| Robert121 |
 Robert121 L Plate Warrior
 Posted: 15:21 - 22 Oct 2010 Post subject: Honda ns 125F Won't start?.. |
Hey guys, im a new member. I browse the forums alot and decided to register now
anywhos... the problem..
I have a Honda ns 125F 86 model and i had it running last night perfectly, then today i started it like normal got round the corner and it started to splutter. I then pulled over and it cut out.
I checked the choke and it wasnt on, tried to kick it again with the choke and nothing. I have tried countless times...
So now im thinking are the carbs flooded?
i have taken out the plugg and cleaned it, no blockage in the fuel line either.
I had this problem once before, i cant remember what i did to fix it as i did everything :/....
Anyone have any ideas? cheers. ____________________ sup. |
| Robert121 |
 Posted: 15:50 - 22 Oct 2010 Post subject: |
Unlikely to be water unless you had just switched to reserve.
It could have flooded but that would suggest that too much fuel was flowing. Most likely cause of that (ignoring leaving the choke on) would be a leaking needle valve in the carb. However this would likely cause major problem when you left the bike parked if you didn't turn the petrol off. Sticking floats in the carb can cause the same flooding (often fixed by tapping the carb float bowl a few times with a screw driver handle).
What condition was the plug in before you cleaned it?
| Robert121 |
 Posted: 16:23 - 22 Oct 2010 Post subject: |
Wet plug does suggest rich. It is always worth trying a fresh plug (always worth carrying one with a 2 stroke), as sometimes they can fire OK on view but not under pressure.
However I would be inclined to turn the petrol off (and drain the carb), and with the ignition off and plug out kick the engine over. See if the plug gets soaked again. If so the engine has flooded.
The last post was made 16 years, 8 days ago. Instead of replying here, would creating a new thread be more useful? |
