car radio fubar
oldpink
PostPosted: 21:00 - 28 Oct 2010    Post subject: Reply with quote
is it sporadic or constant, could be a lot of things, slack wire dry solder joint moisture
any more info may narrow it down, I used to repair taxi radio's for a living
but without a bit more info its hard to narrow it down
woll
PostPosted: 21:03 - 28 Oct 2010    Post subject: Reply with quote
HIjack...
Our tractor radio will turn up, but when you go to turn it down it turns up again Confused . Any ideas?
oldpink
PostPosted: 21:12 - 28 Oct 2010    Post subject: Reply with quote
press button or dial volume control ?? if button it could be sticking or shorting
if so a clean with an alcohol spray may solve it, if its a dial one that could be more tricky to pinpoint and more likely a fault in the amp or pre amp electronic's
oldpink
PostPosted: 21:19 - 28 Oct 2010    Post subject: Reply with quote
try sitting still and see if it does it, if its Ok it could be a loose wire, dry joint
particularly on the power side as if the voltave swings it will cut off and have erratic volume or other wierd things happen
if it does it while stationary then its very hard to tell without seeing the unit and seeing whats happening
also look for that screen dimming or getting brighter, it could be part of the power loop about to fail
like a leaky capacitor or damaged diode
oldpink
PostPosted: 21:33 - 28 Oct 2010    Post subject: Reply with quote
had a quick look on google, pretty newish so it will most likely be all integrated circuits
if it did it on another vehicle i'd have to say its an internal fault and very hard to track without opening it up
and getting a test meter in there to see whats going on
but as you mention its in a tractor (I'm assuming its a tractor not a lorry tractor)
I'd be inclined to think maybe dampness / condensation may have got in and is the culprate
can't really say much more without seeing it but open it up and check the fuse (theres normally one)
or look for any loose or oxidised connections or rust on the fuse holder etc
woll
PostPosted: 21:39 - 28 Oct 2010    Post subject: Reply with quote
It's a dial one... if it's a big job it can get left. I'll convince the boss it's foobar and to buy a new one Laughing
oldpink
PostPosted: 21:42 - 28 Oct 2010    Post subject: Reply with quote
if its a dial type its amost certainly an internal electrical issue
again not easy to track without getting a meter in there and checking it out
but most likely its at the amp stage, does it go up slow or jump quickly ??
woll
PostPosted: 21:44 - 28 Oct 2010    Post subject: Reply with quote
Jumps quickly... i tried hitting it incase it was a loose connection. It made no difference Laughing
oldpink
PostPosted: 21:47 - 28 Oct 2010    Post subject: Reply with quote
I've never had much luck using a hammer to fix electrical items
but its Bloody good fun trying Twisted Evil
oldpink
PostPosted: 21:51 - 28 Oct 2010    Post subject: Reply with quote
try the local Chav's Twisted Evil up my way a tenner will get you a good one Wink
as long as you don't ask for a receipt Rolling Eyes
The last post was made 15 years, 319 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.9 - MySQL Queries: 13 - Page Size: 90.18 Kb
