Honda CG - Neutral a pain in the ass to find...
jemdna
PostPosted: 13:32 - 02 Nov 2010    Post subject: Honda CG - Neutral a pain in the ass to find... Reply with quote
Hey everyone Smile
Just recently (last 50 miles or so?) neutral has become a real pain in the ass to get. Whilst riding every gear seems absolutely fine and clutch seems ok. It is almost impossible to put it in neutral if the bike is warm...
Oil change less than <200 miles ago
All other gears seem fine
Sometimes easier to locate neutral if bike is moving still? ~5mph
Cheers in advance for your help Smile
Bry
https://bryanhardy.co.uk/wpmu/files/2010/10/SNC00258.jpg
FreshAL
Sir Crashalot
PostPosted: 13:39 - 02 Nov 2010    Post subject: Reply with quote
Check your chain.
Most common reason for what you describe is the chain too slack.
If you're not sure how to check/adjust post back
VTRkemshell10...
PostPosted: 13:58 - 02 Nov 2010    Post subject: Reply with quote
blip your throttle,
usually helps with mine
Past Rides: Sym Jet Euro X, Gilera DNA, Aprillia RS125 (Spains No1 Replica), 1991 Honda NSF, 2006 Honda CG125, 1992 Honda CB400 Super Four, 2000 VFR800 FY-I
Current Rides: 2001 VTR1000 FIRESTORM
jemdna
PostPosted: 14:09 - 02 Nov 2010    Post subject: Reply with quote
Chain adjusted, done recently and made no difference to neutral (Although made ride much more pleasurable Very Happy)
Blipping throttle makes no difference (That I've noticed anyway)
Bry
map
Mr Calendar
PostPosted: 16:27 - 02 Nov 2010    Post subject: Reply with quote
Bry
Maybe consider another oil change?
IIRC the CG is about 900ml, so not that expensive, just a little bit of hassle.
One of my bikes did that when I put too much oil in it.
Ok on the move but a pain when stopped.
HTH Thumbs Up
blurredman
PostPosted: 16:48 - 02 Nov 2010    Post subject: Reply with quote
Lol, nice bike
Two things though:
Your front wheel fender is put on backwards and I could be wrong but the carburetta leg cover looks a bit crooked Laughing
Looks very strange xD
I have the same bike btw.
Walloper
PostPosted: 16:51 - 02 Nov 2010    Post subject: Reply with quote
Check that the gear 'LEVER' is not pushed into the cover or for some other reason tight to move.
Another thing may be your boots are too heavy to let you feel the change in lever position. It is kinda subtle on some bikes.
PostPosted: 16:58 - 02 Nov 2010    Post subject: Reply with quote
Check the slack on your clutch cable, it might not be fully disengaging which makes it awkward.
Hectristic
PostPosted: 19:29 - 03 Nov 2010    Post subject: Reply with quote
I've got the same problem, but then my cg's a bit knackered in general. It's easy to put it in neutral when it's cold, but near impossible to do when had a bit of a ride.
I've found that if you brake while going downhill with the clutch in, it's a lot easier to flick it in to neutral!
jemdna
PostPosted: 09:03 - 21 Nov 2010    Post subject: Reply with quote
Ok done some messing about...
* Chain at correct tension with no (noticable) tough spots
* Oil change done <50 miles ago
* Checked lever isnt hitting case
* Threatened with an assortment of hammers and other tools...
I've noticed more and more now that if the engine is off, it almost effortlessly goes into neutral, engine on and you've got no chance...
Bry
HD
PostPosted: 10:52 - 21 Nov 2010    Post subject: Reply with quote
Try the rocking method.
Down into first and hold the clutch in. As if you are kicking it into neutral apply a fair bit of pressure on the lever but not enough to go into second (as you normally would like you said going ~5mph)
Then rock the back back and forth and it 'should' jump in.
If all else fails; ask a mechanic. Just ride there and explain and let them see.
Alexio
PostPosted: 13:10 - 21 Nov 2010    Post subject: Reply with quote
I know the oil change wasn't long ago, but seeming as the gear box shares oil with the rest of the engine (it's a simple engine!) the oil level could still be wrong.
Use the dip stick!!!
Otherwise, I can only assume that the engine heating up affects the operation of the clutch somehow.
The last post was made 15 years, 70 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 80.83 Kb
