So those V8 coffee tables?
PostPosted: 21:01 - 21 Oct 2010    Post subject: So those V8 coffee tables? Reply with quote
How easy are they to make?
The way I see it the only really tricky bit is the cleaning and lacquering of the block itsself.
I may have someone that can get me a Jaguar V12 block pretty cheaply so I'm sorely tempted.
Anyone know how you'd need to clean it, and what the best way to lacquer it?
I'm thinking acid dipped, then a car body shop to lacquer?
Fixing the glass to it could be done through the bolt holes that sit in the middle of the V.
90% sure the block's aluminium, if that makes a difference.
PostPosted: 21:15 - 21 Oct 2010    Post subject: Reply with quote
CHR15 wrote:
sandblast and powdercoat silver.
a piston pushed into the 4 corner cylinders, stopped by a peg welded into the liner.
legs, (made from conrods?)
and a glass top, with little rubber rectangles stuck on, where the 4 tips of the pistons meet the glass.
i'd do it tomorrow if i had the money.
How much for sandblast & powder coating ball park?
I'd be surprised if con rods were strong enough to support the weight of the block?
Also seems mad to mess about welding a peg into the barrels when you can just drill the glass and screw through it like this:
https://www.v12designs.co.uk/images/gallery/table/tbl_09.jpg
Raffles
PostPosted: 21:22 - 21 Oct 2010    Post subject: Re: So those V8 coffee tables? Reply with quote
Which school did you attend, Big_Ham? Wink
PostPosted: 21:23 - 21 Oct 2010    Post subject: Re: So those V8 coffee tables? Reply with quote
Pedant. Wink
Typically people tend to use V8s for coffee tables, I guess since they're more plentiful, and Top Gear made them famous.
Would you prefer those Engine Block tables? Razz
PostPosted: 21:25 - 21 Oct 2010    Post subject: Reply with quote
CHR15 wrote:
only reason i said that, is that you will find the casting has quite alot of imperfections on non machined areas, and might look a bit crap if just lacquered.
Hmm, however the machined bits & gasket faces will look crap if powder coated. So you'd need to mask those off when it's coated and then if it's aluminium leave them, if it's iron lacquer them. Thinking
Frost
PostPosted: 21:31 - 21 Oct 2010    Post subject: Reply with quote
I've seen one made out of an old F1 wheel and tyre.
PostPosted: 21:33 - 21 Oct 2010    Post subject: Reply with quote
Will it look as cool with an XR250 wheel? Razz Laughing
PostPosted: 21:40 - 21 Oct 2010    Post subject: Reply with quote
Just mailed a local place that does shot blasting, and powder coating, so we'll see what they say.
Silver
PostPosted: 22:03 - 21 Oct 2010    Post subject: Reply with quote
Ask Esoteric1, he'll know!
(actually I'm just bookmarking this, 'cos I'm interested in the outcome!)
SoND
PostPosted: 22:11 - 21 Oct 2010    Post subject: Reply with quote
Sheet of glass and grinding paste, will clean the faces up perfectly. It's unlikely to rust even if it's iron, good chance it won't get wet and there probably won't be a huge amount of damp in the house.
The conrods will easily hold a block.
daz_d_biker
PostPosted: 13:04 - 22 Oct 2010    Post subject: Reply with quote
https://blog.makezine.com/v8coffeetable.jpg
https://blog.makezine.com/v8table.jpg
You could bond the glass to the table or use suckers secured by holes drilled in the block/pistons?
"bikes are replaceable - but a complete nutter aint."
Robby
Dirty Old Man
PostPosted: 15:36 - 22 Oct 2010    Post subject: Reply with quote
Vapour blasting will get the best look - takes it back to plain, clean alloy. Will look better than new and far better than powder coating.
Not too cheap though. I had my CB250RS engine vapour blasted (7 different pieces in total) and it cost about £150.
To save yourself come cost, a pressure washer will take off an awful lot of crap. Coat it in strong household cleaner (cillit bang or similar) and let that work in first.
mad4it028
PostPosted: 18:28 - 22 Oct 2010    Post subject: Reply with quote
be cheaper just to buy one
https://cgi.ebay.co.uk/V8-coffee-tables-made-order-ideal-christmas-/160496090739?pt=UK_Home_Garden_LivingRoomFurniture_EH&hash=item255e4ffe73
PostPosted: 18:38 - 22 Oct 2010    Post subject: Reply with quote
They look as cool as fcuk but I think a stonkin great V twin turned into a small coffee table would be more full of win than them Thumbs Up
Silver
PostPosted: 19:05 - 22 Oct 2010    Post subject: Reply with quote
mad4it028 wrote:
That's cheap Thumbs Up The only ones I'd seen before were something like this: https://www.libertygames.co.uk/store/games_room_spares/games_room_furniture_decoration/v8-engine-table/
PostPosted: 19:23 - 22 Oct 2010    Post subject: Reply with quote
Thinking.
Interesting.
For a shot blast and powder coat it's £150 at the place near me.
Gazdaman
I did a trackday!!!
PostPosted: 20:49 - 22 Oct 2010    Post subject: Reply with quote
To get something that size powder coated would be about £40-50.
I thought about doing this, the main drawback was the weight. Those thing weigh an absolute ton.
But then F1 wheels can be picked up for about £50 including postage, I'd be far more likely to make one out of one of those.
Gaz
mad4it028
PostPosted: 20:51 - 22 Oct 2010    Post subject: Reply with quote
you may get an f1 tyre for that price but i very much doubt you would get a wheel too
Gazdaman
I did a trackday!!!
PostPosted: 20:53 - 22 Oct 2010    Post subject: Reply with quote
Ah, seem to be slightly more expensive now, but still only £80 inc postage.
There were loads when I last looked, eBay was almost flooded with them.
There's still plenty all in the same ballpark.
https://cgi.ebay.co.uk/Jordan-Midland-Spyker-F1-used-F1-wheel-rim-/140465038984?pt=UK_Sports_Memorabilia_ET&hash=item20b45e6688#ht_910wt_1139
Gaz
PostPosted: 21:03 - 22 Oct 2010    Post subject: Reply with quote
Gaz
The block alone's about 50kg IIRC.
The last post was made 15 years, 341 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.07 - MySQL Queries: 13 - Page Size: 110.88 Kb
