Need to fix Aprillia RX50 by tonight or can't get to work!!
efdnthr
PostPosted: 13:25 - 26 Oct 2010    Post subject: Need to fix Aprillia RX50 by tonight or can't get to work!! Reply with quote
Hi there, need to fix my Aprilia RX 50's running problems ASAP!! It's deresricted and will reach 50/55 mph, but I´ve been having trouble with it. It completely dies at about 40mph / when throttle is pulled back completely. Will only start again with choke and will only pull away with revs just below max. Took carb off - will give it a clean, but is there anything else obvious it could be before I re-assemble it and find out it´s still having the same problem? Electrics maybe? Would really appreciate some help please!!
efdnthr
PostPosted: 13:36 - 26 Oct 2010    Post subject: Reply with quote
not sure, how would i check?
efdnthr
efdnthr
PostPosted: 13:46 - 26 Oct 2010    Post subject: Reply with quote
sorry, didn't mean to post that twice, pressed the wrong button Razz
I have an Aprilia RX 50, can't wait to get something that doesn't die up hill!! Hahhaa Razz
d3akiin
PostPosted: 15:06 - 29 Oct 2010    Post subject: Reply with quote
im having the exactly the same problem my bikes a 09 plate need help Sad
m.d.deakin
PostPosted: 15:10 - 29 Oct 2010    Post subject: Reply with quote
rob yarrr wrote:
is the clutch adjusted properly ?
How would that affect it?
d3akiin
PostPosted: 15:20 - 29 Oct 2010    Post subject: Reply with quote
do you know why this is.. also when i turn the handle bars after it ticks over it cuts it off!
m.d.deakin
PostPosted: 15:43 - 29 Oct 2010    Post subject: Reply with quote
I can't see a poorly adjusted clutch doing the symptoms listed. At speed a poorly adjusted clutch will only slip or not engage fully.
PostPosted: 15:44 - 29 Oct 2010    Post subject: Reply with quote
I imagine it is your throttle cable routing when you turn the bars it affects it.
d3akiin
PostPosted: 15:59 - 29 Oct 2010    Post subject: Reply with quote
i just dont understand how it cuts out when you fully rev it Sad
m.d.deakin
PostPosted: 16:00 - 29 Oct 2010    Post subject: Reply with quote
Have you modded it or changed anything from stock? How was it derestricted.
d3akiin
PostPosted: 16:02 - 29 Oct 2010    Post subject: Reply with quote
its all completely standard exept it has a mallosi air filter on it.. i have just brought a new metrakit exhaust for it and it was de restricted by a proper motoring shop.
m.d.deakin
PostPosted: 16:05 - 29 Oct 2010    Post subject: Reply with quote
is the air filter a 'pod' style filter?
d3akiin
PostPosted: 16:13 - 29 Oct 2010    Post subject: Reply with quote
It is like a k and n air filter but its spongey if you know what I mean also my other problem is my clocks my milage shows 999999 my speedo don't work nor my revs how would I fix this is ther a reset button?
m.d.deakin
JD-234
PostPosted: 18:04 - 29 Oct 2010    Post subject: Reply with quote
have you rejetted the carb after putting the airfilter on, put the standard one back on
pits
PostPosted: 20:47 - 29 Oct 2010    Post subject: Reply with quote
Your power rave valve is more than likely fooked, and I can tell you that there is no stock of Aprilia power rave valves in the UK, you can get one from Italy, but they are all on holiday or something.
Identical problem to my RS125, and my RS125 has had
New bottom end
New top end
New carb
New air filter and service (standard filter)
In fact the only thing left to replace is the power rave valve, but just can't get hold a new one for love nor money, not buying a second hand one for near as dammit the same price as a new one.
K&N and new exhaust would have required up jetting the carb.
Your best bet is to get it to a garage and get it properly checked over, the short of it though, you aint going anywhere on it, it will become totally unrideable.
d3akiin
PostPosted: 10:21 - 30 Oct 2010    Post subject: Reply with quote
the rx 50 2009 model does not have a power valve it has a reed valve.
m.d.deakin
pits
PostPosted: 11:50 - 30 Oct 2010    Post subject: Reply with quote
The reed valve does the same job as the rave valve does it not? If it does then the symptoms are identical to a failing rave valve.
Either way, I would get it to a garage to have a look at, the Aprilias are to finicky to mess about with unless you know what you are doing, easily mess that up and it can quickly cost you a lot of money
Syris the Indomitable
PostPosted: 12:04 - 30 Oct 2010    Post subject: Reply with quote
To me this sounds like a fuel flow issue, your Carburettor float chamber may be running out at you approach higher revs, check the manual for float height; set the float height as well as blowing out the NEEDLE VALVE, give fuel lines a good blow out too.
If this fails it also sounds to me to be an environmental dip CDI issue.
Source: Rebuilt an RS 125.
In Greek mythology Ichor is what immortals have in the place of blood
Those that mind, don't matter...Those that matter, don't mind. Do you agree with this?
d3akiin
PostPosted: 13:38 - 31 Oct 2010    Post subject: Reply with quote
i have just looked at the carb it has a 10.2 jet in it.. and it has a mallosi air filter on it, also i have just ordered a new metrakit full exhaust for it i thought maybe its getting too much fuel beacuse the jet is so much bigger?
m.d.deakin
Codemonkey
PostPosted: 20:16 - 31 Oct 2010    Post subject: Reply with quote
Sounds to me more like it might be running lean (this is a very bad thing). Could be overheating as you work the engine harder, causing it to die. Try fitting the original more restrictive air filter back on and see if that makes any difference.
*(My experience is with model aircraft 2 stroke engines, so I could be talking rubbish).
The last post was made 16 years, 15 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.12 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 114.56 Kb
