Clutch Noise.
johnsmith222
PostPosted: 19:01 - 01 Nov 2010    Post subject: Clutch Noise. Reply with quote
Hi guys.
My clutch is being unusually noisy. I noticed this noise when in first gear and I thought it was the camchain. It turns out it is the clutch.
What is happening is that in neutral with the bike idling there is a whirring noise coming from the clutch basket. This noise has been pretty recent in the past couple of weeks. The sound goes away when you pull the clutch lever when the bike is idling in neutral.
The clutch case is coming off anyway this week to replace a seal, but I was wondering if any of you knew what the issue could be. The bike has done around 24k miles.
Today I noticed that the biting point had moved to the end of the lever even though I adjusted it quite recently. I have enough experience with clutch cables to know it's not that.
I also noticed when I pulled into uni that I felt like there wasn't nearly as much engine braking as there should be compared to the rest of my journey. I double checked the choke wasn't on.
What do you guys think?
Thanks for any help! Thumbs Up
HD
PostPosted: 19:24 - 01 Nov 2010    Post subject: Reply with quote
(how did you get on with that parking ticket?)
No idea Laughing
johnsmith222
PostPosted: 19:47 - 01 Nov 2010    Post subject: Reply with quote
No idea Laughing
I sent them a letter a couple of weeks ago to let them know I'm appealing. I have 3 different reasons for appealing the parking ticket that I will explain in my thread once I get my cancellation letter.
I am pretty sure they will back down, because I know I wont. Thumbs Up
Blue_SV650S
PostPosted: 20:31 - 01 Nov 2010    Post subject: Reply with quote
If the lever is needing adjusting, its more just a coincidence then!
When the clutch is apart, measure the plate thickness to see if you need to replace.
Also, check the basket for wear/grooving.
The last post was made 15 years, 322 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.09 - MySQL Queries: 13 - Page Size: 39.89 Kb
