NSR Ground points?
skatefreak
PostPosted: 11:37 - 30 Oct 2010    Post subject: NSR Ground points? Reply with quote
Hey,
So I'm planning to go over the ground points on the NSR but am not 100% sure how many there are or where they are to be found...
I have the wiring manual but cant see any "traditional" ground/earth symbols.
Anyone fancy giving me a clue? Smile
Diagram attached.
Best regards
-Jvr
Syris the Indomitable
PostPosted: 13:35 - 30 Oct 2010    Post subject: Reply with quote
Well normally they would look like this:
__|__
The one your diagram near the stator looks like this:
____
In Greek mythology Ichor is what immortals have in the place of blood
Those that mind, don't matter...Those that matter, don't mind. Do you agree with this?
skatefreak
PostPosted: 13:41 - 30 Oct 2010    Post subject: Reply with quote
Thats what i was thinking....
It would imply that there are at least (from what i can see) 5 points:
- Ignition coil
- Temp Sensor
- Alternator
- Neutral switch
- Starter motor
Does that sound right to anyone?
I know there is a ground on the ignition coil, i will go and have a gander and see what else i can find as the weather is pretty good heh.
Cheers for pointing out my suspicions there.
Best regards
-Jvr
trisers
PostPosted: 16:13 - 30 Oct 2010    Post subject: Reply with quote
That looks the case to me, just the five earthing points...the main battery earth is actually in the harness with the starter motor and shares the same earth point on the frame?
The temp sensor i suspect will earth through it's own body so no separate earth point for that one....
PostPosted: 16:32 - 30 Oct 2010    Post subject: Reply with quote
Yep looks good to, so it's just a case of making sure they are screwed down firmly and not touching any other circuits.
alains
PostPosted: 19:13 - 30 Oct 2010    Post subject: Reply with quote
i recommand for any bike to add a wire section 2 to 4 square mms (multi-sprigs) from the negative of the battery to a bolt on the frame then another one from the same bolt to an engine bolt
The last post was made 15 years, 346 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 47.89 Kb
