| Carvel |
 Carvel World Chat Champion
 Posted: 20:43 - 03 Nov 2010 Post subject: rxs premix (still got problems) |
Im going to run my rxs on premix because it siezed up and I dont fancy ruining another fresh rebore and piston. It was siezed when I bought it so there's obviously something going on.
I was just wondering what ratio to run it on. I ran my fizzy on 20:1 but im not too sure about the rxs.
Help greatly appreciated.
Ollie ____________________ 2002 Aprilia RSV1000R, Cbr600Fs, Mk1 B12, Vfr400 NC30...
| Blau Zedong |
 Blau Zedong Banned
| Carvel |
 Posted: 21:19 - 03 Nov 2010 Post subject: |
Im used to it, I used to premix my fizzy. I double checked everything, Bled the pump etc and everything is as it should be. I was thinking it might be something else causing it, like the mixture, but the plugs coming out a good colour and everythings adjusted correctly. The bike itself ran ok, but it rattled like a bastard which got progressively worse before it nipped up. Thing is it used to smoke so it must have been getting two stroke through Bit confused really. ____________________ 2002 Aprilia RSV1000R, Cbr600Fs, Mk1 B12, Vfr400 NC30...
Matt B: I can deal with crushed nuts to beat Ollie. |
| 27cows |
 27cows World Chat Champion
 Posted: 21:45 - 03 Nov 2010 Post subject: |
Something must have been seriously wrong. RXS motors are virtually impossible to seize (I once ran my original motor completely dry and it still didn't seize up, though it did make some scary noises ).
If it was smoking, chances are the issue has nothing to do with lubrication. Could be a dodgy rebore, or a dodgy piston. Have you got a picture of the piston? ____________________ The RXS100: vehicle of choice for Chuck Norris |
| Carvel |
| 27cows |
| Kickstart |
 Kickstart The Oracle
| SnowTigeress |
 SnowTigeress Brolly Dolly
 Posted: 19:34 - 04 Nov 2010 Post subject: |
Tef here (Snowies been at my lappy again!)
Those skirt appatures looked suspiciousely dremmelled to me, so checked e-bay for pics of new pistons.
https://i.ebayimg.com/13/!B))K,IQB2k~$(KGrHqR,!iQEw5yWTwYrBMO5DdEM!!~~_12.JPG
[img]https://i.ebayimg.com/07/!B7Rs(K!!Wk~$(
KGrHqN,!k0Ey+jC1sigBMzvJSioig~~_12.JPG[/img]
I cant be sure but does look like some-one may have tried opening them up. Poss bad DIY porting job?
Quoted oversizes were +50 & +100 too, as Keith said ____________________ Real bikers build their own Renovated and Riding a 1986 Honda CB125TD-C called the Pup. Full Licence 13/09/2012, 1994 Moto Guzzi 750 Strada
Can-Do Girl that does spanners TOO!
TheSmiler: binning it is better than going around a roundabout the wrong way |
| 27cows |
| Carvel |
 Posted: 21:37 - 04 Nov 2010 Post subject: |
This is the piston I bought (crappy pattern one)
https://www.wemoto.com/bikes/Yamaha/RXS_100/83-85/picture/Piston_Kit_0.75_Oversize/
I havn't touched it, thats how it came.
I snapped a ring so had to use an old one but that wouldn't have made any difference.
I checked everything again tonight. The oil tank is squeeky clean. When you take the bleed screw out of the oil pump it flows out fine. Also all the marks on the pulley line up as they should.
That fact that it was smoking before tells me the pump must be alright.
What else could have caused it? ____________________ 2002 Aprilia RSV1000R, Cbr600Fs, Mk1 B12, Vfr400 NC30...
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 22:06 - 04 Nov 2010 Post subject: |
When did it nip up on you?
Cota used to nip up when used on the road... alledgedly... & did so curiousely. Comp-Trial bike, so loads of cooling fins for slow speed running, with little cooling effect.
Run it hard on road, & it would over-cool & nip up. Ritchening the pre-mix weakened the fuel ratio, made things worse, reducing the oil ratio, ritchened the fuel, made it better.
(The err.... underage rider apparently used to slosh half a gallon of neat in the tank to thin it down before heading down the back-lanes to see girlfreind on a Sunday when there were no country busses..... alledgedly!)
If its nipping up when maxed out, could be similar over cooling / weak mixture. Lifting the throttle needle a notch may help.
If its nipping up in traffic, then possibly under-cooling, due to lack of air-flow, may suggest idle mixture too lean.
Whats the ignition timing like? Too much advance / low grade fuel, could be causing knock / hot running.
What about the exhaust? (Is it on the stocker, or it it running a spannie?) pin-hole, leaky joint, lost baffle can make motor run weak, hence hot. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| 27cows |
 Posted: 22:46 - 04 Nov 2010 Post subject: |
| Carvel wrote: | This is the piston I bought (crappy pattern one)
What else could have caused it? |
There's very little difference between one of those pistons and the ones that come in a Yam box. Shouldn't make any difference at all.
You will have checked the reeds/block for signs of breakage, of course. And the air box, to make sure there's a filter in there. Jetting is standard? Oil pipe itself intact and in good nick. Carb spotless. Barrel not ported or otherwise 'enhanced' by overenthusiastic learner.
RXS motors are immensely robust usually and can withstand most things and soldier on. I just can't imagine a reasonable situation where this kind of damage would occur so quickly. ____________________ The RXS100: vehicle of choice for Chuck Norris |
| Carvel |
 Posted: 23:10 - 04 Nov 2010 Post subject: |
| Quote: | When did it nip up on you? |
It happened gradually from when I fitted the piston. It just got worse (noisier, and started running like poo) until I took it apart and found that.
The pipe is standard.
| Quote: | You will have checked the reeds/block for signs of breakage, of course. And the air box, to make sure there's a filter in there. Jetting is standard? Oil pipe itself intact and in good nick. Carb spotless. Barrel not ported or otherwise 'enhanced' by overenthusiastic learner. |
Checked the reeds, they seem fine. Its got an air filter in it. The jetting is, as far as I know, standard. The carb is spotless. Barrels fine, hasn't been messed around with, could have been a shit rebore though.
| Quote: | RXS motors are immensely robust usually and can withstand most things and soldier on. I just can't imagine a reasonable situation where this kind of damage would occur so quickly. |
I know, I am confused. ____________________ 2002 Aprilia RSV1000R, Cbr600Fs, Mk1 B12, Vfr400 NC30...
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 23:34 - 04 Nov 2010 Post subject: |
| Carvel wrote: | I know, I am confused. |
Well scoring & nip means that the piston has got too big for the bore, doesn't it?
So its either bore to piston tolerences weren't right, OR, its got too hot, whichmeans, mixture or ignition.
Given the possibilities & unknowns, going pre-mix, is unlikely to help. Thats just another variable to start messing with.
If you dump the pump for pre-mix, then the oil has to go in via the carb.
Carb meters whatever comes out the petrol tank into the air-stream going into the engine. So when you mix oil in the petrol to make pre-mix, you are diluting the amount of petrol going into the carb, so you get a lean petrol to air mixture, and need to compensate, lifting the throttle needle and ritchening the idle mixture, to compensate.
That throws everything from stock settings, and as you'd ned to experiment to find the best pre-mix ratio, means a lot of mucking about, for what might not be any problem.
From where you are at: Will the piston clean up? Can you hone the bore? Or do you want to go the safe route and get a new, better rebore & new piston?
Putting it all back together, bit of attension to detail. Use paper gaskets not gloop for the reed-block & base. New copper head gasket & exhaust crush-ring etc.
Motor back together, make sure that the reeds are set, make sure that the carbs cleaned & set, make sure that the auto-lube pump is checked and adjusted. New plug, points and condensor (to be sure)
Set the ignition timing a 'tad' retarded from stock setting.
Set the idle mixture a tad on the ritch side, & possibly run the throttle needle one notch lower, (lift needle in slide) to ritchen mix accross the rev range.
See how it runs on that. It'll be down a tad on power and pick-up, and you'll drop a few MPG, but ritch is 'safe'... give it a chance to bed in, and then lean off the mixture & advance the ignition from there to get best running.
Quick Query; do you consistently use the same petrol station?
Is it a cheapo super-market, or independent?
Occassionally, VERY occassionally, something like this can come down to a filling station having low-grade fuel. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Carvel |
 Posted: 23:55 - 04 Nov 2010 Post subject: |
| Quote: | From where you are at: Will the piston clean up? Can you hone the bore? Or do you want to go the safe route and get a new, better rebore & new piston? |
I've had it rebored and have a new piston to match. It only came back yesterday so havn't had the chance to fit it yet.
| Quote: | Motor back together, make sure that the reeds are set, make sure that the carbs cleaned & set, make sure that the auto-lube pump is checked and adjusted. |
Will do.
| Quote: | points and condensor |
It's electronic ignition
| Quote: | Set the idle mixture a tad on the ritch side, & possibly run the throttle needle one notch lower, (lift needle in slide) to ritchen mix accross the rev range. |
I'll give that a go, see how it runs
| Quote: | Quick Query; do you consistently use the same petrol station?
Occassionally, VERY occassionally, something like this can come down to a filling station having low-grade fuel. |
Nope just any random station.
Cheers mike  ____________________ 2002 Aprilia RSV1000R, Cbr600Fs, Mk1 B12, Vfr400 NC30...
| 27cows |
| Carvel |
| cb1rocket |
 cb1rocket World Chat Champion
| Blau Zedong |
 Blau Zedong Banned
| ms51ves3 |
 ms51ves3 Super Spammer
| Carvel |
| 27cows |
| Carvel |
| Carvel |
| cb1rocket |
 Posted: 21:00 - 13 Feb 2011 Post subject: |
yeah looks right, how come an RXS is Kawasaki?!  |
The last post was made 15 years, 140 days ago. Instead of replying here, would creating a new thread be more useful? |
