| Richie46 |
 Richie46 L Plate Warrior
| DrDonnyBrago |
| Richie46 |
| FreshAL |
 FreshAL Sir Crashalot
 Posted: 13:03 - 04 Nov 2010 Post subject: |
It requires very little power to rev out without any load, so revving it in neutral just really shows that there is no electrical rev limiter cutting in.
Has the idle speed dropped or is it still running perfectly normally at very low revs? When it lacks power is it still fairly smooth or is it misfiring?
If it is still idling normally but just getting breathless as the revs rise then I would first check the flow of fuel (ie, look for a blocked fuel filter, tank breather, kinked fuel pipe) and also air (look for a blocked air filter). If it was fuel flow related I would expect the problem to get worse rapidly if you tried using revs (as the fuel in the float bowls got used up).
If it is misfiring then I would look at the plugs, valve clearances, individual carbs, ht leads, etc.
| Richie46 |
 Posted: 14:44 - 04 Nov 2010 Post subject: |
| Kickstart wrote: | Hi
SEEMS TO RUN OK AT IDILING AND OR LOW SPEED, WHEN IT BEGINS TO LACK POWER THERE IS NO AUDIBLE MISSFIRE.
I THINK THERE COULD BE SOMETHING IN THIS AS I RECENTLY PUT ON A NEW CLUTCH CABLE WHICH MEANT ME TAKING OFF THE TANK, HENCE A KINKED PIPE OR SOMETHING MIGHT OF COME ABOUT AS A RESULT..
NO MISFIRING.
Keith |
THANKS KEITH, MUCH APPRECIATED WILL LOOK TO CHECK THIS OUT |
| Marcg868 |
 Marcg868 World Chat Champion
| FreshAL |
| Marcg868 |
| MarkJ |
 MarkJ World Chat Champion
| chris-red |
| MarkJ |
 Posted: 13:01 - 05 Nov 2010 Post subject: |
Good idea chris but a bit difficult with Hornets, the entire filler cap comes off when you unlock it as it's not hinged onto the tank. Suppose you could hold it on with a bit of gaffer tape though  |
The last post was made 15 years, 349 days ago. Instead of replying here, would creating a new thread be more useful? |
