help needs to be fixed by 11pm
lonie This post is not being displayed because the poster is banned. Unhide this post / all posts.
PostPosted: 15:03 - 25 Oct 2010    Post subject: Reply with quote
First basic things. Clean the plug. Turn the petrol off and drain the carb float bowl (just in case water has got into the fuel). Check that fuel flows (ie, not a blocked filter).
Paxovasa
PostPosted: 15:04 - 25 Oct 2010    Post subject: Reply with quote
Plenty petrol in the bike?
Did you warm it up enough?
Fuel turned on or reserve?
Paxovasa
PostPosted: 15:14 - 25 Oct 2010    Post subject: Reply with quote
lonie wrote:
Yes plenty of petrol furl is in the same position as always KILLSWITCh ISOFF
I am trying to help Thumbs Up I never mentioned the kill switch.
If you don't warm the bike up enough, it will cut out when you open up the throttle Thumbs Up As it is colder it will take longer to warm up Thumbs Up
You probably flooded it, leave it for a few minutes and try again.
PostPosted: 15:21 - 25 Oct 2010    Post subject: Reply with quote
Would probably help to know what bike it is too.
Paxovasa
PostPosted: 15:23 - 25 Oct 2010    Post subject: Reply with quote
Check the breather hole is not blocked Thumbs Up
PostPosted: 15:26 - 25 Oct 2010    Post subject: Reply with quote
Sounds like the breather is blocked, fuel pipe kinked or the fuel filter is blocked. To check the first undo the petrol cap and see if fuel suddenly flows.
Also could be the floats have stuck in the carb. Tap the carb float bowl (with something like the handle of a screw driver) and again see if fuel suddenly flows.
PostPosted: 15:38 - 25 Oct 2010    Post subject: Reply with quote
Presume you mean the bottom of the tank is an upside down u shape to go over the spine of the frame. Lean the bike over as far as you can towards the side with the fuel tap on the tank and hopefully any remaining petrol will get onto the useful side of the tank.
Also check to see if you have a 2nd fuel tap on the other side of the tank (common on older bikes partly because of this kind of problem).
Paxovasa
PostPosted: 15:39 - 25 Oct 2010    Post subject: Reply with quote
"The defence rests, your honour" Very Happy
Paxovasa
PostPosted: 17:58 - 25 Oct 2010    Post subject: Reply with quote
Bikes take a few minutes to warm up properly.
Is the choke on the handlebar?
Paxovasa
PostPosted: 18:14 - 25 Oct 2010    Post subject: Reply with quote
You could buy some thing like this and attach it to the handlebars Thumbs Up
https://www.lambrettaspares.com/spareparts/control-cables/handlebar-choke-pull./mbu0444.html
HD
PostPosted: 20:31 - 25 Oct 2010    Post subject: Reply with quote
Dont know about anyone else but I dont ride my bike until I am satisfied that it is warm. So I leave it running for like 5 mins.
If everyone else does that, too, I would advise that you just hold your choke until it is warm.
Anyway, hope it works out. And you should have kept some money behind for petrol. I always keep £3 under my seat just to get me home. If I needed it that bad I would use it to get to work. Just an idea Thumbs Up
HD
PostPosted: 20:37 - 25 Oct 2010    Post subject: Reply with quote
Am I right in thinking you just pull that green thing? If so, then its practically on your bars Confused
And about the money, its easily done Laughing
Suntan Sid
PostPosted: 21:53 - 25 Oct 2010    Post subject: Reply with quote
Pull the choke then put a clothes peg, or two if they'll fit, on the cable to hold the choke in postion!
Glenben92
PostPosted: 22:09 - 25 Oct 2010    Post subject: Reply with quote
lonie wrote:
Also bike is a chinese copy of a dt 125 i know my own fault for buying chinese
lonie wrote:
the way the tank is there isnt enough for it to get to the tap (stupid design flaw)
stupid shoddy japanese designed bike...
57 Huoniao HN125-8 - Smile, 97 Kawasaki GPZ500S - Very Happy
99 Yamaha FZS 600 - Wink
Mod 2 Passed - 01/10/2010
The last post was made 16 years, 6 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 131.09 Kb
