Honda Hornet - no top end, no pull - ideas?
Richie46
PostPosted: 11:44 - 04 Nov 2010    Post subject: Honda Hornet - no top end, no pull - ideas? Reply with quote
Hi chaps, any ideas, - I have a [not very well] Honda Hornet 600cc '98 42,000miles
Starts ok, recent new battery and plugs and air filter about 4k ago.
Noticed the acceleration was a bit sluggish, particularly in 4th/5th and now is very unwilling to pull beyond 4,500revs (in gear) hence top end is a sad 50mph or so - less so going up a hill.
Obviously something wrong but before I go diving in and wasting my time on the wrong part, does anybody have any ideas?? I'd rather sort myself rather than throw good money after bad by checking it in to a garage.
thanks in advance,
Richie.
DrDonnyBrago
PostPosted: 12:13 - 04 Nov 2010    Post subject: Re: Honda Hornet - no top end, no pull - ideas? Reply with quote
thanks in advance,
Richie.
Will it rev out to redline in other gears?
How about in neutral?
Richie46
PostPosted: 12:28 - 04 Nov 2010    Post subject: Reply with quote
Not revved it as far as 13,000revs(red line), but in neutral it revs out well beyond of what it can do in gear...
FreshAL
Sir Crashalot
PostPosted: 12:47 - 04 Nov 2010    Post subject: Reply with quote
With my limited mechanical knowledge, it sounds like a fuel issue.
Did it used to work fine, and this problem has only recently started to happen?
Did it work fine after the air filter and plugs?
Assuming yes to the above, it's probably a carb problem and most likely a blocked main jet
Other, less likely things that I would also check (experts probably will be along soon to say these could not be the problem)
* blocked/clogged fuel filter
* blocked/clogged tank breather
PostPosted: 13:03 - 04 Nov 2010    Post subject: Reply with quote
It requires very little power to rev out without any load, so revving it in neutral just really shows that there is no electrical rev limiter cutting in.
Has the idle speed dropped or is it still running perfectly normally at very low revs? When it lacks power is it still fairly smooth or is it misfiring?
If it is still idling normally but just getting breathless as the revs rise then I would first check the flow of fuel (ie, look for a blocked fuel filter, tank breather, kinked fuel pipe) and also air (look for a blocked air filter). If it was fuel flow related I would expect the problem to get worse rapidly if you tried using revs (as the fuel in the float bowls got used up).
If it is misfiring then I would look at the plugs, valve clearances, individual carbs, ht leads, etc.
Richie46
PostPosted: 14:44 - 04 Nov 2010    Post subject: Reply with quote
SEEMS TO RUN OK AT IDILING AND OR LOW SPEED, WHEN IT BEGINS TO LACK POWER THERE IS NO AUDIBLE MISSFIRE.
I THINK THERE COULD BE SOMETHING IN THIS AS I RECENTLY PUT ON A NEW CLUTCH CABLE WHICH MEANT ME TAKING OFF THE TANK, HENCE A KINKED PIPE OR SOMETHING MIGHT OF COME ABOUT AS A RESULT..
NO MISFIRING.
THANKS KEITH, MUCH APPRECIATED WILL LOOK TO CHECK THIS OUT
Marcg868
PostPosted: 20:23 - 04 Nov 2010    Post subject: Reply with quote
My Hyosung is also doing a very similar thing. Its had spark plugs changed,oil changed,air filter and spark plugs. Carbs have been cleaned also.
It idles well, but bogs when revving in neutral and has a lack of power and very jerky when riding.
So will be watching this topic with intrest.
JACK, MISS YOU LOADS YOU LEGEND.
FreshAL
Sir Crashalot
PostPosted: 11:42 - 05 Nov 2010    Post subject: Reply with quote
bwfc4eva86 wrote:
My Hyosung
GT650?
the GT650 is very similar to the SV650 which suffered from rain water getting into the tank. The float bowls then fill with water and fuel. The fuel floats on top, so the pilot jets get fuel but the main jets mostly get water.
Drain the fuel into a clear glass bottle, see if it's separated into fuel and water. If it is, check the drain hose isn't kinked, and drain the carbs too. On the SV there's allen screws to drain the float bowls, you'll need a long allen key to get to the rear carb.
Marcg868
PostPosted: 12:07 - 05 Nov 2010    Post subject: Reply with quote
FreshAL wrote:
bwfc4eva86 wrote:
My Hyosung
GT650?
I wish it was the 650 Laughing No its the 125 version.
MarkJ
PostPosted: 12:20 - 05 Nov 2010    Post subject: Reply with quote
Definitely just check for kinked/blocked lines first
PostPosted: 12:37 - 05 Nov 2010    Post subject: Reply with quote
LEave the tank open when you ride (obviously not with a full tank and tank corners easy. does it still do it? If so this will rule out a blocked breather.
MarkJ
PostPosted: 13:01 - 05 Nov 2010    Post subject: Reply with quote
Good idea chris but a bit difficult with Hornets, the entire filler cap comes off when you unlock it as it's not hinged onto the tank. Suppose you could hold it on with a bit of gaffer tape though Laughing
The last post was made 15 years, 348 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.09 - MySQL Queries: 13 - Page Size: 75.47 Kb
