| CarlosCBR |
 CarlosCBR World Chat Champion
 Posted: 15:17 - 04 Nov 2010 Post subject: No power... |
Right, as some of you know from my other threads, i am in the process of building a race bike for next year. I have it almost fully assembled but it doesnt have any power (electrical).
I know the starter works as i joined the two wires together that feed the starter motor and that span, but when i turn the ignition switch on, nothing happens, no click from starter relay, no light comes on in rear light, its just like i havent turned the ignition on.
I have checked the ignition wires to the relay and they all seem fine.
Any help would be much appreciated.
Thanks.
Carlos. ____________________ https://www.youtube.com/watch?v=1OPv5mDPQ14
https://www.facebook.com/carl.simmonds.7 |
| nowhere.elysium |
 nowhere.elysium The Pork Lord
| map |
 map Mr Calendar
 Posted: 15:27 - 04 Nov 2010 Post subject: |
Checked the fuse(s)? ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?  |
| CarlosCBR |
| CarlosCBR |
 Posted: 15:28 - 04 Nov 2010 Post subject: |
| chris-red |
| nowhere.elysium |
| Kickstart |
 Kickstart The Oracle
 Posted: 16:04 - 04 Nov 2010 Post subject: |
Is there a master fuse built into the starter relay? Fairly common on Hondas, with all power from the battery going to the relay, and then some feeds from there to the rest of the electrical system.
Failing that start probing various connectors to the ignition switch and afterwards for a voltage (ie, volt meter, one probe to -ve battery terminal and the other to the various wires) and see where the power stops.
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 19:09 - 04 Nov 2010 Post subject: |
A charged battery, but all systems dead, rather than some stuff working and others not, suggests a problem in the main feed.
battery connection, battery earth, main fuse or the common 'feed' via the ignition switch.
Bike was a Cat B wirte off wasn't it?
What wrote it off, was it by any chance, stolen, (crashed) & recovered? If so, has some-one butchered the loom trying to hot-wire it?
Can you try the ignition switch off your other bike?
Check the wires into the back off the connector blocks looking for one thats broken or cut, particularly the connector on the ignition switch. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| CarlosCBR |
| Acemastr |
 Acemastr World Chat Champion
| Vincent |
 Vincent Banned
| Kickstart |
The last post was made 15 years, 346 days ago. Instead of replying here, would creating a new thread be more useful? |
