RS125, Getting fed up with it now :@
Stefan RS50 Wood
PostPosted: 17:28 - 04 Nov 2010    Post subject: RS125, Getting fed up with it now :@ Reply with quote
Right Ive posted before about my rs being too rich, as when i turn the fuel off and ride her she runs fine, until the fuel runs out of course. but i parked up in college today and came back and all of my petrol was on the floor even tho i turn the fuel off when i park up.
Will be getting the jets sorted soon but should that fix this problem, theirs no leak in the tank so i have no idea
stirlinggaz
PostPosted: 17:49 - 04 Nov 2010    Post subject: Reply with quote
if its leaking fuel from the carb, then its likely that floats are set at incorrect height or a bit of grit has got under the float needle.
cheers,
GAZ
Stefan RS50 Wood
PostPosted: 17:58 - 04 Nov 2010    Post subject: Reply with quote
cheers,
GAZ
Nice 1 will a carb service sort this out
PostPosted: 18:15 - 04 Nov 2010    Post subject: Reply with quote
Stefan RS50 Wood wrote:
cheers,
GAZ
It could be a leaky fuel tap as well. Throw some talc over it it should show where the leak is coming from.
PostPosted: 18:27 - 04 Nov 2010    Post subject: Reply with quote
Other possibility with the needle valve is that the float height is wrong or that the floats are damaged.
Just thought, UK seems to be getting more ethanol in fuel which is corrosive to some plastics (seems to be causing problems with various fuel tank sealants people have used over the years). Wonder if this sudden rash of RS possible fueling problems could be floats leaking?
stirlinggaz
PostPosted: 00:17 - 05 Nov 2010    Post subject: Reply with quote
cheers,
GAZ
shouldnt take you more than half an hour, from start to finish.
read Keiths guide to carbs for a few pointers.
i also find it interesting that there seems to be more & more of this type of problem arising,
cheers,
GAZ
The last post was made 15 years, 351 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 50.26 Kb
