| HD |
 HD World Chat Champion
 Posted: 21:07 - 22 Oct 2010 Post subject: Engine Oil |
As you may know I am in the process of restoring my bike. After some engine oil but not sure what I should get.
It says in the (shit) manual that I should use AGIP 10w40 oil but everywhere I look that is for a 4 stroke engine. Well not, the AGIP but others are. On the silkolene website it says to use any of these for my model:
SILKOLENE PRO SRG 75W
: SILKOLENE COMP GEAR OIL 80W-90
: SILKOLENE BOA 80W-90
: SILKOLENE LIGHT GEAR OIL 75W-80
So that surely means 75-90w oil? What would be the best to use? Planning on going to J&S tomorrow to go and get this. And some coolant aswell. If not Silkolene's Pro Cool then what should I be looking at?
Thanks guys  ____________________ Rusty '02 Vito Camper + CBR600F3 |
| N cee thirty |
 N cee thirty Banned
| HD |
 Posted: 21:20 - 22 Oct 2010 Post subject: |
Well yeah. The oil you put in the engine, think its gear oil? Just changed the clutch and I dont even know what oil it is
But seriously, its just 2 stroke oil in the reservoir to mix with the fuel and then gear/engine oil in the engine (sump?) right?
Thanks ____________________ Rusty '02 Vito Camper + CBR600F3 |
| N cee thirty |
 N cee thirty Banned
| HD |
 Posted: 21:34 - 22 Oct 2010 Post subject: |
So just 2 stroke and gear oil then?
Im after gear oil  ____________________ Rusty '02 Vito Camper + CBR600F3 |
| N cee thirty |
 N cee thirty Banned
| Kickstart |
 Kickstart The Oracle
 Posted: 21:37 - 22 Oct 2010 Post subject: |
The oil you put in the gearbox of a 2 stroke is often normal 4 stroke engine oil.
10W40 is a normal engine oil. The others you list are specific gearbox oils. The weights of engine and gearbox oils are not that same.
With gearbox oil there are other issues, as some additives used in some oils react with some materials used in some gearboxes. They will probably specify GL4 or GL5, but GL5 does not signify an improved oil over GL4 but instead a different oil. This tends to be an issue on cars with synchromesh on the gears, but one to be aware of anyway.
| HD |
 Posted: 21:42 - 22 Oct 2010 Post subject: |
So what do I buy  ____________________ Rusty '02 Vito Camper + CBR600F3 |
| MinhDinh |
 MinhDinh World Chat Champion
 Posted: 21:44 - 22 Oct 2010 Post subject: |
I got confused myelf when I had an RS125.
Engine oil is often known as 2stroke oil I think
Gearbox oil is 10 x 40 for the RS
To tell you the truth, I am still kinda lost on it ____________________ Hit the G spot.  |
| Carvel |
 Carvel World Chat Champion
| HD |
 Posted: 22:04 - 22 Oct 2010 Post subject: |
So 10w40 then? Does it matter if it says four stroke on it?  ____________________ Rusty '02 Vito Camper + CBR600F3 |
| N cee thirty |
 N cee thirty Banned
 Posted: 22:08 - 22 Oct 2010 Post subject: |
just get 10w40 and stop your moanin!
its all the same ____________________ '00 Aprilia RS50 > '92 Honda CG > '99 Yamaha Fazer > '91 Yamaha RXS > '79 Suzuki X5 > 01' Honda Cg > 07' Honda Cg > 82' Kawasaki Z200 > suzuki gsxr 400 gk73a > honda vfr 400 NC30 Mod 2 Passed 09/06/2011
Jewlio Iglesias wrote: I actually did vote BNP once |
| Carvel |
| HD |
| weasley |
 weasley World Chat Champion
| evoboy |
 evoboy World Chat Champion
| neatbik |
 neatbik World Chat Champion
 Posted: 23:04 - 22 Oct 2010 Post subject: |
Just get some 80-90w gearbox oil.
Job done.
| stinkwheel |
 Posted: 23:35 - 22 Oct 2010 Post subject: |
Yes. Normal, 10w-40 engine oil in the gearbox is pretty standard on many (most?) modern 2-strokes.
It's what lubricates the clutch and gearbox in 4-strokes too, these bits aren't significantly different between a 2-stroke and a 4-stroke. If anything, a 4-stroke is much harder on the oil because it's mashing it up through the engine too. It lasts much longer on a 2-stroke.
Last time I was in halfords, their semi-synthetic motorcycle 10W40 oil was on offer. Cheaper than the car stuff as it happens. This would be entirely appropriate, there is no need to blow your wad on super-special marketing gimmick oil for this application. Save that for your 2-stroke oil.
Any 10w-40 engine oil you can buy will be good enough. Just avoid car ones that contain lots of additives like GTX magnatec, these can cause clutch slip. Normal castrol GTX is fine too if you can find the 10w-40 grade (getting less easy to find these days). I used castrol GTX in my motorcycle engines for years with no problems but it started getting pricey.
I have tescos own brand semi-synthetic in my VFR at the moment. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| ZRX61 |
 ZRX61 Victor Meldrew
| ZRX61 |
| neatbik |
| Ariel Badger |
 Ariel Badger Super Spammer
 Posted: 08:36 - 23 Oct 2010 Post subject: |
1. It is not the recommended oil.
2. Gearbox oils are normally intended for cars and generally they have dry clutches. An oil that heavy in a wet clutch will give grief. ____________________ Bikers make great organ donors, get 115 on your licence today. |
| neatbik |
| MinhDinh |
| MarJay |
 MarJay But it's British!
 Posted: 09:56 - 23 Oct 2010 Post subject: |
The last post was made 15 years, 323 days ago. Instead of replying here, would creating a new thread be more useful? |
