silicone petrol pipes
oldbiker
PostPosted: 22:51 - 23 Oct 2010    Post subject: silicone petrol pipes Reply with quote
Just curious ????
I bought some of the silicone rubber stuff last year and I am not too impressed, I found that the ends where the jubilee clips go have become quite hard and nonflexible.
so apart from looking like good swag when new, what are the advantages of the silicone stuff over the braided poly or braided rubber rubber types????
I only ask `cos i feel that I was ripped and hope that somebody could tell me that there really is some advantage, and that I did not simply waste my money
It`s all powerfull white mans magic
https://i897.photobucket.com/albums/ac178/tzrsteve/album%201/035.jpg
Bezzer
PostPosted: 11:16 - 24 Oct 2010    Post subject: Reply with quote
Think you've been stiffed and not using silicone rubber of any quality. Decent stuff keeps it's flexibility and shouldn't harden/crack like yours as it doesn't really suffer age hardening and copes with much higher temperatures than most other alternatives.
lihp
PostPosted: 11:47 - 24 Oct 2010    Post subject: Reply with quote
Regular silicone hosing will be destroyed by petrol.
You need to use fluorosilicone hoses. However, even this usually is not rated for PERMANENT Fuel use. This year SamcoSport released a hose called, I think, Samco ProFuel. This is apparently one of the worlds first hoses, suitable for fuel use, permanently.
What brand of hose are you using? is it fluorosilicone? If you do have Samco ProFuel, I'd get in touch with Samco about your problems, as it's obviously not fit for purpose.
Robby
Dirty Old Man
PostPosted: 12:26 - 24 Oct 2010    Post subject: Reply with quote
It's just tartiness, particularly on a bike where the engine is solid mounted and can't move around on its mountings like a car engine. The main reason people would fit it is to compliment the rest of the blue hoses in their engine bay.
Braided rubber hose costs pennies and lasts for decades. Stick with it.
Walloper
PostPosted: 12:28 - 24 Oct 2010    Post subject: Reply with quote
Why fcuk with tradition to improve the chances of failure?
I only found plastic, rubber or teflon (Polytetrafluoroethylene PTFE) products were suitable for petrol.
If it's cheaper/lighter/better wearing then I would consider 'up-grade' but I wouldn't change for change sake.
I have never had any problem with the braided rubber OEM on any bikes/cars/trucks.
It will perish due to heat or UV radiation but years of use would earn replacement with similar.
And fuel lines subjected to heat in service require a totally unique set up.
I'm Confused. Confused
Walloper
PostPosted: 12:42 - 24 Oct 2010    Post subject: Reply with quote
Vincent wrote:
My Triumph ST came with plastic quick couplers which were later changed for SS units as the plastic ones were leaking.... Free up-grade from Triumph UK.
They should be standard fit by OEM.
Legislation should cover that instead of compulsory ABS. Smile
kestrel
PostPosted: 15:39 - 24 Oct 2010    Post subject: Reply with quote
i see this 'samco' pipe is nearly £70 a metre. i've had bikes that cost less than that FFS! as for the poster who reckons that this is the worlds first 'permanent' fuel pipe, i have a '77 XS650 in the garage with the same OEM fuel pipe it had when it was built 33 years ago..... how fuckin' permanent does it need to be?
lihp
PostPosted: 17:19 - 24 Oct 2010    Post subject: Reply with quote
Sorry, my post was open to interpretation, and you interpreted not how it was intended. It's the first SILICONE hose for permanent use.
Generally silicone hoses are fit and forget items, and if you need to replace coolant hoses etc, replacing with silicone can generally be a good idea, but if the originals are lasting 20 years+ what's the point?
But yes, oem fuel hoses are more than adequate, silicone will deteriorate quickly if it's not the correct silicone and still not generally intended for long term use. Whether or not this new Samco stuff lasts, is yet to be proven, it's just claims, as nobody has had it fitted for 30 years.
The last post was made 15 years, 292 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.27 - MySQL Queries: 13 - Page Size: 61.28 Kb
