quote
Yes it is a blatant plug but I don't have anything to do with them other than having brought parts off them.
https://simplybearings.co.uk/shop/
Have been very good for most of the bearings I've needed. Not always the cheapest but good quality and usually next day delivery. A complete set of bearing and seals for the CG cost around £15. Absolute bargain.
2wheelsteve
PostPosted: 11:20 - 21 Oct 2010    Post subject: Reply with quote
feels ok but I will watch for it, the saving grace is the left bearing next to the sprocket aint to bad at all.
I think swing arm bushes will be next in line for replacement though the movement up to now is less than a mil Smile
Ride Safe
Walloper
PostPosted: 11:27 - 21 Oct 2010    Post subject: Reply with quote
Check the wheel/frame alignment.
But as discussed soggy suspension could be the culprit.
I would plump for dampening not sufficient or out of balance.
A bouncy front or rear could be upsetting the other suspension unit.
Maybe a characterisic of the beast which you need to tame.
Try riding through it.... Embarassed
However many times a speed wobble happens one's chocolate starfish reacts with the same ferocity. Laughing
2wheelsteve
PostPosted: 11:45 - 21 Oct 2010    Post subject: Reply with quote
Its sorted now, no wobble when the bikes over on fast bends but Im gonna do the swing arm bushes just because I want to, Thumbs Up cheers Very Happy Very Happy
Ride Safe
Pernig
PostPosted: 14:13 - 21 Oct 2010    Post subject: Reply with quote
If your swingarm is like mine (which I suspect it might not be with the 550 being chain driven) there is an adjuster under the right hand swingarm pivot cover bit that you can screw out to take up the free play with a locknut over the top of it.
2wheelsteve
PostPosted: 14:41 - 21 Oct 2010    Post subject: Reply with quote
No unfortunetly it doesnt have that feature but like I say its miniscule movement that isnt affecting control at all, Ive got loads to do on it anyway but its all good fun, its called bonding with your bike Very Happy Thumbs Up
Ride Safe
The last post was made 15 years, 319 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 101.37 Kb
