No power...
CarlosCBR
PostPosted: 15:17 - 04 Nov 2010    Post subject: No power... Reply with quote
Right, as some of you know from my other threads, i am in the process of building a race bike for next year. I have it almost fully assembled but it doesnt have any power (electrical).
I know the starter works as i joined the two wires together that feed the starter motor and that span, but when i turn the ignition switch on, nothing happens, no click from starter relay, no light comes on in rear light, its just like i havent turned the ignition on.
I have checked the ignition wires to the relay and they all seem fine.
Any help would be much appreciated.
Thanks.
Carlos.
nowhere.elysium
The Pork Lord
PostPosted: 15:20 - 04 Nov 2010    Post subject: Reply with quote
Sounds like what's happening with the GS I'm renovating. Strip the switchgear, check everything for continuity. I'm presuming you have a multimeter, right?
map
Mr Calendar
PostPosted: 15:27 - 04 Nov 2010    Post subject: Reply with quote
Checked the fuse(s)?
CarlosCBR
PostPosted: 15:28 - 04 Nov 2010    Post subject: Reply with quote
The switchgear wouldnt have an effect on when i turn the ignition on would it? I turned the ignition on on my road bike and can hear the relay click. Could it be that the relay itself is knackered?
CarlosCBR
Yeah fuses are all good.
PostPosted: 15:37 - 04 Nov 2010    Post subject: Reply with quote
Kills switch?
nowhere.elysium
The Pork Lord
PostPosted: 15:43 - 04 Nov 2010    Post subject: Reply with quote
Depends largely upon how it's wired. Do you have a wiring diagram for it?
PostPosted: 16:04 - 04 Nov 2010    Post subject: Reply with quote
Is there a master fuse built into the starter relay? Fairly common on Hondas, with all power from the battery going to the relay, and then some feeds from there to the rest of the electrical system.
Failing that start probing various connectors to the ignition switch and afterwards for a voltage (ie, volt meter, one probe to -ve battery terminal and the other to the various wires) and see where the power stops.
Teflon-Mike
tl;dr
PostPosted: 19:09 - 04 Nov 2010    Post subject: Reply with quote
A charged battery, but all systems dead, rather than some stuff working and others not, suggests a problem in the main feed.
battery connection, battery earth, main fuse or the common 'feed' via the ignition switch.
Bike was a Cat B wirte off wasn't it?
What wrote it off, was it by any chance, stolen, (crashed) & recovered? If so, has some-one butchered the loom trying to hot-wire it?
Can you try the ignition switch off your other bike?
Check the wires into the back off the connector blocks looking for one thats broken or cut, particularly the connector on the ignition switch.
CarlosCBR
PostPosted: 19:39 - 05 Nov 2010    Post subject: Reply with quote
Yes Kickstart that is the type of relay on the bike, fuse is fine and relay looks good too, no corrosion etc. Quite stuck now and this has put the entire project in jeopardy and next seasons racing on hold. Anyone close by that could give me a hand?
Acemastr
PostPosted: 21:27 - 05 Nov 2010    Post subject: Reply with quote
I had this, had to jiggle the wires under the fuse box, it'll most likely be simple
2016 Toyota Tacoma Limited
PostPosted: 22:16 - 05 Nov 2010    Post subject: Reply with quote
Time to get a volt meter and probe around to find where the power stops.
The last post was made 15 years, 347 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.77 - MySQL Queries: 13 - Page Size: 83.81 Kb
