Engine Oil
HD
PostPosted: 21:07 - 22 Oct 2010    Post subject: Engine Oil Reply with quote
As you may know I am in the process of restoring my bike. After some engine oil but not sure what I should get.
It says in the (shit) manual that I should use AGIP 10w40 oil but everywhere I look that is for a 4 stroke engine. Well not, the AGIP but others are. On the silkolene website it says to use any of these for my model:
SILKOLENE PRO SRG 75W
: SILKOLENE COMP GEAR OIL 80W-90
: SILKOLENE BOA 80W-90
: SILKOLENE LIGHT GEAR OIL 75W-80
So that surely means 75-90w oil? What would be the best to use? Planning on going to J&S tomorrow to go and get this. And some coolant aswell. If not Silkolene's Pro Cool then what should I be looking at?
Thanks guys Thumbs Up
HD
PostPosted: 21:20 - 22 Oct 2010    Post subject: Reply with quote
Well yeah. The oil you put in the engine, think its gear oil? Just changed the clutch and I dont even know what oil it is Laughing
But seriously, its just 2 stroke oil in the reservoir to mix with the fuel and then gear/engine oil in the engine (sump?) right?
Thanks
HD
PostPosted: 21:34 - 22 Oct 2010    Post subject: Reply with quote
So just 2 stroke and gear oil then?
Im after gear oil Cool Laughing
PostPosted: 21:37 - 22 Oct 2010    Post subject: Reply with quote
The oil you put in the gearbox of a 2 stroke is often normal 4 stroke engine oil.
10W40 is a normal engine oil. The others you list are specific gearbox oils. The weights of engine and gearbox oils are not that same.
With gearbox oil there are other issues, as some additives used in some oils react with some materials used in some gearboxes. They will probably specify GL4 or GL5, but GL5 does not signify an improved oil over GL4 but instead a different oil. This tends to be an issue on cars with synchromesh on the gears, but one to be aware of anyway.
HD
PostPosted: 21:42 - 22 Oct 2010    Post subject: Reply with quote
So what do I buy Confused Sad
MinhDinh
PostPosted: 21:44 - 22 Oct 2010    Post subject: Reply with quote
I got confused myelf when I had an RS125.
Engine oil is often known as 2stroke oil I think
Gearbox oil is 10 x 40 for the RS
To tell you the truth, I am still kinda lost on it
Hit the G spot. Wink
Carvel
PostPosted: 21:47 - 22 Oct 2010    Post subject: Reply with quote
What the manual tells you to buy
https://www.motoworlduk.co.uk/products/transmissionbike/gear10w40.html
HD
PostPosted: 22:04 - 22 Oct 2010    Post subject: Reply with quote
So 10w40 then? Does it matter if it says four stroke on it? Confused
Carvel
PostPosted: 22:21 - 22 Oct 2010    Post subject: Reply with quote
rob yarrr wrote:
just get 10w40 and stop your moanin! Razz
its all the same
No it isnt. Gearbox oils are designed to work under much higher pressures than engine oils. Also the derbi has a wet clutch which could be affected by using engine oil.
Aslong as its 10w40 gearbox oil it will be fine.
HD
PostPosted: 22:24 - 22 Oct 2010    Post subject: Reply with quote
Thankyou!
weasley
PostPosted: 22:53 - 22 Oct 2010    Post subject: Reply with quote
Except 10W-40 is an engine oil viscosity classification and so you'll struggle to find a dedicated gear oil with 10W-40 on it. IIRC 80W-90 is the nearest equivalent gear oil viscosity.
evoboy
PostPosted: 22:54 - 22 Oct 2010    Post subject: Reply with quote
Tis pretty much the same stuff...
Never had a problem using engine oil in the gearboxes of any of my strokers...
APT Motorcycles
neatbik
PostPosted: 23:04 - 22 Oct 2010    Post subject: Reply with quote
Just get some 80-90w gearbox oil.
Job done.
PostPosted: 23:35 - 22 Oct 2010    Post subject: Reply with quote
Yes. Normal, 10w-40 engine oil in the gearbox is pretty standard on many (most?) modern 2-strokes.
It's what lubricates the clutch and gearbox in 4-strokes too, these bits aren't significantly different between a 2-stroke and a 4-stroke. If anything, a 4-stroke is much harder on the oil because it's mashing it up through the engine too. It lasts much longer on a 2-stroke.
Last time I was in halfords, their semi-synthetic motorcycle 10W40 oil was on offer. Cheaper than the car stuff as it happens. This would be entirely appropriate, there is no need to blow your wad on super-special marketing gimmick oil for this application. Save that for your 2-stroke oil.
Any 10w-40 engine oil you can buy will be good enough. Just avoid car ones that contain lots of additives like GTX magnatec, these can cause clutch slip. Normal castrol GTX is fine too if you can find the 10w-40 grade (getting less easy to find these days). I used castrol GTX in my motorcycle engines for years with no problems but it started getting pricey.
I have tescos own brand semi-synthetic in my VFR at the moment.
ZRX61
Victor Meldrew
PostPosted: 07:39 - 23 Oct 2010    Post subject: Reply with quote
Carvel wrote:
its all the same
Yanno, if ya don't know WTF you are talking about, it's best to just keep quiet... Wink
ZRX61
Victor Meldrew
PostPosted: 07:40 - 23 Oct 2010    Post subject: Reply with quote
Job done.
Do NOT do this... Rolling Eyes
neatbik
PostPosted: 08:22 - 23 Oct 2010    Post subject: Reply with quote
Why not?
Ariel Badger
PostPosted: 08:36 - 23 Oct 2010    Post subject: Reply with quote
beatnck2 wrote:
Why not?
1. It is not the recommended oil.
2. Gearbox oils are normally intended for cars and generally they have dry clutches. An oil that heavy in a wet clutch will give grief.
neatbik
PostPosted: 09:02 - 23 Oct 2010    Post subject: Reply with quote
Sendaman himself has said that 'SILKOLENE COMP GEAR OIL 80W-90' is one of the reccomended oils.
Usually packaged as EP 80-90 (which is what i should have said in my first post as that is what i meant - long day..)
So, in short, using EP80-90 wont do any harm, its designed for the purpose.
MinhDinh
PostPosted: 09:47 - 23 Oct 2010    Post subject: Reply with quote
Yes but aren't engine oil for 2 strokes actually the 2T stuff etc... that mixes with the petrol.
and the oil for the gearbox is totally different but for the gear box.
PostPosted: 09:56 - 23 Oct 2010    Post subject: Reply with quote
Oh gosh. This thread is making my head hurt. When that happens it is often followed by the voices... Please don't make the voices start... they say
Kill them! Kill them ALL!
Confused
Right time for some facts:
Arrow The weight measurement for four stroke engine oil and gear box oils are different. The generally reccomended gearbox oils (IIRC 80w-90) are equivalent to 10w40 four stroke engine oil
Arrow The gearbox oil in a two stroke engine has a very very easy life. There are no carbon deposits, and very little swarf and gunk contaminates it. It doesn't get exposed to super high temperatures, nor squeezed by the top end of the engine. It lasts a LONG time.
Arrow You could go into a motorcycle shop and buy something like 'silkolene light gear oil' which I think is 80w90 if you want, thats what I did cos I'm anal about these things. Or, you could go into Halfords or Hein Gericke and buy cheap four stroke motorcycle engine oil and it will do exactly the same job. Especially in a 50cc bike which is under very little stress.
Arrow At the end of the day, it doesn't matter if you put 10w40 motorcycle engine oil in the bike, or 80w90 light gear oil, because they are nominally the same for the application you're using them for. As long as you don't put car engine oil with friction modifiers in them like Castrol GTX Magnatec, you'll be fine.
The last post was made 15 years, 322 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 134.45 Kb
