Problem with my moped..
grantp
PostPosted: 22:01 - 21 Oct 2010    Post subject: Problem with my moped.. Reply with quote
Hi,
I have a problem with my moped,
its a 2008 Baotian Pulse 49cc.
It was working fine till the other day when it just died. It then started but wouldn't go anywhere, it would move slightly then cut out. It will start and you can leave it running, but when you give it any throttle, the back will spins and then as you gradually give it more throttle it just dies.
Any help would be much appreciated.
Thanks.
Grant.
Livefast123
PostPosted: 22:08 - 21 Oct 2010    Post subject: Reply with quote
The first problem is that it's a Baotian....
On a more constructive note have you filled up with fuel recently? as it sounds like it's a fuelling problem.
Firstly I would replace the spark plug and fuel filter if it has one and see if that makes a difference. If that doesn't do anything I would drain the fuel tanks and carb then give it a good clean. Check the air filter and give it a clean/replace if ness.
Might also be worth checking the choke isn't stuck on
Current ride - Yamaha MT-07
0l0dom0l0
PostPosted: 22:09 - 21 Oct 2010    Post subject: Reply with quote
to lean. blocked main jet in carb. clean carb.
grantp
PostPosted: 22:58 - 21 Oct 2010    Post subject: Reply with quote
Do you know where the carb is located?
Thanks.
0l0dom0l0
PostPosted: 08:06 - 22 Oct 2010    Post subject: Reply with quote
The carb is the massive thing connected to the engine and airbox.
map
Mr Calendar
PostPosted: 11:57 - 22 Oct 2010    Post subject: Reply with quote
From your description I agree it sounds like a fuel issue.
Try a quick fix first.
Locate your airbox, where the air filter is and then the carb.
Buy a can of carburettor cleaner spray.
Remove the air filter.
Start bike and spray carburettor cleaner into the carb.
When revs start to die stop and rev (may need 2nd person to give you a hand).
Repeat until engine revs fully.
If this doesn't sort if then it's a carb out and clean job.
Be careful of the jets as they can be damaged. Do not start poking bits of metal down them (use air preferable, at a push use brass or plastic).
If you don't know what I'm talking about in the carb then go to the library and read a book. Or look on the likes of this site, Dan's Motorcycle Repair Course, or this one (click text for link). There's even YouTube videos that may help, like this one.
Once sorted make sure you get an in-line fuel filter fitted to try and stop crap (one of the technical mechanics terms for this) from getting into the carb from the petrol tank.
HTH Thumbs Up
oatesmx
PostPosted: 15:20 - 22 Oct 2010    Post subject: Reply with quote
i agree, its fuel/carb, either way fuel isn't successfully getting into your cilinder* just a good clean of the carb and checking the fuel line should do the job Wink
if it doesn't smoke, it's a joke... 2stroke for life bitch!!!
lukamon
PostPosted: 19:05 - 22 Oct 2010    Post subject: Reply with quote
i always use an upturned lynx can to cleanm out jets Thumbs Up
killa wrote: Im an ass man myself
The last post was made 16 years, 10 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 56.79 Kb
