Waterproofing my Feet
Ingah
PostPosted: 13:31 - 26 Oct 2010    Post subject: Waterproofing my Feet Reply with quote
Anyone got any ideas of any household items (or something cheap and readily available in a local supermarket) that i can use to waterproof my feet? My bike boots have developed gaping holes in the bottom and i need to go out delivering in the rain again later. It really doesn't need to be classy - just functional and cheap until i can go visit up north to get myself some Alt Bergs measured up.
Have tried bin bags previously, but found that my feet always end up wet-ish anyway, and it feels very cold the second i go out there - like the rain is coming straight through.
-- Ingah
sharpee1984
PostPosted: 13:37 - 26 Oct 2010    Post subject: Reply with quote
I had this issue once when hiking....and my boots split.
1 plastic bag in between 2 socks...did the trick for me although did get slightly sweaty!
PRESENT: HONDA CBR600F 2002
Past: Yamaha XJ600N 2001
Past: Hyosung GT125 2008
PostPosted: 13:41 - 26 Oct 2010    Post subject: Re: Waterproofing my Feet Reply with quote
I'd be tempted to go for a bag over your socks and another (ideally tougher, ie rubble bag etc) over your entire boot, then gaffa taped on top and possibly further down too.
Ol
PostPosted: 13:50 - 26 Oct 2010    Post subject: Reply with quote
silicone sealer.
instructions:
(1) - apply silicone sparingly over feet
(2) - put feet in boot
(3) - Ride, enjoying dry (bouncy) feet
(4) - Wink
PostPosted: 14:11 - 26 Oct 2010    Post subject: Reply with quote
Ol wrote:
silicone sealer.
instructions:
(4) - Wink
(5) - Chop feet off at ankles to remove boots
There fixed for you
Thumbs Up Thumbs Up
PostPosted: 14:14 - 26 Oct 2010    Post subject: Reply with quote
I put my foot in a carrier bag, then taped it to my leathers, I then put my boot on and folded the bag over and taped it to my boots.
Tonka
PostPosted: 14:36 - 26 Oct 2010    Post subject: Reply with quote
If you haven't got on very well with the binbag quick fix, you could try the verucca socks that you can normally get at a sports shop/swimming pool - they are cheap (couple of quid) and will keep your toes dry.
Personally, purely for being comfortable, I'd splash out the extra few quid and get some neoprene socks. They'll set you back less than a tenner and can be used over and over again. Wear normal socks underneath and make sure they are not sticking out the top as they will wick water down otherwise - this keeps the neoprene ones fairly clean (unless you have honkingly cheesy feet obviously!!), so you won't need to wash every time just dry/air ready for next wear.
HTH
paddlesat16
PostPosted: 14:41 - 26 Oct 2010    Post subject: Reply with quote
your feet are already waterproof, it's the boots and socks which have the problem. Take off boots and socks, stow in carrier bag, ride home and replace on feet...toasty Laughing
I once saw a bloke shagging a donkey.... in Saudi arabia. Theory Test Passed 26/10/09 Mod 1 Passed 26/4/10, Mod 2 Passed 7/6/10 Current Bikes Suzuki GSX1400 K5, Aprillia Pegaso 650, Suzuki DR350T.
iooi
PostPosted: 15:38 - 26 Oct 2010    Post subject: Reply with quote
If its in the sole, then how about one of the sticky soles you can get. Might need to add some extra glue to ensure its stuck. Or Duck tape the boot.
MarkJ
PostPosted: 15:45 - 26 Oct 2010    Post subject: Reply with quote
This Thumbs Up
Or if you're feeling flush, get hold of some tarpauline, cut to shape, wrap around boot and gaffer tape in place.
Paxovasa
PostPosted: 16:07 - 26 Oct 2010    Post subject: Reply with quote
I have done the carrier bag over the foot and sock trick Thumbs Up
It works, but it is only a temporary fix.
map
Mr Calendar
PostPosted: 16:11 - 26 Oct 2010    Post subject: Reply with quote
Not too cheap but not too expensive either would be a pair of gortex type over socks (that's over your socks but inside the boot). You can get these from outdoor shops, maybe cheaper than motorcycle accessory places (but check). I use a pair in winter as not only do they keep water out they keep my feet warm as well. Get them now and you can still use them with your new boots.
Other than that I'd go with the plastic bag over the socks (socks soak up the sweat) with anothe pair of socks over the top to hold the plastic in place.
HTH Thumbs Up
FreshAL
Sir Crashalot
PostPosted: 16:39 - 26 Oct 2010    Post subject: Reply with quote
sealskinz waterproof socks Thumbs Up
waffles
PostPosted: 17:00 - 26 Oct 2010    Post subject: Reply with quote
Use some of that caulking stuff that plumbers use round bathtubs? Thats supposed to be waterproof.
PostPosted: 17:12 - 26 Oct 2010    Post subject: Reply with quote
HTH Thumbs Up
+1 Thumbs Up
PostPosted: 18:10 - 26 Oct 2010    Post subject: Reply with quote
I've been doing it for the last 3 months Laughing
ajbsmirnoff
Smear your feet in vaseline. Then put your socks and boots on.
They won't be waterproof, but it'll be a funny thing to explain to the wife when she sees what you're doing.
Waterproof socks.
calyx
PostPosted: 18:15 - 26 Oct 2010    Post subject: Reply with quote
I paid 22 quid for them. You can get bike boots for 30 pounds.
Boris - London
spetom
PostPosted: 13:44 - 31 Oct 2010    Post subject: Reply with quote
Buy leather boots, which are sealed all the way around. Laced is ok so long as the tongue is stitched and not loose.
Then get some dubbin for £3
Smear it on once every 1-2 years.
Fully waterproof...
Teflon-Mike
tl;dr
PostPosted: 15:50 - 31 Oct 2010    Post subject: Reply with quote
Ol wrote:
silicone sealer.
instructions:
(4) - Wink
I was looking for a screen-shot of the 'Spray-On' shoes from Cloudy with a Chance of Meat-Balls, but I think my nipper's worn out the disk! Laughing
Practically
Different 'brands' of carier bag have different properties. Some are softer or more comfortable inside, some are crinkly and itchy, some have holes punched in them. [why do I even KNOW this shit?!?!?!?]
Carrierbags over the boots, rather than inside them can work better, but they soon rip.
Ultimately, decent boots are a must!
Cheap wellies are water-proof but offer zilch crash protection, so dont crash!
Cheap Derriboots are water-proof, but dont offer much crash protection, so still dont crash.
Cobblers can often fix old boots.
Ultimately needs must as the devil drives - make that trip up north!
PostPosted: 16:51 - 31 Oct 2010    Post subject: Reply with quote
Note you can get a variety of bike specific overboots (obviously less use to the OP when they posted), ie: https://www.mandp.co.uk/products/list/Clothing-and-Helmets/Waterproof-Overboots.
I found some quite useful looking bright yellow over boots that tread which I wanted to get for Glastonbury to wear on top of my army boots (as my wellies are terrible on stony stuff) - but the company, while it had a British division, had to get them from their US warehouse which would have taken too long.
Can't find the details, but reckon it'd have been good for bikes too.
bazza
PostPosted: 16:55 - 31 Oct 2010    Post subject: Reply with quote
https://bigrab.files.wordpress.com/2009/03/wellies.jpg
https://2.bp.blogspot.com/_xyEYIx77ERw/Swc4YooqwBI/AAAAAAAAAO4/sI842HrQx60/s320/duck_tape.jpg
Job jobbed. Thumbs Up
spetom
PostPosted: 16:56 - 31 Oct 2010    Post subject: Reply with quote
You can get rubber overboots on ebay, might be that sort of thing.
However has everyone forgotten DUBBIN?
For example:
https://cgi.ebay.co.uk/DUBBIN-REJUVENATES-OLD-TIRED-LEATHER-TACK-SHOES-/370448491491?pt=UK_Horse_Wear_Equipment&hash=item56407363e3
It's been used to waterproof practically everything but specifically leather for 800 years??
Only trouble is it makes things smell when you first apply it, but they have other derivatives now such as Nikwax and other modern (less smelly) and probably less effective versions of the same thing.
Dubbin is the way forward, British army still use it!
27cows
PostPosted: 17:12 - 31 Oct 2010    Post subject: Reply with quote
Wellies aren't recommended unless you're on an automatic. Even if you can squeeze your welly-shod foot between footrest and gearchange lever, the actual process of moving your foot up and down is fun, to say the least. When I say fun, I mean you'll keep missing gearchanges and probably die horribly at some stage Wink
PostPosted: 17:15 - 31 Oct 2010    Post subject: Reply with quote
Unless you're used to dirt bikes, in which case they'll feel amazingly supple, small and flexible Smile.
The last post was made 15 years, 331 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 131.15 Kb
