Epoxy on a radiator?
Bike Chat Forums Index -> The Workshop via View Category
DrDonnyBrago
PostPosted: 09:44 - 02 Nov 2010    Post subject: Epoxy on a radiator? Reply with quote
Hi,
I recently stripped and repainted my radiator as it was riddled with corrosion. All has been well for about 600 miles but yesterday I noticed a coolant filled blister had developed under the paint on one of the side tanks.
Popped it, dried the area (which didn't feel wet again) and stuck a blob of araldite over the blistered area.
Thinking about it later on I have doubts about how good an idea this was. In retrospect I SHOULD have stripped the paint from the surrounding few inches and treated the whole lot. Also I am not 100% on the suitability of araldite epoxy in this situation.
What ya reckon, will it last? temporary/permanant? Is epoxy the right thing on aluminium rads?
If there are better alternatives, how would I get the araldite off to apply them?
EDIT: Everyone loves pitchers
Before painting
https://i1015.photobucket.com/albums/af271/DonnyBrago/DSC06188.jpg
After Painting
https://i1015.photobucket.com/albums/af271/DonnyBrago/DSC06196.jpg
https://i1015.photobucket.com/albums/af271/DonnyBrago/DSC06198.jpg
The area that blistered was about the size of a pound coin and around where the aluminium has pitted.
Damon
PostPosted: 09:50 - 02 Nov 2010    Post subject: Reply with quote
Doubt the epoxy will last an amazing amount of time tbh. I personally would strip the rad and then use one of those Ali weld sticks to braise the area.
2Smoke
PostPosted: 10:22 - 02 Nov 2010    Post subject: Reply with quote
This stuff works wonders:
https://il.rsdelivers.com/product/loctite/360652/leak-fix-repair-paste-55ml-tube/2269920.aspx
Have used it in allsorts of applications, radiators, fuel tanks, cases, cylinders...
dodgydog
I read somewhere that ordinary araldite is ok, but that araldite rapid absorbs moisture.
I repaired a petrol tank with araldite, many years ago. It outlasted the car.
Dog
I know that you believe that you understood what you think I said, but I am not sure you realise that what you heard is not exactly what I meant
Walloper
PostPosted: 11:10 - 02 Nov 2010    Post subject: Reply with quote
That radiator is bent like a Pringle man.... Shocked Laughing
Araldite Metal or JB weld.
As long as the surface is clean, keyed and the operating temperature of the gloowed bit is within the limits of the glue then no problems.
We use a cold welding compound to repair holes in Air conditioning evaporators and condensers without issue.
But if your rad is rotting from the inside then your repair may outlast the core.
https://www.bostik.co.uk/diy/product/araldite/Rapid-Steel/118
I can't find the Data Sheet for this but JB WELD 'Waterweld' will stick like shite to a blanket.
Stable to 148.88 Deg. C (300 Deg. F)
https://jbweld.net/products/water.php
Don't know who the agents are and how quick or $$$ to get it but I did most of the work for yous... Smile
DrDonnyBrago
PostPosted: 15:09 - 02 Nov 2010    Post subject: Reply with quote
Thanks for the suggestions, in my haste yesterday to patch it up to make it usable for today I just dumped the araldite onto a poorly prep'd area and hoped for the best.
Anyone know if epoxy can be removed with heat or something so I can clean up and key the area and apply some JB weld?
Donny
PostPosted: 15:14 - 02 Nov 2010    Post subject: Reply with quote
Don't think normal levels of heat wlill.
A quick google (ie, here) suggests there are a few chemicals that will dissolve araldite but not sure how commonly available they are.
With it being on a metal surface I think I would just carefully try a scalpel to cut it off.
DrDonnyBrago
PostPosted: 15:22 - 02 Nov 2010    Post subject: Reply with quote
Thanks, looking at the list, I do have one of the chemicals in my lab. Not sure I'd be able to smuggle a sufficient quantity out without it being obvious though...
Hmmm, time to crack out the scalpels Doh!
Damon
PostPosted: 15:25 - 02 Nov 2010    Post subject: Reply with quote
When I had to get old metal epoxy off my sump I used a knife, a thin screwdriver and a hammer to chip it away. It will easier to get off than you think.
Good luck!
Louise
PostPosted: 16:31 - 02 Nov 2010    Post subject: Reply with quote
Used Epoxy on my rad.
Its still going now. Seems fine, just smells when its hot Laughing
Walloper
PostPosted: 17:32 - 02 Nov 2010    Post subject: Reply with quote
Aradite Rapid will go soft enough to chew off with just boiling/boiled water from a kettle. The 'normal' stuff may be a bit more tenacious and need more aggressive Mularky-ing though.
If was well mixed it will chip off but then you risk poking a hole in the rad tank. Crying or Very sad
Can you get at it with a file/sandpaper/emery/carbrundinuminuminum paper? And just worry it away.
DrDonnyBrago
PostPosted: 20:03 - 02 Nov 2010    Post subject: Reply with quote
I used the araldite rapid, just assumed the red and white tubes were the standard version Embarassed . I will leave it on there for a few days to see what happens, the hole underneath it must be tiny because I can't actually see it, and only about 1/2 a ml of coolant came out to form the blister over the course of several hundred miles so I am not overly worried about a leak just yet.
I will try burning/melting/scraping and chiselling it off at some point so I can apply a more permanent solution - there is really good access to the part I glued which is nice. Normally I end up underneath the bike with rust in my eyes Thumbs Up .
PostPosted: 20:08 - 02 Nov 2010    Post subject: Reply with quote
Better than we got in the car. Pulled out of a petrol station to a roundabout. Stopped at the roundabout and saw a jet of water squirting a couple of feet straight in front of the car Doh! .
Walloper
PostPosted: 21:21 - 02 Nov 2010    Post subject: Reply with quote
I heard the pad backing licking the flat surface off my rear left disc of the car.
Hoi'd the wheel off to find a b*stard sliding caliper with a seized h/brake adjuster. Then the rain came on. Then it got dark. Then Halfrauds don't stock the pads.....
I effin hate cars. Crying or Very sad
PostPosted: 21:36 - 02 Nov 2010    Post subject: Reply with quote
You have my sympathy.
Noxious89123
PostPosted: 23:42 - 02 Nov 2010    Post subject: Reply with quote
It's meant to be Laughing
Lol wut?
The last post was made 15 years, 360 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Workshop via View Category All times are GMT + 1 Hour
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.37 - MySQL Queries: 13 - Page Size: 95.27 Kb
