| DrDonnyBrago |
 DrDonnyBrago World Chat Champion
 Posted: 09:44 - 02 Nov 2010 Post subject: Epoxy on a radiator? |
Hi,
I recently stripped and repainted my radiator as it was riddled with corrosion. All has been well for about 600 miles but yesterday I noticed a coolant filled blister had developed under the paint on one of the side tanks.
Popped it, dried the area (which didn't feel wet again) and stuck a blob of araldite over the blistered area.
Thinking about it later on I have doubts about how good an idea this was. In retrospect I SHOULD have stripped the paint from the surrounding few inches and treated the whole lot. Also I am not 100% on the suitability of araldite epoxy in this situation.
What ya reckon, will it last? temporary/permanant? Is epoxy the right thing on aluminium rads?
If there are better alternatives, how would I get the araldite off to apply them?
EDIT: Everyone loves pitchers
Before painting
https://i1015.photobucket.com/albums/af271/DonnyBrago/DSC06188.jpg
After Painting
https://i1015.photobucket.com/albums/af271/DonnyBrago/DSC06196.jpg
https://i1015.photobucket.com/albums/af271/DonnyBrago/DSC06198.jpg
The area that blistered was about the size of a pound coin and around where the aluminium has pitted.
| Damon |
 Damon World Chat Champion
| 2Smoke |
 2Smoke Crazy Courier
 Posted: 10:22 - 02 Nov 2010 Post subject: |
This stuff works wonders:
https://il.rsdelivers.com/product/loctite/360652/leak-fix-repair-paste-55ml-tube/2269920.aspx
Have used it in allsorts of applications, radiators, fuel tanks, cases, cylinders... ____________________ Currently in the stable.. '89 TDR250, 86 NSR250 '79 350LC, '79 DT175MX, 82, Pasola, '98 R1, '95 Speed Triple.. all of them total sheds.. |
| dodgydog |
 dodgydog World Chat Champion
| Walloper |
 Walloper Super Spammer
 Posted: 11:10 - 02 Nov 2010 Post subject: |
That radiator is bent like a Pringle man....
Araldite Metal or JB weld.
As long as the surface is clean, keyed and the operating temperature of the gloowed bit is within the limits of the glue then no problems.
We use a cold welding compound to repair holes in Air conditioning evaporators and condensers without issue.
But if your rad is rotting from the inside then your repair may outlast the core.
https://www.bostik.co.uk/diy/product/araldite/Rapid-Steel/118
I can't find the Data Sheet for this but JB WELD 'Waterweld' will stick like shite to a blanket.
Stable to 148.88 Deg. C (300 Deg. F)
https://jbweld.net/products/water.php
Don't know who the agents are and how quick or $$$ to get it but I did most of the work for yous...  ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| DrDonnyBrago |
| Kickstart |
 Kickstart The Oracle
| DrDonnyBrago |
 Posted: 15:22 - 02 Nov 2010 Post subject: |
| Kickstart wrote: | Hi
Don't think normal levels of heat wlill.
A quick google (ie, here) suggests there are a few chemicals that will dissolve araldite but not sure how commonly available they are.
With it being on a metal surface I think I would just carefully try a scalpel to cut it off.
Keith |
Thanks, looking at the list, I do have one of the chemicals in my lab. Not sure I'd be able to smuggle a sufficient quantity out without it being obvious though...
Hmmm, time to crack out the scalpels  |
| Damon |
| Louise |
 Louise World Chat Champion
 Posted: 16:31 - 02 Nov 2010 Post subject: |
Used Epoxy on my rad.
Its still going now. Seems fine, just smells when its hot  |
| Walloper |
 Posted: 17:32 - 02 Nov 2010 Post subject: |
Aradite Rapid will go soft enough to chew off with just boiling/boiled water from a kettle. The 'normal' stuff may be a bit more tenacious and need more aggressive Mularky-ing though.
If was well mixed it will chip off but then you risk poking a hole in the rad tank.
Can you get at it with a file/sandpaper/emery/carbrundinuminuminum paper? And just worry it away. ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| DrDonnyBrago |
| Kickstart |
| Walloper |
 Posted: 21:21 - 02 Nov 2010 Post subject: |
I heard the pad backing licking the flat surface off my rear left disc of the car.
Hoi'd the wheel off to find a b*stard sliding caliper with a seized h/brake adjuster. Then the rain came on. Then it got dark. Then Halfrauds don't stock the pads.....
I effin hate cars.  ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| Kickstart |
 Posted: 21:36 - 02 Nov 2010 Post subject: |
| Noxious89123 |
 Noxious89123 World Chat Champion
The last post was made 15 years, 360 days ago. Instead of replying here, would creating a new thread be more useful? |
