| grantp |
 grantp Renault 5 Driver
| Livefast123 |
 Livefast123 Nearly there...
| 0l0dom0l0 |
 0l0dom0l0 World Chat Champion
| grantp |
| 0l0dom0l0 |
| map |
 map Mr Calendar
 Posted: 11:57 - 22 Oct 2010 Post subject: |
From your description I agree it sounds like a fuel issue.
Try a quick fix first.
Locate your airbox, where the air filter is and then the carb.
Buy a can of carburettor cleaner spray.
Remove the air filter.
Start bike and spray carburettor cleaner into the carb.
When revs start to die stop and rev (may need 2nd person to give you a hand).
Repeat until engine revs fully.
If this doesn't sort if then it's a carb out and clean job.
Be careful of the jets as they can be damaged. Do not start poking bits of metal down them (use air preferable, at a push use brass or plastic).
If you don't know what I'm talking about in the carb then go to the library and read a book. Or look on the likes of this site, Dan's Motorcycle Repair Course, or this one (click text for link). There's even YouTube videos that may help, like this one.
Once sorted make sure you get an in-line fuel filter fitted to try and stop crap (one of the technical mechanics terms for this) from getting into the carb from the petrol tank.
HTH  ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?  |
| oatesmx |
 oatesmx Borekit Bruiser
 Posted: 15:20 - 22 Oct 2010 Post subject: |
i agree, its fuel/carb, either way fuel isn't successfully getting into your cilinder* just a good clean of the carb and checking the fuel line should do the job  ____________________ if it doesn't smoke, it's a joke... 2stroke for life bitch!!! |
| lukamon |
 lukamon World Chat Champion
 Posted: 19:05 - 22 Oct 2010 Post subject: |
i always use an upturned lynx can to cleanm out jets  ____________________ killa wrote: Im an ass man myself |
The last post was made 16 years, 12 days ago. Instead of replying here, would creating a new thread be more useful? |
