rxs premix (still got problems)
Carvel
PostPosted: 20:43 - 03 Nov 2010    Post subject: rxs premix (still got problems) Reply with quote
Im going to run my rxs on premix because it siezed up and I dont fancy ruining another fresh rebore and piston. It was siezed when I bought it so there's obviously something going on.
I was just wondering what ratio to run it on. I ran my fizzy on 20:1 but im not too sure about the rxs.
Help greatly appreciated. Karma Thumbs Up
Ollie
Carvel
PostPosted: 21:19 - 03 Nov 2010    Post subject: Reply with quote
Im used to it, I used to premix my fizzy. I double checked everything, Bled the pump etc and everything is as it should be. I was thinking it might be something else causing it, like the mixture, but the plugs coming out a good colour and everythings adjusted correctly. The bike itself ran ok, but it rattled like a bastard which got progressively worse before it nipped up. Thing is it used to smoke so it must have been getting two stroke through Confused Bit confused really.
27cows
PostPosted: 21:45 - 03 Nov 2010    Post subject: Reply with quote
Something must have been seriously wrong. RXS motors are virtually impossible to seize (I once ran my original motor completely dry and it still didn't seize up, though it did make some scary noises Shocked ).
If it was smoking, chances are the issue has nothing to do with lubrication. Could be a dodgy rebore, or a dodgy piston. Have you got a picture of the piston?
Carvel
PostPosted: 22:04 - 03 Nov 2010    Post subject: Reply with quote
It wasn't like a locked up and wouldn't turn over siezed, more like ran like shit and made scary noises as you say.
I was thinking it could be a dodgy rebore. It was on a .75 oversize when I bought it so its nipped up three times in 16,000 miles!
https://i979.photobucket.com/albums/ae271/RxsOllie/SNC00075.jpg
Thats the only picture i've got. It did that in about 70 miles.
27cows
PostPosted: 09:40 - 04 Nov 2010    Post subject: Reply with quote
I would say the bore was under done. I've seen it happen on other bikes. Often happens where a barrel is honed instead of actually rebored, meaning people put a bigger piston into too-small bore - leading to the kind of carnage you have.
Having said that, if it was on .75 at a mileage when the original bore should just be nicely bedded in, that would suggest something else. RXS bores/pistons normally go to at least 40K even when relentlessly and mercilessly thrashed.
I'm wondering if there's crap in the oil tank, causing an intermittent blockage. Oil pumps rarely fail, certainly not after such a low mileage.
PostPosted: 11:41 - 04 Nov 2010    Post subject: Reply with quote
To add an extra thought into the mix, not sure Yamaha sell .75 o/s pistons and a fair chance it is a cheap pattern piston. Some pattern pistons are pretty useless and prone to seizing.
SnowTigeress
PostPosted: 19:34 - 04 Nov 2010    Post subject: Reply with quote
Tef here (Snowies been at my lappy again!)
Those skirt appatures looked suspiciousely dremmelled to me, so checked e-bay for pics of new pistons.
https://i.ebayimg.com/13/!B))K,IQB2k~$(KGrHqR,!iQEw5yWTwYrBMO5DdEM!!~~_12.JPG
[img]https://i.ebayimg.com/07/!B7Rs(K!!Wk~$(
KGrHqN,!k0Ey+jC1sigBMzvJSioig~~_12.JPG[/img]
I cant be sure but does look like some-one may have tried opening them up. Poss bad DIY porting job?
Quoted oversizes were +50 & +100 too, as Keith said
Real bikers build their own Renovated and Riding a 1986 Honda CB125TD-C called the Pup. Full Licence
13/09/2012, 1994 Moto Guzzi 750 Strada
Can-Do Girl that does spanners TOO!
TheSmiler: binning it is better than going around a roundabout the wrong way
27cows
PostPosted: 19:54 - 04 Nov 2010    Post subject: Reply with quote
You can get .25 for the RXS for sure, pretty sure .75 is also quoted in a parts list I have from Mitsui too.
A poor porting job is certainly a possibility. Why do people do it? It always ends in tears.
Carvel
PostPosted: 21:37 - 04 Nov 2010    Post subject: Reply with quote
This is the piston I bought (crappy pattern one)
https://www.wemoto.com/bikes/Yamaha/RXS_100/83-85/picture/Piston_Kit_0.75_Oversize/
I havn't touched it, thats how it came.
I snapped a ring so had to use an old one but that wouldn't have made any difference.
I checked everything again tonight. The oil tank is squeeky clean. When you take the bleed screw out of the oil pump it flows out fine. Also all the marks on the pulley line up as they should.
That fact that it was smoking before tells me the pump must be alright.
What else could have caused it?
Teflon-Mike
tl;dr
PostPosted: 22:06 - 04 Nov 2010    Post subject: Reply with quote
When did it nip up on you?
Cota used to nip up when used on the road... alledgedly... & did so curiousely. Comp-Trial bike, so loads of cooling fins for slow speed running, with little cooling effect.
Run it hard on road, & it would over-cool & nip up. Ritchening the pre-mix weakened the fuel ratio, made things worse, reducing the oil ratio, ritchened the fuel, made it better.
(The err.... underage rider apparently used to slosh half a gallon of neat in the tank to thin it down before heading down the back-lanes to see girlfreind on a Sunday when there were no country busses..... alledgedly!)
If its nipping up when maxed out, could be similar over cooling / weak mixture. Lifting the throttle needle a notch may help.
If its nipping up in traffic, then possibly under-cooling, due to lack of air-flow, may suggest idle mixture too lean.
Whats the ignition timing like? Too much advance / low grade fuel, could be causing knock / hot running.
What about the exhaust? (Is it on the stocker, or it it running a spannie?) pin-hole, leaky joint, lost baffle can make motor run weak, hence hot.
27cows
PostPosted: 22:46 - 04 Nov 2010    Post subject: Reply with quote
There's very little difference between one of those pistons and the ones that come in a Yam box. Shouldn't make any difference at all.
You will have checked the reeds/block for signs of breakage, of course. And the air box, to make sure there's a filter in there. Jetting is standard? Oil pipe itself intact and in good nick. Carb spotless. Barrel not ported or otherwise 'enhanced' by overenthusiastic learner.
RXS motors are immensely robust usually and can withstand most things and soldier on. I just can't imagine a reasonable situation where this kind of damage would occur so quickly.
Carvel
PostPosted: 23:10 - 04 Nov 2010    Post subject: Reply with quote
It happened gradually from when I fitted the piston. It just got worse (noisier, and started running like poo) until I took it apart and found that.
The pipe is standard.
Checked the reeds, they seem fine. Its got an air filter in it. The jetting is, as far as I know, standard. The carb is spotless. Barrels fine, hasn't been messed around with, could have been a shit rebore though.
I know, I am confused.
Teflon-Mike
tl;dr
PostPosted: 23:34 - 04 Nov 2010    Post subject: Reply with quote
Well scoring & nip means that the piston has got too big for the bore, doesn't it?
So its either bore to piston tolerences weren't right, OR, its got too hot, whichmeans, mixture or ignition.
Given the possibilities & unknowns, going pre-mix, is unlikely to help. Thats just another variable to start messing with.
If you dump the pump for pre-mix, then the oil has to go in via the carb.
Carb meters whatever comes out the petrol tank into the air-stream going into the engine. So when you mix oil in the petrol to make pre-mix, you are diluting the amount of petrol going into the carb, so you get a lean petrol to air mixture, and need to compensate, lifting the throttle needle and ritchening the idle mixture, to compensate.
That throws everything from stock settings, and as you'd ned to experiment to find the best pre-mix ratio, means a lot of mucking about, for what might not be any problem.
From where you are at: Will the piston clean up? Can you hone the bore? Or do you want to go the safe route and get a new, better rebore & new piston?
Putting it all back together, bit of attension to detail. Use paper gaskets not gloop for the reed-block & base. New copper head gasket & exhaust crush-ring etc.
Motor back together, make sure that the reeds are set, make sure that the carbs cleaned & set, make sure that the auto-lube pump is checked and adjusted. New plug, points and condensor (to be sure)
Set the ignition timing a 'tad' retarded from stock setting.
Set the idle mixture a tad on the ritch side, & possibly run the throttle needle one notch lower, (lift needle in slide) to ritchen mix accross the rev range.
See how it runs on that. It'll be down a tad on power and pick-up, and you'll drop a few MPG, but ritch is 'safe'... give it a chance to bed in, and then lean off the mixture & advance the ignition from there to get best running.
Quick Query; do you consistently use the same petrol station?
Is it a cheapo super-market, or independent?
Occassionally, VERY occassionally, something like this can come down to a filling station having low-grade fuel.
Carvel
PostPosted: 23:55 - 04 Nov 2010    Post subject: Reply with quote
I've had it rebored and have a new piston to match. It only came back yesterday so havn't had the chance to fit it yet.
Will do.
It's electronic ignition
I'll give that a go, see how it runs Thumbs Up
Nope just any random station.
Cheers mike Thumbs Up
27cows
PostPosted: 09:13 - 05 Nov 2010    Post subject: Reply with quote
Be careful to run in the new bore/piston and you shouldn't have a problem.
Looking at that piston, I'm wondering if the previous owned just jumped on the bike after a rebore and caned it. That is about the only non-oil failure situation that would do that kind of damage to an RXS top end, I think.
Carvel
PostPosted: 19:39 - 13 Feb 2011    Post subject: Reply with quote
Ok I finally got round to fitting the rebored barrel and new piston the other day and have put a few miles on it since. Unfortunatly it's starting to rattle again so im pretty sure it's going to detroy this piston aswell.
Now it runs ok and it smokes as it should so it must be getting oil, but theres a distinct rattle (which is getting worse with use), most noticeable on tickover. And if you keep it at fairly high revs for a little while it gets seriously f*cking hot, like somethings about to melt levels of heat, at which point it runs cack, wont tickover etc, but let it cool down and it's ok again.
I'm at a loss of what to do really.
Any ideas?
Ollie
cb1rocket
PostPosted: 20:07 - 13 Feb 2011    Post subject: Reply with quote
are you running on the correct plug? you say its so hot that the jet is probably wrong. Are you using a new small end bearing, and is there any play in the big end?.
My GP100 was a pig when I got it, and I had to go through a rebore and new piston. The old one shattered itself! At the moment its touch wood so far, and I still have another 300 miles to run in.
PostPosted: 20:10 - 13 Feb 2011    Post subject: Reply with quote
I'd be checking jetting. What mainjet is fitted? Standard is 120.
Carvel
PostPosted: 20:23 - 13 Feb 2011    Post subject: Reply with quote
It running a br8hs which I think is correct. Small end is new, there's no play in the big end at all.
Have you checked the oil pump is pumping, because it sounds like a lubrication issue to me.
I presumed it was because it was smoking. Whats the best way of going about checking this?
Hmmm, im not sure i'll have a look in the morning.
27cows
PostPosted: 20:31 - 13 Feb 2011    Post subject: Reply with quote
I'd be tempted to trash the motor. Rip it apart for spares. Buy another and chuck that in. Having said that, people charge some quite hilarious prices on ebay for RXS engines these days. Bargains do turn up - one with 12,000 on the clock went £30 last year.
One thing it might be worth checking if you're back using the autolube - make sure the oil tank breather pipe isn't blocked.
If possible, post a pic of the plug so we can see the kind of nick it's in.
Carvel
PostPosted: 20:42 - 13 Feb 2011    Post subject: Reply with quote
I never went to premix in the end, i'll give the breather pipe a check. Thumbs Up
I'll go get one Laughing, give me a minute.
Carvel
PostPosted: 20:58 - 13 Feb 2011    Post subject: Reply with quote
Looks about right to me?
https://i979.photobucket.com/albums/ae271/RxsOllie/Plug-1.jpg
Excuse the quality had to use my phone
cb1rocket
PostPosted: 21:00 - 13 Feb 2011    Post subject: Reply with quote
yeah looks right, how come an RXS is Kawasaki?! Shocked
The last post was made 15 years, 139 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.06 - MySQL Queries: 16 - Page Size: 146.81 Kb
