Honda ns 125F Won't start?..
Robert121
PostPosted: 15:21 - 22 Oct 2010    Post subject: Honda ns 125F Won't start?.. Reply with quote
Hey guys, im a new member. I browse the forums alot and decided to register now Smile
anywhos... the problem..
I have a Honda ns 125F 86 model and i had it running last night perfectly, then today i started it like normal got round the corner and it started to splutter. I then pulled over and it cut out.
I checked the choke and it wasnt on, tried to kick it again with the choke and nothing. I have tried countless times...
So now im thinking are the carbs flooded?
i have taken out the plugg and cleaned it, no blockage in the fuel line either.
I had this problem once before, i cant remember what i did to fix it as i did everything :/....
Anyone have any ideas? cheers.
sup.
PostPosted: 15:36 - 22 Oct 2010    Post subject: Reply with quote
Does it have sufficient fuel? Is the fuel filter blocked? Could there be water in the carb (tends to accumulate at the bottom of the fuel tank causing no problems until there is plenty there and you switch to reserve)?
If those points check out OK then get a fresh spark plug and try that.
Robert121
PostPosted: 15:39 - 22 Oct 2010    Post subject: Reply with quote
half a tank of fuel :/
No idea about water in carb, but it was fine yesterday
I cleaned out the plug and its sparking fine aswell
cheers.
sup.
PostPosted: 15:50 - 22 Oct 2010    Post subject: Reply with quote
Unlikely to be water unless you had just switched to reserve.
It could have flooded but that would suggest that too much fuel was flowing. Most likely cause of that (ignoring leaving the choke on) would be a leaking needle valve in the carb. However this would likely cause major problem when you left the bike parked if you didn't turn the petrol off. Sticking floats in the carb can cause the same flooding (often fixed by tapping the carb float bowl a few times with a screw driver handle).
What condition was the plug in before you cleaned it?
Robert121
PostPosted: 15:59 - 22 Oct 2010    Post subject: Reply with quote
the condition of the plug was wet and a little oli on it, cleaned it up and the spacing was fine.
cheers.
sup.
PostPosted: 16:23 - 22 Oct 2010    Post subject: Reply with quote
Wet plug does suggest rich. It is always worth trying a fresh plug (always worth carrying one with a 2 stroke), as sometimes they can fire OK on view but not under pressure.
However I would be inclined to turn the petrol off (and drain the carb), and with the ignition off and plug out kick the engine over. See if the plug gets soaked again. If so the engine has flooded.
The last post was made 16 years, 9 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.92 - MySQL Queries: 13 - Page Size: 49.83 Kb
