| oldbiker |
 oldbiker Nitrous Nuisance
 Posted: 22:51 - 23 Oct 2010 Post subject: silicone petrol pipes |
Just curious ????
I bought some of the silicone rubber stuff last year and I am not too impressed, I found that the ends where the jubilee clips go have become quite hard and nonflexible.
so apart from looking like good swag when new, what are the advantages of the silicone stuff over the braided poly or braided rubber rubber types????
I only ask `cos i feel that I was ripped and hope that somebody could tell me that there really is some advantage, and that I did not simply waste my money ____________________ It`s all powerfull white mans magic
https://i897.photobucket.com/albums/ac178/tzrsteve/album%201/035.jpg |
| Bezzer |
 Bezzer World Chat Champion
| lihp |
 lihp World Chat Champion
| Robby |
 Robby Dirty Old Man
| Walloper |
 Walloper Super Spammer
 Posted: 12:28 - 24 Oct 2010 Post subject: |
Why fcuk with tradition to improve the chances of failure?
I only found plastic, rubber or teflon (Polytetrafluoroethylene PTFE) products were suitable for petrol.
If it's cheaper/lighter/better wearing then I would consider 'up-grade' but I wouldn't change for change sake.
I have never had any problem with the braided rubber OEM on any bikes/cars/trucks.
It will perish due to heat or UV radiation but years of use would earn replacement with similar.
And fuel lines subjected to heat in service require a totally unique set up.
I'm Confused.  ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| Vincent |
 Vincent Banned
 Posted: 12:31 - 24 Oct 2010 Post subject: |
| Walloper |
 Posted: 12:42 - 24 Oct 2010 Post subject: |
My Triumph ST came with plastic quick couplers which were later changed for SS units as the plastic ones were leaking.... Free up-grade from Triumph UK.
They should be standard fit by OEM.
Legislation should cover that instead of compulsory ABS.  ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| kestrel |
 kestrel Nearly there...
| lihp |
 Posted: 17:19 - 24 Oct 2010 Post subject: |
| kestrel wrote: | as for the poster who reckons that this is the worlds first 'permanent' fuel pipe, i have a '77 XS650 in the garage with the same OEM fuel pipe it had when it was built 33 years ago..... how fuckin' permanent does it need to be? |
Sorry, my post was open to interpretation, and you interpreted not how it was intended. It's the first SILICONE hose for permanent use.
Generally silicone hoses are fit and forget items, and if you need to replace coolant hoses etc, replacing with silicone can generally be a good idea, but if the originals are lasting 20 years+ what's the point?
But yes, oem fuel hoses are more than adequate, silicone will deteriorate quickly if it's not the correct silicone and still not generally intended for long term use. Whether or not this new Samco stuff lasts, is yet to be proven, it's just claims, as nobody has had it fitted for 30 years. |
The last post was made 15 years, 293 days ago. Instead of replying here, would creating a new thread be more useful? |
